10-11-2018, 12:06 PM | #1 |
Rep 17
80ah instead of 90ah Battery any dangers!?
Hi guys sorry if this sounds naive but thought I get expert advice from you guys ok so am replacing the battery in my F30 320d ED it had a 90ah battery but I have just ordered an 80AH battery albeit with the same voltage and size would it be a problem !?
Thanks for your replies |
10-11-2018, 12:59 PM | #2 | |
Rep 10,473
vooonoo537.00 |
10-11-2018, 01:05 PM | #3 |
Sedan Driver
389
Rep 1,018
make sure you have your car coded and registered for the 80AH battery otherwise the car may over charge the battery.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
upsidedownfunnel1996.00 |
10-11-2018, 01:18 PM | #4 |
Rep 2,499
Yeah you should use a 90Ah battery. If you absolutely don't want to, make sure to code it for the new battery capacity in ADDITION to registering it. If you simply do a battery registration, it will assume the new battery has the same capacity as the old one.
10-11-2018, 03:53 PM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3124
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
No but it needs to be registered (coded). Car is coded to charge for 90 amps. IIRC you can code for 70-80-90 batteries.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
10-11-2018, 04:13 PM | #7 |
No 55mph
1619
Rep 8,476
Rule of thumb - never replace a battery with one of lower capacity.
Your car came with 90ah for a reason...
10-11-2018, 05:33 PM | #9 |
Rep 5,984
10-11-2018, 06:17 PM | #10 |
Rep 10,473
10-11-2018, 06:47 PM | #11 | |
Rep 17
10-11-2018, 07:24 PM | #12 | |
3124
Rep 5,264
You want to maintain or exceed the factory specs on the discharge sides CCA, CA & reserve capacity ratings
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 10-11-2018 at 08:06 PM.. |
10-11-2018, 07:35 PM | #13 | |
Rep 10,473
Wattage is only one part of the equation. You can use 8 D size batteries in Series and get 12VDC for about 10£ using your logic. Or save space and use a single 9 volt and 2 D batteries for 5£ Last edited by IK6SPEED; 10-11-2018 at 07:44 PM.. |
1QuikWS61618.50 |
10-12-2018, 05:06 AM | #14 |
No 55mph
1619
Rep 8,476
The AH rating means:
AH = Amperes per hour(Amperage), a 90Ah battery means that your battery can last for 1 hour by giving 90A continuously, This is in a perfect world with battery @ 100% charge to begin with, normal state of charge in real life of a battery installed in car might be around 70–75% = less than 1 hr in real life With all the electronic systems pulling off the battery in new cars it's best to go with highest AH available for your specific car - again, that's the reason the 90ah battery was installed from the factory I get it that the other may be cheaper, but you should have guessed that owning a BMW was not gonna be cheap from the start And yes, there are aftermarket batteries available with 90ah rating that would be cheaper so that's an option Did your pricing include new battery, installation, & registering? Here in U.S. I was quoted $700 for all included in my old E92, I'm not gonna pay that price for a battery, so I purchased a new OEM BMW battery of correct ratings, installed it myself, & registered it with Carly app/dongle > Even if you install a battery of same rating it should be Registered so that the charging logic car uses is correct - this can be done DIY using Carly or Bimmercode >If the new battery is a different ah than factory also = Coding different ah is necessary + Registering upon install
