09-13-2021, 01:21 PM | #1 |
Rep 205
I got the catted Akrapovic Downpipe professionally Installed 3 weeks ago and have not had any issues until now.
Engine management light came on today (surprised iDrive doesn't tell me what the code is) but I assume it has to do with the Downpipe. I installed a catted Downpipe, so I was assuming there wasn't going to be any emissions issues. Has anyone else had any issues like this with a catted Downpipe especially Akrapovic? Could it possibly be a faulty install? I have a 2017 340 w/ mppsk |
09-13-2021, 01:52 PM | #2 |
Rep 1,452
On their website, it states that their catted DP does not meet emissions requirements. Not all catted DP's are created equal unfortunately. Only one avail that I know with a CEL guarantee is the AA catted for $1,300.
2022 CT4-V Blackwing 6-speed
09-13-2021, 05:46 PM | #3 |
Rep 205
Yeah I saw that. The reviews I read said no issues with CEL with akra's catted DP, though which is why I was concerned. I suppose a "high-flow" cat might still be too much flow for my CEL.
I stopped by a shop and ran the code which read faulty cat converter. The tech there said it was possible my mppsk tune/exhaust has to get used to the higher flow? Not sure about this, but he cleared the code and advised me to see if it continues to come on or if it starts to clear by itself. My main concern is the install wasn't properly done which I suppose I'll find out after driving a few more days. |
09-14-2021, 02:29 AM | #4 | |
Rep 3,860
I have been driving the Akrapovic Downpipe for about an year now, together with MPPSK - no problems at all! This is not where your CEL is coming from, unless it was installed badly (e.g. O2 sensors not put in properly, etc.) or unless you have a faulty converter for some reason, which is very unlikely.
1. The Akrapovic DP features a high-end HJS cat, same as in HJS's own DP, same as in AC Schnitzer's cat and used by many other reputable manufacturers. The DP is designed and guaranteed to maintain emissions, same as all of the above-mentioned. The DP also comes with an ECE approval! 2. What you have misinterpreted (I don't blame you, it is written ambiguously) is that it does not meet emission requirements for vehicles with OPF, hence MY 2019 and later. It is not compatible with those. Actually, the Akrapovic DP is top of the line. AA is lower quality (and lower price) in comparison.
09-14-2021, 08:37 AM | #5 |
Rep 112
According to the xph website...
"When installing the Akrapovič downpipe, remapping the ECU is mandatory in order to prevent potential “check engine light” warning signals." Its does say "potential" so dunno. Maybe Mike can elaborate on that. |
09-14-2021, 10:34 AM | #6 |
Rep 3,860
Simply read
https://f30.bimmerpost.com/forums/sh....php?t=1691853 The HJS cat is made to maintain emissions within factory limits.
09-14-2021, 02:16 PM | #8 |
Rep 205
Well my engine light hasn't come on yet today after it was cleared yesterday. And I did some pretty heavy driving to try to trigger something. I guess at this point I just wait and see if it flashes codes. I'll still get it up on a lift this weekend and make sure everything is tightened..
Figured I'd also add that the Akra DP + MPPSK is an incredible sound, and I'd recommend it to anyone. |
zen_f308.50 |
09-14-2021, 03:17 PM | #9 |
Rep 3,368
Something may have changed recently...I see no mention on the Akra website or their resellers, that the sport cat is compliant with emissions regulation. In fact some specify that a remap is required to avoid a CEL.
https://www.akrapovic.com/en/car/pro...00&yearId=5439 |
09-14-2021, 04:07 PM | #10 |
Rep 3,860
Nothing has changed! The same text was there in January 2020, when I ordered. I specifically asked the Akra dealer about it and got the following response as explanation:
"Bei OPF Modellen ist die downpipe natürlich nicht erlaubt. Nur bei nicht OPF Modellen komplett legal." English translation: "The downpipe is not allowed for OPF models. Completely legal only for non-OPF models" So, again, the misleading text is intended for MY 2019 and later, which feature an OPF (in Europe). The Akrapovic Dowpipe contains a HJS cat which is Euro 6 compliant. Same cat converter as in HJS's own B58 downpipe: https://burkhart-engineering.com/en/...rtkat-mit-ece/ (Note at the bottom again - "Not suitable for vehicles with OPF!")
09-14-2021, 07:47 PM | #11 | |
Rep 1,452
My CG DS-1 never had a "guarantee" but only produced a CEL once and never came back. Might be a similar story here.
09-15-2021, 02:11 PM | #12 | |
Rep 410
09-15-2021, 04:08 PM | #13 |
Rep 205
CEL hasn't come on again after the code was cleared 2 days ago. Might be in the clear with this, but I'm still gonna get it checked out cause I wouldn't expect to have any issues with akrapovic's. Not to mention, it seems like the sound is moody at higher revs where sometimes it almost sounds stock, but when it roars it roars and its awesome. Could just be the "randomness" of mppsk.
09-15-2021, 04:26 PM | #14 |
Rep 1,597
I went poking my nose on the Akrapovic website for the B58 downpipe and I did not find any data showing me they are using the HJS 300 which is EC exhaust compliant. Even so, this downpipe is priced as if it were using an HJS 300. If it were using the HJS 300, I seriously doubt a catalytic error would be thrown. Ireland is EC and nothing in the document shows me its even exhaust compliant in the EC. I would go with a Fabspeed unit explicitly using the quality HJS-300:
fabspeed com/bmw-m140i-m240i-340i-440i-540i-740i-hjs-euro-6-sport-catalytic-converter-downpipe/ |
09-16-2021, 02:29 AM | #15 | |
Rep 3,860
How much more proof does one need Another relevant thread: https://f30.bimmerpost.com/forums/sh....php?t=1506433
09-16-2021, 03:44 AM | #16 |
Rep 3,860
P.s. Here also a declaration by HJS, that the GB35 catalytic converter does not invalidate or negatively influence the exhaust gas or noise emissions, based on tests performed on M235i and 435i (Euro 6 vehicles).
More proof needed? I do find it silly though that such a reputable manufacturer (Akrapovic) does not take better care of their website and product description. The claimed weight of the DP is also wrong, as I have discovered. And I sent an email to Akrapovic to let them know and advise them to correct the data on their website... never got any response. And it is still wrong.
vcx81.50 |
09-16-2021, 10:15 AM | #17 | |
Rep 1,597
09-16-2021, 12:37 PM | #18 | |
Rep 3,860
(I am the author of the 2 photos) Also please see the lower engraved plate on the outside of the DP above in my previous post... More evidence needed? I'll just stand up and say - both my research and my own experience show that the Akrapovic DP is the absolute BEST catted DP one can get for B58! And probably the most expensive... Material selection, design, build-quality........ top-notch! Way better than the OEM, HJS's DP and various others. Does one really need it to be that top-notch (and expensive)? Probably not. But it is.
09-16-2021, 01:25 PM | #20 | |
Rep 3,860
whilst maintaining the factory warranty, all sound like a waste to you!?? Interesting. Oh well, to each their own.
09-16-2021, 01:58 PM | #21 | |
Rep 205
Edit: I'm still flashing stage 1 or 2 BM3 whenever I get confirmation my DME can still be bench unlocked with BMW's latest software update from a few months ago. |
Skyhigh1879.00 disintegrator66393.00 |
