09-27-2021, 04:24 PM | #1 |
Rep 5,088
Does F30 ZF 8AT M/S return to D automatically after 5-10 seconds?
In F30 ZF 8AT M/S mode(without paddle shifter), once gear is shifted manually, does AT return to D automatically(after 5-10 seconds without manual shift), or gear shifter needs to be snapped right to get D again?
I remember the ZF behavior is the former one, but just want to confirm. |
09-27-2021, 04:53 PM | #2 |
Rep 7,597
If you manually shift a gear with the shifter to the right, it will automatically go back into automatic shifting "D" mode after a brief period of accelerating on throttle.
If the shifter is to the left in M/S mode and you manually shift a gear, it will go from S# to M# and it will never automatically go back to automatic shifting (S# nor D#), and you will hit rev limiter if you dont shift. You need to push it to the right to go back into D#, then back to the left to go into S# (both with automatic shifting) |
BrysonDM53.00 bavarianride1505.00 |
09-27-2021, 05:27 PM | #3 | |
Rep 5,088
09-27-2021, 05:33 PM | #4 |
Rep 15,858
Can you change manually with the shifter when to the right in D position? Surely you'll be going to neutral and .... attempting reverse.
09-27-2021, 05:37 PM | #5 |
Rep 7,597
No, can only manually change gears with paddles when the shifter is to the right, you can't use the shifter itself to do so as when its to the right the shifter is used to go between R / N / D as you noted, not change gears. This is for F3x at least.
09-27-2021, 05:40 PM | #6 |
Rep 15,858
Agree, it's paddles only, that's why I'm asking the question, when it is posted it can be done via the shifter in D.
09-27-2021, 05:46 PM | #7 |
Rep 6,234
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Just to add to what’s been said, with the shifter to the left you can use it to shift gears also, in addition to using the paddle shifters.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
09-27-2021, 06:35 PM | #8 |
Rep 5,088
09-29-2021, 05:33 PM | #9 |
Rep 4,876
It allows you to drive in "D", and then manually override for corners, passing, etc. and then back to "D" for regular operation.
I leave mine in "S", then using the paddles remains in "M" forever as others mentioned. |
