BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Need more comfort and less harsh (now b8+eibach)
      11-26-2016, 06:58 PM   #1
cola.p
Drives: BMW 530e G30
I have installed Bilstein b8 and Eibach spring (b12) for my F30 for 2 months. My tires are 18" Hankook v12 evo2 225/45/18. I feel very good except the harsh and feel uncomfortable when drive under 50mph. Drive at high speed is superb. Then I need more comfort and less harsh.
After a short research, I have ideas
  • b6 + ACS
  • b6 + Eibach -> I can use the existing spring
  • Koni fsd + Eibach -> I can use the existing spring
  • Koni yellow + Eibach -> I can use the existing spring
  • b8 + H&R -> I can use the existing shock but H&R spring i'm afraid it's too low for me. Eibach height is perfect for me.
Do you guys have any idea of upgrade? Pleas suggest.
Thank you very much.
      11-26-2016, 07:47 PM   #2
RedKloud
RedKloud's Avatar
753
Drives: BMW i4 M50
Decrease your tire pressures by 3-5 PSI.
      11-27-2016, 05:14 AM   #3
cola.p
Thank you. I've just tried decresing the tire pressure this morning. It help!! more comfort.
      11-27-2016, 10:24 AM   #4
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
235/50/17 will help your ride also. Decrease your wheel size with taller tires.
G05 - M Performance roof spoiler
      11-27-2016, 11:51 AM   #5
Cammy5
Drives: 2016 BMW 328i M Sport 6MT
I've ordered the Dinan Sport springs with the custom "ride and handling kit" (revised bumpstops) to pair with Bilstein B8s front and rear.
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune
*Evolution Racerwerks Competition Intercooler & Chargepipe
*M Performance Big Brake Kit
      11-27-2016, 12:23 PM   #6
RedKloud
RedKloud's Avatar
753
Drives: BMW i4 M50
You actually don't need the Dinan bump stops for B8s, they are already shorter than stock shocks.
      11-27-2016, 04:42 PM   #7
Polo08816
Drives: 2014 335i M Sport
  • b6 + ACS
Have you tried filling your tires with water instead of air? I've always felt that water beds are more comfortable than air mattresses. The same should apply here.
      11-29-2016, 11:15 AM   #8
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
Don't exceed 2,1bar front & 2,3bar rear with 225/45/18 all round in cold condition.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
      11-30-2016, 06:02 AM   #9
cola.p
After researched more, I think I will go for Dinan spring instead of changing shock.
      11-30-2016, 10:21 AM   #10
T4NZ4NIT3 335i
Drives: 2013 BMW 335i xdrive Sportline
Bilstein b4 are also an option
      11-30-2016, 10:44 AM   #11
RedKloud
RedKloud's Avatar
753
Drives: BMW i4 M50
I don't think changing springs only will improve comfort. B8 are much stiffer shocks than stock.
      11-30-2016, 12:51 PM   #12
M47
Drives: F30 328 xDrive
  • b6 + ACS
Have you consider getting coilovers?
      11-30-2016, 03:26 PM   #13
cailas
cailas's Avatar
Lithuania
31
Drives: BMW M5 F90 2018
  • b6 + ACS
Can you post some photos of your car?
E92 M3 Silver Frozen Edition 2012
F90 M5 2018
      11-30-2016, 06:41 PM   #14
cola.p
Here are my car pics.
      11-30-2016, 06:43 PM   #15
cola.p
I think it's too expensive. If it's the only choice, I may go for that.
      12-02-2016, 10:41 AM   #16
bheng89
Drives: 2012 328xi
I vote for Koni Yellow. I had them on a previous vehicle and was able to adjust the stiffness of the ride to some degree. Softer when driving around in a city with potholes and stiffer for the backroads.
Both adjustments were made on the top of the tubes; however, I am unsure where the adjustment knobs would be for the f30.
      12-02-2016, 10:52 AM   #17
cola.p
I can't find Dinan spring here in Thailand. Finally, I end up with D2 RS (coilovers). I've just bought and installed today. After 30-40km ride, it was much more comfort than B12 and no harsh but still stiff (a bit less than B12). Overall, I'm happy with this setup. Here the price of D2 set is cheaper than B12.
PS. the mechanic guy adjusted the damping to about 55% of the most stiff (it's adjustable).
      12-04-2016, 06:04 AM   #18
cdgatti
cdgatti's Avatar
254
Drives: e90 328i
Don't install aftermarket "Performance" suspension systems if you want a "Factory" comfort ride. BMW engineers work literally thousands of hours to make your ride fit the majority of customers where comfort with a little bit of sport is offered. You went to a system where Bilstein spent alot less time with people that are not BMW suspension experts, they have to be experts on all systems, to design a system that significantly improves the sport aspect of your car with as minimal as possibly comfort sacrifice. You fit into the category that cannot accept that little comfort sacrifice. From the E90 forums we have been having this conversation there for many years now. The only system that gains a little performance but gives up the least comfort is the KW Street Comfort coilover system. Either man up on the comfort side, try the KW system or go back to stock. Good Luck with your suspension quest - but remember it is very difficult to do better than what the BMW engineers have given you for all around comfort and performance.
OEM Black grill and Blackline tails - LCI halogens with Lux V2 coded as DRL - 3M Crystalline - BMS PBX - OEM Euro Airbox with K&N - Hardwired CTEK - Bilstein B6 w/OEM springs and SP perches - Conti DWS06 - HiFi-Helix DSP - JLAudio HD/XD-Morel - CD changer trim - AE optical out
      12-06-2016, 01:02 PM   #19
cailas
cailas's Avatar
Lithuania
31
Attachment 1534807
Attachment 1534808
Attachment 1534809
Thanks,is it rwd or xdrive?
F90 M5 2018
      12-07-2016, 02:07 AM   #20
cola.p
It's RWD.
bilstein, eibach, f30, h&r
