BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > DIY Complete Guide to full LED bulb swap for the F30s with halogen headlights
      05-05-2018, 03:02 PM   #45
jeimon
Drives: 2017 X3 (F25)
Originally Posted by Billfitz View Post
No. If you do you'll screw up the beam pattern.
Thanks!
      05-07-2018, 06:50 AM   #46
drewkelly
drewkelly's Avatar
Drives: 2018 340i xDrive, 2017 X5
Sorry for my ignorance...hoping someone can help me out. Your price list is:
Pricing:
$22.50 - Low beam LEDs
$9.29 - Parking lights LEDs
$8.29 - DRLs LEDs
$28.68 - Vgate WiFi Adapter
$35.00 - BimmerCode App
Total: $103.76
I have a OBD cable + E-Sys and have coded successfully.
With that said, do I need the Vgate + BimmerCode App? Or, can I do everything I need to do on E-Sys? If that's the case, I can upgrade to LEDs for around $40? That's a no-brainer...
      05-07-2018, 07:22 AM   #47
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If you have E-Sys you don't need bimmercode or any other coding tools. They all do the same thing. You will want to go LED high beams and fogs if you have them as well, you won't be satisfied with halogens after seeing the improvement with the low beams. I went LED for the brake and rear turn signals as well, in part after seeing problems some have had with connectors over heating and burning out. The 90% reduction in current draw with LED should prevent that.
      05-09-2018, 09:04 PM   #48
jeimon
No FEM/Bulb change option on Bimmercode app
Hi Guys, I followed crimson instructions and got everything but run into an issue:
I have a 2017 X3 with Halogen lights. I'm trying to change to LED and when trying to code with bimmercode I'm not getting the bulb change or cold/warm options on the app (using iphone).
First of, there is no "FEM" option, the lighting options are in "Footwell Module" section. And once there what I get is the "Angel Eyes brightness" option. It seems to me that this car came from factory with Angel Eyes lights and was later fit with Halogen headlights.
Is there a way to code back to non-Angel Eyes headlights?
Please help, I changed bulbs successfully but getting the DRL and Low Beam bulb malfunctioning message.
I will go and look/learn coding. Just please point me in the right direction or tell me If what I'm trying to do is even possible.
Please!
      05-09-2018, 09:56 PM   #49
Billfitz
Billfitz's Avatar
Try posting in the coding forum. The coding experts will see it there, probably not here.
      05-09-2018, 10:33 PM   #50
IK6SPEED
Drives: BMW M3 / AH3
Please!
Bimmercode is a “cheat sheet”. A predetermined list of the most common coding options in a simple menu form. It’s a microwave dinner instead of a legit home cooked meal.
It will let you change a few of the most common things.
However, you do not go to a storefront walk-in clinic when you need heart surgery or something more complicated than a stitch or a flu shot.
If you want to be able to do all coding needed for projects like this, you need a real coding solution. Not bimmercode.
      05-09-2018, 10:52 PM   #51
jeimon
I hear ya IK6SPEED, and appreciate your response. But I see Bimmercode has the "expert mode" with all kinds of options. I just don't know how to use them. You are telling me that even there, there is no solution to my issue? Anywhere to learn/look for what those expert modes options can do?
      05-12-2018, 04:11 PM   #52
crimson_king
Drives: 2014 328i F30 Manual Trans
You can try emailing the Bimmercode developer or searching in the X3 forums for codes from people with experience. Someone must know if an option exists within Bimmercode or the developer can add it in for you in the next update if yo ask nicely
      05-12-2018, 08:56 PM   #53
Billfitz
Billfitz's Avatar
+1. You really need to be in the F25 forum for F25 questions. For instance:
http://x3.xbimmers.com/forums/showthread.php?t=1452617
      05-15-2018, 05:33 AM   #54
hakisalapaki
Drives: BW 2012 F30
i am not happy with the cutoff line..
      05-15-2018, 07:34 AM   #55
Billfitz
Billfitz's Avatar
If you don't tell people which bulbs gave you that result it's not helpful.
AndrewC198910931.00
      05-19-2018, 07:51 PM   #56
andyt26
Drives: 2015 BMW 335i Msport
Do the parking light LED’s require coding?
      05-19-2018, 07:53 PM   #57
crimson_king
Yes, "position lights" in my pics from bimmercode
      05-20-2018, 01:27 PM   #58
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Very nice OP but what about the highbeams and fogs though?
      05-20-2018, 01:31 PM   #59
crimson_king
I'm going to buy and post about the fogs and front and rear turn signals as well, probably not going to change out the highs as I never use them
      05-20-2018, 01:40 PM   #60
AndrewC1989
Is there a list of every bulb type used in the front and rear that you know of by any chance?
I'd like to choose the brands and bulbs myself, I'm just not sure what kinds of bulbs are needed in each section.
      05-20-2018, 01:43 PM   #61
crimson_king
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
AndrewC198910931.00
      05-20-2018, 03:21 PM   #62
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
AndrewC198910931.00
      05-21-2018, 04:19 PM   #63
andyt26
Whoever has Bimmercode can you tell me if there are cold and warm check options for turn signal bulbs? Looking to replace mine with some brighter LED’s and need to know if there’s an option to code those checks out in case they cause flickering.
      05-21-2018, 04:21 PM   #64
crimson_king
Yes there is an option for cold/warm checks. Please see my guide/first post for photos of bimmercode - same options for turn signals too
      05-21-2018, 04:36 PM   #65
andyt26
Thanks bro. I had someone code my LED’s for me last time but I want to start learning how to do it myself. Ordered the device on amazon waiting for it to get here Wednesday.
      05-22-2018, 05:57 AM   #66
CDJohn1223
Drives: 2014 328i X-Drive
Just did my front turn signals this past weekend. Changed bulb type to LED and turned off the warm/cold checks. Works great.
