07-28-2021, 09:18 AM | #1 |
Rep 115,980
n54tuning.com - F-Series N20/N26/N55 High Performance Fuel Pump
ORDER LINK https://www.n54tuning.com/f-series-n...fuel-pump.html F-Series N20/N26/N55 High Performance Fuel Pump PRECISION RACEWORKS SKU: 601-0014 The Precision Raceworks F-SERIES N55 HIGH PERFORMANCE FUEL PUMPS are designed for customers looking to run all blends of E85. These drop in pumps include a Walbro fuel pump capable of flowing up to 300% more fuel than the factory fuel pump and is 100% E85 compliant. Best of all this pump ships completely assembled and ready to install we don’t even have a core charge. New pump, new fuel filter, and new sending unit included! By design a fuel pump such as this is ideal for daily driving and racing applications of all kinds. This system keeps the primary pump fully submerged in fuel regardless of tank level or the g-force the car is subjected to. Stage 2 (2.4 gallons per minute) Our Stage 2 bucketed fuel pump comes with a single Walbro 450 (F90000274) fuel pump. This pump can support up to 575whp (Rated for 500whp on 100% E85) and is drop in ready just like the OEM fuel pump. No wires to cut or splice, nothing to assemble, 100% OEM quality and drop in ready. Included in the box New genuine OEM fuel pump bucket assembly Pre-assembled with genuine Walbro 450 pump Includes new fuel sending unit (fuel level sensor) New primary and secondary fuel filters Stage 2.5v2 (3.1 gallons per minute) Our Stage 2.5v2 bucketed fuel pump comes with a single Walbro 535 (F90000285) fuel pump. This pump can support up to 675whp (Rated for 600whp on 100% E85) and is drop in ready just like the OEM fuel pump. No wires to cut or splice, nothing to assemble 100% OEM quality and drop in ready. Included in the box New genuine OEM fuel pump bucket assembly Pre-assembled with genuine Walbro 535 pump Includes new fuel sending unit (fuel level sensor) New primary and secondary fuel filters Stage 3 (5 gallons per minute) Our Stage 3 bucketed/bucketless hybrid fuel pump includes all necessary wiring and pump activation switch (hobbs switch). This pump boasts a single primary Walbro 450 (F90000274) fuel pumps in bucket and a second Walbro 450 (F90000274) fuel pump outside the bucket. This pump can support850whp (Rated for 800whp on 100% E85) and is drop in ready. No wires to cut or splice, nothing to assemble, simply drop the bucketless system into the tank, insert the factory pump, mount the bucketless to side of bucket and close the top hat you are ready to go! Included in the box New genuine OEM fuel pump bucket assembly Pre-assembled with dual genuine Walbro 450 pumps Includes new fuel sending unit (fuel level sensor) New primary and secondary fuel filters Stage 3.5 (6 gallons per minute) Our Stage 3 .5 bucketed/bucketless hybrid fuel pump includes all necessary wiring and pump activation switch (hobbs switch). This pump boasts a single primary Walbro 450 (F90000274) fuel pump in bucket and a second Walbro 525 (F90000285) fuel pump outside the bucket. This pump can support 950whp (Rated for 875whp on 100% E85) and is drop in ready. No wires to cut or splice, nothing to assemble, simply drop the bucketless system into the tank, insert the factory pump, mount the bucketless to side of bucket and close the top hat you are ready to go! Included in the box New genuine OEM fuel pump bucket assembly Pre-assembled with Walbro 450 (Primary), Walbro 525 (Secondary) Includes new fuel sending unit (fuel level sensor) New primary and secondary fuel filters Plug and play boost reference harness (zero cutting, stripping, crimping) 13psi boost reference switch (hobbs switch) Stage 4v2 (6 gallons per minute) Our Stage4 bucketed/bucketless hybrid fuel pump includes all necessary wiring and pump activation switch (hobbs switch). This pump boasts a single primary Walbro 535 (F90000295) fuel pump in bucket and a second Walbro 525 (F90000285) fuel pump outside the bucket. This pump can support OVER 1,000whp! (Rated for 950whp on 100% E85) and is drop in ready. No wires to cut or splice, nothing to assemble, simply drop the bucketless system into the tank, insert the factory pump, mount the bucketless to side of bucket and close the top hat you are ready to go! Included in the box New genuine OEM fuel pump bucket assembly Pre-assembled with Walbro 535 (Primary), Walbro 525 (Secondary) Includes new fuel sending unit (fuel level sensor) New primary and secondary fuel filters Plug and play boost reference harness (zero cutting, stripping, crimping) 13psi boost reference switch (hobbs switch) This is a true plug and play solution that anyone can install in their home garage and start taking advantage of the benefits right away. Factory BMW pump Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: Horsepower Supported 100% E85: NOT COMPATIBLE Stage 2 Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: 575 Horsepower Supported 100% E85: 500 Aftermarket EKP Required: No Stage 2.5v2 Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: 675 Horsepower Supported 100% E85: 600 Aftermarket EKP Required: No Stage 3 Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: 850 Horsepower Supported 100% E85: 800 Aftermarket EKP Required: No Stage 3.5 Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: 950 Horsepower Supported 100% E85: 875 Aftermarket EKP Required: No Stage 4v2 Pump flow 72psi (5bar): XXX GPM Pump Weight: Horsepower Supported Pump Gas: 1,000+ Horsepower Supported 100% E85: 1,000 Aftermarket EKP Required: No Vehicle Fitment Bmw 228i 2014 to 2016 Bmw 228i Xdrive 2015 to 2016 Bmw 320i 2013 to 2018 Bmw 320i Xdrive 2013 to 2018 Bmw 328i 2012 to 2016 Bmw 328i Gt Xdrive 2014 to 2016 Bmw 328i Xdrive 2013 to 2016 Bmw 335i 2012 to 2015 Bmw 335i Gt Xdrive 2014 to 2016 Bmw 335i Xdrive 2013 to 2015 Bmw 428i 2014 to 2016 Bmw 428i Gran Coupe 2015 to 2016 Bmw 428i Xdrive 2015 to 2016 Bmw 428i Xdrive Gran Coupe 2015 to 2016 Bmw 435i 2014 to 2016 Bmw 435i Gran Coupe 2015 to 2016 Bmw 435i Xdrive 2014 to 2016 Bmw 435i Xdrive Gran Coupe 2015 to 2016 Bmw M235i 2014 to 2016 Bmw M235i Xdrive 2015 to 2016 |
08-07-2021, 08:11 PM | #2 |
Rep 115,980
08-15-2021, 06:40 PM | #3 |
Rep 115,980
09-01-2021, 04:46 PM | #4 |
Rep 115,980
09-07-2021, 04:38 PM | #5 |
Rep 115,980
09-10-2021, 07:39 PM | #6 |
Rep 115,980
09-18-2021, 09:47 AM | #7 |
Rep 115,980
09-24-2021, 10:16 AM | #8 |
Rep 115,980
09-28-2021, 06:28 PM | #9 |
Rep 115,980
11-01-2021, 09:37 AM | #10 |
Rep 115,980
11-13-2021, 04:52 PM | #11 |
Rep 115,980
11-22-2021, 01:10 PM | #12 |
Rep 115,980
11-22-2021, 01:11 PM | #13 |
Rep 115,980
12-03-2021, 12:30 PM | #14 |
Rep 115,980
12-10-2021, 10:45 AM | #15 |
Rep 115,980
05-23-2022, 05:51 PM | #16 |
Rep 115,980
07-29-2022, 05:39 PM | #17 |
Rep 115,980
08-18-2022, 10:04 PM | #18 |
Rep 115,980
10-24-2022, 10:14 AM | #19 |
Rep 115,980
