02-04-2019, 09:28 PM | #1 |
Rep 170
Boost leak or turbo problem?
So I thought it was just a cold problem but it seems to be getting worse. I have a whistling noise which seems to build as I build boost. It starts around 2500 rpm. Uploaded a bad video here.
Should I be concerned at all? Boost leak? Turbo going to fail soon? log, seems like there's too much boost if anything.... so it seems like either normal or early turbo failure sign? http://www.bootmod3.net/log?id=5c591487ae729b7de7f4654d At first I thought the sound was cool. But I also thought it showed up because it was freezing cold outside and thought it would go away... Last edited by meltbox; 02-04-2019 at 11:01 PM.. |
02-04-2019, 09:33 PM | #2 |
Rep 3,679
Hard to tell, that's a cummins that makes a lot of noises the N20 doesn't. Try and upload a video of your car so we can tell better.
meltbox43.00 |
02-04-2019, 10:57 PM | #3 |
Rep 170
Terrible camera work and the sound is a bit hard to pick out. It is the whistling sound. It comes through clearer in real life than it does on the video. May have to turn it way up to hear.
Updated in op. |
02-05-2019, 08:37 AM | #4 |
Rep 3,679
Hmmmm, I don't know about that sound, but the log is head scratcher. It's making just the right amount of boost (albeit laggy in the beginning) and the WGDC is fine, so that doesn't indicate a boost leak, and it doesn't look like the turbo is compensating for one. I don't know what is going on with the throttle angle and accel. pedal % though. Either the reading is off, or more likely, you're having some throttle closure issues. Simple way to tell which it is: did the car feel like it stopped pulling while you still had your foot down? You can see in the log, the early part of the pull was very lean, and when it got too lean, the throttle angle dropped into the 20s/30s. Then when it richened back up it opened, then leaned and closed again. It looks small scale, so I wouldn't be too surprised if it was a fluke of the pull, especially if the car pulled smoothly and steadily.
Anyway, that's just what I noticed in the log. About the noise: purely based off the sound, it sounds turbo related, but there's nothing in the log (that I could pick out, completely possible I missed something) that would indicate turbo issues. Kinda stumped there. Also: what map are you running?
02-05-2019, 06:03 PM | #5 |
Rep 170
BM3 93 octane stage 1 but it's a custom version since I had a ton of vibration in the lower rpm range with the ots one. I'll do another couple of pulls and try to see if it's consistent. Maybe up to higher speeds or through more than one gear.
Edit: Car feels pretty good and responsive. If anything maybe feels like boost is a little slow to build. Any concern on why the target sits at 19 and it's delivering 23psi? That doesn't seem exactly right. But then again I know very little. Just here to learn. |
02-05-2019, 07:04 PM | #6 | |
Rep 3,679
02-05-2019, 09:21 PM | #7 |
Rep 170
http://www.bootmod3.net/log?id=5c5a3e2fae729b7de7f466c9
Also have you ever had an issue where logs you take end up empty on the website? Most of the logs I took today download as an empty csv file and dont open on the website at all. Stuff has been buggy lately for me. Wonder if it is my phone. This log seems okay to me too. I feel like I'm chasing a phantom again. Looked around the turbo and charge pipes but everything seems okay. Will take another look when its bright outside and I have some spare time. EDIT: http://www.bootmod3.net/log?id=5c5a3e2fae729b7de7f466c9 Better log from an on ramp. What is a reasonable wgdc? Mine seems to never drop below 80% when WOT but I have nothing to reference against. Kind of makes sense for it to be high given the WOT. If anyone is on this tune and could post a log so I can compare I would appreciate it. |
02-05-2019, 09:34 PM | #8 | |
Rep 3,679
WGDC should be above 85 bare minimum at WOT.
02-05-2019, 10:29 PM | #9 |
Rep 170
Your log is extremely clean. No deviation, no throttle closure. Lower WGDC and higher boost would indicate my turbo is doing better than normal.
Yea the more I look at my logs the more I think something is really screwy. Those throttle closures and over a psi deviation is normal in my logs. Don't know if its trying to use throttle to compensate for that somehow and create a pressure drop before the manifold? There is even a place where the MAF reading dips during WOT which doesn't make any sense... I might flash back to stock just to see. If things are broken when I am stock then at least I can rule out the tune. I have run logs by PTF so I think they would have caught this. I deleted those logs though... wish I hadn't. |
02-06-2019, 06:51 AM | #10 | |
Rep 3,679
According to the MAP psi, your boost levels are perfectly normal. It's expected on these engines for boost to taper off in the higher rpms as the turbo is so small it runs out of steam. Again, according to the MAP, your car is fine, but looking at pre-throttle, it's overboosting just a bit. It's always a good idea with an issue like this to flash back to stock and log to rule out mechanical issues and isolate the issue to the tune. Also, open a support ticket with PTF and tell them your seeing these throttle closures but not feeling them. Ask them about the deviation between pre-throttle and MAP psi too, I'm really curious to see what they say there.
02-06-2019, 04:54 PM | #11 |
Rep 170
So I flashed back to stock and.... it still whistles. I cannot get logging to spit out a log. I keep getting logs that have time uknown or are 340 seconds long when I only log for maybe 50 seconds at a time. Opened a ticket with PTF. I'll post back when I have another log.
Side note. I complained to PTF a lot about idle quality. I can now say that I am not crazy. The idle quality on stock tune is miles better. Feels smoother too on the pulls but way less power. Really want to see what the logs look like. I will try again later today. What is confusing me is I think they said they don't change anything at idle so I don't understand why there is so much less vibration in the cabin/through the seat. EDIT: I should note here that the tune I was running was a custom fix by PTF for me because of some of my complaints. I wonder if the throttle closure is a result of that. Lots to test here. The custom tune was to address a vibration issue I had under high load at lower rpm. The car would make a deep rumbling noise. It would do this while in drive-comfort too when I requested more torque but not enough to downshift. |
02-06-2019, 05:42 PM | #12 | |
Rep 3,679
For the logging issue: go to your BM3 page, click "About" at the bottom of the list, and then click the "Reset Settings" button. I had a similar issue and this fixed it.
meltbox43.00 |
02-06-2019, 06:57 PM | #13 |
Rep 170
http://www.bootmod3.net/log?id=5c5b779ec090c60e36a144cb
http://www.bootmod3.net/log?id=5c5b785dc090c60e36a144ce Your fix did not work unfortunately. I did however find that if i toggle to the datalog tab after taking every log then they save properly. Otherwise I get garbage if I take back to back logs without leaving the dashboard. I seem to still have throttle closure. Peak pressure seems low even for stock. Deviation seems much smaller than before though and timing across cylinders is dead consistent here. Whistle seems to be related to a certain rpm range of the turbo impeller while it spools or something since it still occurs in a similar place despite way lower pressures now. That is not what I was hoping but the conclusion I am drawing right now. EDIT: Sent all the logs to PTF for comment. I'll let you know what I learn. Thinking the next step could be to book a dyno and ask them to help me find this sound. Might as well dyno stock vs stage 1 while I'm there too. Been meaning to for a while. EDIT2: Is this normal AFR for stock? I remember it running much leaner for some reason even at WOT. I'm hitting high 11's in some cases. Upon closer inspection it also seems that throttle closure occurs right about where AFR drops. Don't know if throttle closure is causing it but it sure is related somehow. EDIT3: You wouldn't have a stock log lying around handy now would you? That would be very lucky on my part haha. Also the throttle closure seems to follow AFR drops which is odd. Also its definitely what is causing the much higher pre throttle psi in my 93 octane stage 1 log up top. EDIT4: WGDC looks better on stock. Funny that its higher despite barely hitting 16psi. Last edited by meltbox; 02-06-2019 at 07:16 PM.. |
02-06-2019, 07:39 PM | #14 | |
Rep 3,679
meltbox43.00 |
02-06-2019, 07:47 PM | #15 |
Rep 170
Interesting your log has some too about 11.3 seconds into the log. Throttle hits mid 30%. Am I reading that right? Maybe this is just normal as odd as it seems.
EDIT: https://www.n54tech.com/forums/showthread.php?t=47424 Seems to be the case the more I look. Will still update when PTF responds. Last edited by meltbox; 02-06-2019 at 07:53 PM.. |
02-06-2019, 08:09 PM | #16 | |
Rep 3,679
That link is a good reference, and kind of echoes what I said earlier. If the throttle modulates when WOT that's normal to regulate boost. But what we see in your first log is beyond that normal modulation.
meltbox43.00 |
02-06-2019, 10:35 PM | #18 |
Rep 170
On the bright side seems like a new turbo costs almost nothing off ebay. Upgraded turbos could also be a good idea. Run a reliable power bump with a reliable turbo. Thanks for the help so far. Appreciate it.
I also checked the air box and my filter to see if maybe something in there was whistling. Nothing. Still need to check around where the turbo sucks in air. I'll find this or go crazy trying. |
rjd_F301999.50 |
02-07-2019, 08:03 AM | #19 | |
Rep 3,679
Yah hopefully you can pinpoint the sound. Never asked, does it make the sound when you're just in park and rev it?
02-07-2019, 07:08 PM | #20 |
Rep 170
Nope, no noise when in park. May have pissed off the neighborhood standing around revving haha. Hold on I recorded a video with sound while recording my dashboard screen. Gives a little context as to when it happens.
The gears I mention refer to the acceleration right before not after. Also PTF responded on the throttle closure. They said it is normal and BMW uses it to keep the target boost and MAP boost perfectly on top of each other. I am still asking again to make sure they looked at the 93 log since theres prolonged throttle under 30% with slight overboost at MAP. Maybe not concerning but I figured I would double check. As for this noise of mine. You think this could be intake leak somewhere? I cannot find another video of any car making a similar noise. If this was exhaust side I would imagine I would get a CEL or something. It also doesn't seem hissy enough to be pre throttle pressurized anything. Its not impossible but its such a whistly sound its strange. I think I don't have a choice. I might have to ask the people at the nearby dyno to see if they will help me figure out where it's coming from. I'm not one to wait until turbo pieces are in my engine. Last edited by meltbox; 02-07-2019 at 07:15 PM.. |
02-07-2019, 09:17 PM | #21 | |
Rep 3,679
Yah that noise is odd lol. I'd bet dollars to donuts it's not a leak. The logs would indicate the same as well. I don't mean to scare you saying this, and I'm sure you already know this, but I guess it could be any part of the rotating assembly in the turbo, maybe something is starting to give up that whine noise sounds more mechanical than a leak. At least if it's not happening in park, you know it's dependent on the car being under load, a big part of which is the turbo. The fact that it only happens when making boost... yah. I'm obviously just speculating, but just a thought.
02-07-2019, 09:58 PM | #22 | |
Rep 170
