05-08-2018, 06:43 AM | #947 |
Cheapskate
4447
Rep 4,993
Got my final alignment yesterday and they said I couldn't get less than -2.5 camber in the rear because of how low it was. Anyone else have the same issue? I really didn't want that much but maybe it is what it is. it was actually at -2.6 when I brought it in and the tech told me there was little to no room for positive adjustment as soon as he looked at the bushing. I just thought I saw some other people in the thread just as low that were able to get between -1.5 and -2.0.
cdwalls701.00 |
05-10-2018, 03:49 AM | #948 |
Rep 26
05-14-2018, 11:07 AM | #949 | |
Rep 296
D Unit
Bay Area, CA |
kern4174446.50 |
05-14-2018, 11:16 AM | #950 |
Rep 969
I was at -2.2 degrees with just KWs coils. We dialed it back to -1.6 degrees with no other aftermarket pieces. I'm on 19s vs your 18s though so technically my drop may no be as aggressive due to the bigger wheels, just a theory though.
kern4174446.50 |
05-14-2018, 01:27 PM | #951 | ||
Cheapskate
4447
Rep 4,993
After installing my supersports, I went to a shop and they brought the rears back to -1.7. When I dropped it on KWs and he took the baseline readings it went all the way to -2.5/-2.6, and I felt like I only dropped it maybe another 3/4"...I was really surprised that it gained almost another 1° of camber just from lowering it. The front only gained 0.5°. I know you said you didn't go all the way down though, and i actually removed the adjustment collars just to get it low enough for the fitment I wanted. I didn't think the overall size was that different between 19s and 18s but if a small amount of lowering changes the camber that much, it might just be that. |
cdwalls701.00 |
05-16-2018, 11:11 PM | #952 |
Rep 18
Can I post in here now?? Haha
dropped on H&R supersports yesterday! Linea Corse LC818 Front: 19x8.5 235/35/19 Rear 19x10 265/35/19
Follow my Build on IG! @F30Kris
05-17-2018, 07:33 AM | #953 |
A family of bimmers
2745
Rep 7,741
That looks great but you are definitely rubbing in the rear running the 10" wide rim and that offset
05-17-2018, 10:46 AM | #954 |
Rep 18
The offset of the rear is 37, very slight rubbing on some bumpy roads but I haven't gotten aligned yet, so I could always get more camber the rears just a bit
05-17-2018, 11:46 AM | #955 |
Rep 407
KTDCV is the exception to this post, but my biggest gripe with some wheel companies is that they make a 8.5 inch wide wheel and a 10 inch wide wheel. The idea is to buy a pair of both and have a staggered setup, but the concavity in each are usually noticeably different. Are there many companies that make a 9 inch wide wheels and 10 inch wide wheel of the same style? This is why I see the allure in 437m wheels.
05-17-2018, 12:40 PM | #956 | |
Cheapskate
4447
Rep 4,993
05-17-2018, 01:30 PM | #957 |
Rep 407
Coming from VW, I tend to lean towards Rotiform's cast line-up, but they only offer 19x8.5 and 19x10. I notice this with other aftermarket manufacturers like Enkei, niche, and AGwheels as well.
05-17-2018, 03:34 PM | #958 | |
Rep 421
Drives: 2017 F31 328dx
05-27-2018, 07:28 PM | #960 |
Rep 2,771
05-27-2018, 07:30 PM | #961 |
Rep 322
05-29-2018, 08:33 PM | #964 |
Rep 626
Volk te37sl double pressed black
F: 19x9.5 +21 235/35/19 -2.2 camber (BC racing camber plates) R: 19x10.5 +35 265/35/19 -3.3 camber (Megan rear camber kit MRS-BM-0311) Bc coilovers Zero rub-a-dub dub [IMG] [IMG] Last edited by GMV Auto; 05-29-2018 at 08:42 PM.. |
05-29-2018, 09:13 PM | #965 |
Rep 621
DaFish156.50 OEM+Alpine93.00 |
05-31-2018, 11:02 AM | #967 |
Rep 259
KendrickOak358.50 |
05-31-2018, 03:47 PM | #968 |
Rep 1,358
Drives: 981CS/428/is250/JLU Rubicon
Temecula's pretty big
There is a couple car shows this weekend in Temecula Cars and Coffee at the promenade mall on Saturday 7-10am Local Car Scene cars and coffee at Gosch Ford on Sunday 8-11am I'm gonna try to make both... Last edited by SoCal_NSX; 06-01-2018 at 12:22 AM.. |
aggressive, f30, low, slammed, stance |
