09-16-2018, 03:02 PM | #1 |
Rep 57
Oil Change Now Car Won't Shift out of Park?
I changed the oil on my 16' 428i GC and now the car won't shift out of park. Would anyone have any ideas on why?
It was a fairly simple process.. drain the oil and torque the plug back to 8Nm. Filled the car back to 5 quarts of genuine bmw 0-20w oil and change the oil filter/orings torqued to 25Nm. Car starts fine and shows the oil level is good... I'm stumped. When shifting out of park to D or R, it would automatically go back to P. |
09-16-2018, 08:01 PM | #4 |
Rep 640
Drives: 2008 M3 (E93)
I don't know how car savvy you are but I have to put it out there. Did you drain your transmission fluid by accident instead of your oil?
09-16-2018, 11:42 PM | #5 | |
Rep 57
Fixed now but lesson learned. Ahhh first time owning a german car obliviously.. Thanks everyone. Good thing the 340 is my secondary |
09-17-2018, 12:13 AM | #6 |
Rep 5,087
09-17-2018, 06:23 AM | #7 | |
Rep 640
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
09-17-2018, 07:22 AM | #8 |
Rep 16,060
This points out why it's a good idea to check a service manual before doing anything on these cars. They're not 57 Chevys.
https://www.newtis.info/tisv2/a/en/ |
09-17-2018, 10:43 AM | #10 | |
Rep 714
I did recently an ATF and oil pan/filter change on my 2010 335d. You have to follow carefully the ZF transmission instructions. If you fill the transmission up to the neck of filling hole without engine running, the transmission will be under filled. |
09-19-2018, 07:56 AM | #11 |
Rep 1,827
Wait. What about the EXTRA 5qts of oil now in your car??
rjd_F301999.50 |
09-19-2018, 08:10 AM | #12 |
Rep 5,989
Is this a CPO car you should get free oil changes if you brought it new. Also like previous poster said you may have too much oil in your engine now. I though the ZF was a sealed transmission I guess I'm wrong. Messing with ATF can be sketchy at best. If you do it wrong you could ruin the transmission.
09-20-2018, 06:49 AM | #14 |
Rep 3,679
OP, these things happen to the best of us lol. But just re-cap: you've got to re-fill the trans with the proper amount of new ATF (not sure how much that is) and then I assume you drained all the oil from the engine and refilled with 5 liters of that 0W-20? Hopefully you didn't run the engine too much with nearly 10 liters of oil in it.
Also, curious as to why you chose 0W-20 for the N20, I always use BMW branded 0W-40.
09-20-2018, 07:04 AM | #15 |
Rep 16,060
09-20-2018, 07:15 AM | #16 |
Rep 3,679
I see. I wasn't aware of that... But yah, I would use a thicker oil in a warmer climate like SoCal.
09-26-2018, 09:52 AM | #17 |
Rep 785
wtf this thread.
Anyone have a pic of where the transmission is drained? I have changed my oil a number of times and dont recall seeing anything for the transmission |
11-02-2018, 12:47 AM | #18 |
Rep 57
Ah forgot to update you guys.
Yes, brand new Lifeguard ZF8 transmission fluid was used to refill the car. I used ISTA/D to measure the oil temp for the correct fill. All 10 quarts of the oil were drained and refilled with new oil.. that was the easiest part! Easy fix guys no sweat madmortar it's under the plastic cover that the exhaust runs parallel to.. Last edited by dorkiedoode; 11-03-2018 at 10:31 PM.. |
rjd_F301999.50 |
