04-14-2019, 08:20 AM | #23 |
Rep 541
11-03-2019, 10:01 PM | #24 |
Rep 10
11-30-2020, 02:50 AM | #28 |
Rep 25
Drives: BMW 120i F20 Msport
I tried on my F20, everything codes ok except WLAN_WIFI_DIRECT which stops with an error. I suppose my car doesn't have the correct hardware (which is as below)
Code:
hmi.type: BMW ID6L hmi.version: EntryEvo_ID5_1903_Release ID5_1903-490-1837K Build 47 - Rev:203015 2018-11-14 08:39:42 |
11-30-2020, 04:56 AM | #29 |
Rep 457
Do you have wireless charging + WiFi hotspot?
11-30-2020, 06:13 AM | #30 |
Rep 25
no but I have extended bluetooth ... below the "S6* " options my car have
Code:
S698A Area-Code 2 for DVD S6ACA Intelligent emergency call S6AEA TELESERVICES S6AKA Connected Drive Services S6APA Remote Services S6NHA Hands-free system with USB interface |
12-31-2020, 07:59 AM | #32 |
Rep 291
I've just successfully coded mine with Bimmercode. Mine definitely doesn't have WiFi preparation so, as others have said, it seems as though there's a built in antenna on some head units. Mines NBTEvo_L with ID6.
12-31-2020, 01:49 PM | #33 |
Coding ECU's remotely
445
Rep 1,176
There is no built in antenna, carplay and screen mirroring will work without the antenna plugged in but just not as well and at a limited range.
12-31-2020, 01:55 PM | #34 |
Rep 291
01-01-2021, 07:34 AM | #35 |
445
Rep 1,176
01-01-2021, 12:47 PM | #36 |
Rep 291
01-02-2021, 02:22 AM | #37 | ||
Rep 25
02-18-2021, 06:38 AM | #39 |
Rep 3
Great! You've followed the instructions from Abzynthe?
01-25-2022, 02:11 PM | #40 | |
Rep 9
NBT_EVO2: ENT_MIRACAST -> aktiv ENT_MC_WLAN_STREAM_DMP -> aktiv ENT_MIRACAST_DISPLAY_SETTINGS -> aktiv WLAN_WIFI_DIRECT -> aktiv WLAN_STATUS -> aktiv I assume they will be also in Expert Mode for coding, not the standard? Could you please advise how did you manage to code the Screen Mirroring option enabled via BimmerCode? Any help appreciated. Thank you in advance! |
01-28-2022, 02:03 PM | #41 |
Rep 135
I have screen mirroring and in my opinion its pointless....it mirrors the phone to the screen in the same aspect ratio, so you cant see a lot and it takes up only 3/4 of the screen but sits in the middle its like you have stiuck ya phone up against the screen...im really not finding any use for it unless it can be made full screen which ive looked into and it seems it cant. I wouldnt rush to do it honestly!
01-29-2022, 04:48 AM | #42 | |
Rep 9
Did you enable this with the commands I have listed above? What software did you use to achieve this? Thank you. |
01-29-2022, 05:43 AM | #43 | |
Rep 135
01-29-2022, 09:53 AM | #44 |
Rep 291
I tend to agree. Neither Netflix or Prime work properly (plays sound but not picture due to protection I'm assuming). YouTube works well though, as does Google Maps, but you're locked into listening to whatever is playing via WiFi, which weirdly isn't as stable as Bluetooth. I bought a WiFi antenna in the end, which has extended the range within the car significantly (obvs)
