02-18-2019, 07:07 PM | #1 |
Rep 81
Successful M4 Spring Swap
I recently posted to determine if M4 springs were compatible with my F32 xdrive, and no one knew the answer. I just did the conversion and thought others could appreciate my findings.
The M4/M3 F82/F80 springs worked perfectly on my 428i xdrive. I just installed them with koni special active dampers without any fitment issues. I tried to install spacers to prevent any drop, but the ones I had did not fit. However, the drop was still modest at .5in, so I was not deterred. M4 springs are about 20% stiffer than stock F30/F32 and seem to offer the perfect setup for my daily driver. The ride is much better over smaller bumps and seams with the konis and the springs allow me to take larger bumps with a bit more speed without fear of scraping my bumper. Body roll is significantly reduced, and there is no harshness. Last edited by cu260r6; 02-21-2019 at 12:48 PM.. |
02-20-2019, 10:17 AM | #3 |
Rep 1,934
How would spacers affect the drop? They only move the tires outward and I would like to believe you don't want the fender putting it's weight on top of the tire. That would rip them out.
02-20-2019, 08:05 PM | #4 | |
Rep 81
02-20-2019, 08:07 PM | #5 |
Rep 81
Huh, didn't consider they could be beforehand actually. They certainly do not feel like they are when driving, and the appearance of the coils do not look similar to other progressive springs I've seen.
02-20-2019, 08:41 PM | #6 | |
Rep 3,537
02-21-2019, 04:00 AM | #7 | |
Rep 595
Is it less bouncy than stock? Whichever end bounces more while driving, the front or the rear? |
02-21-2019, 12:45 PM | #8 | |
Rep 81
It was a total guess which shocks would match these springs best, but I am very happy with the choice. The Koni FSD/Special Active are OEM for Lamborghini so I hoped they would work well with the M3/4 springs which are only about 20% stiffer. Before this, I had a 128i with Koni Str.t shocks and pretty stiff Megan lowering springs. There was not nearly enough dampening to keep up with the spring rate on that car. These Special Actives are a far better match. |
02-21-2019, 12:47 PM | #9 |
Rep 81
No, I don't think those would have worked since my understanding is they are for a dual spring setup on coilovers. I wish I could have found a perfect set of spacers, but I didn't have the time to find other parts. The car is still high enough for a daily driver living in the mountains in CO and dealing with winter driving.
02-21-2019, 01:43 PM | #10 | |
Rep 3,537
02-22-2019, 10:44 PM | #11 |
Rep 81
Ahh, gotcha now. I didn't use those because they reportedly stiffen the spring rate, and preventing that was a large reason I tried this setup instead of Eibach sports.
Did you notice a difference in ride with yours installed? |
04-23-2019, 07:01 PM | #12 |
Rep 5,506
Do you have any pictures of your set up?
Since your car is a 428i X Drive and it dropped your car 1/2 an inch - that means if someone runs the same set up on a RWD Sport suspension car (10mm lower than non Sport), it should lower the car 10mm or so?
Auto Detailing Enthusiast!
05-02-2019, 12:22 PM | #13 |
Car Hypochondriac
335
Rep 901
So I bet this would mean I could theoretically put f80 springs on my f30 right? I'm thinking about going with lowering springs with my adaptive suspension.
05-15-2019, 11:51 AM | #15 |
Rep 5,506
I have a set of F80 springs that I will be installing on my RWD 328i.
The F80 and F82 rear springs are different. The F80 has a lower cut rear fender. If you fit F82 rear springs on a F80, it will cause the rear to be much lower and vice versa.
05-15-2019, 12:12 PM | #16 | |
Rep 3,537
For your setup I'd want to try the manual transmission front spring first, since you have less weight in the front than an F80 (4cyl vs 6cyl engine), thus your ride height will probably be higher than the F80. Interestingly, the 4cyl engine weights + xDrive components (transfer case and axles) brings the front weight pretty close to that of an F80 from my calculations
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 05-15-2019 at 12:19 PM.. |
05-18-2019, 12:35 AM | #17 | |
Rep 5,506
Is there a spring code listing for F80 springs? Something that can convert the 2 letter spring code? I know the springs I have is from an F80 but I don't know which car it is from. Most likely it is a DCT car as most cars sold were DCT.
05-18-2019, 01:55 PM | #18 | |
Rep 3,537
07-14-2019, 10:25 AM | #19 |
Rep 10,249
Rethinking future suspension upgrade and looking for recommendations for my 2017 BMW 440i GC RWD with EDC suspension:
- Shocks: Bilstein B6 Damptronic shocks https://www.bimmerworld.com/Bilstein...2-F3X-RWD.html The description indicates " ... suitable for cars with stock coil springs". - Would M4 springs be compatible with my vehicle? My goal is to maintain OEM ride height as much as possible. |
07-14-2019, 02:26 PM | #20 | |
Rep 3,537
The M3/M4 base suspension springs are about 5-7% stiffer front and rear over your OE springs. Not a huge change. Are you looking for much stiffer?
cfm56d7b5876.00 |
07-14-2019, 02:38 PM | #21 |
Rep 10,249
@FaRKle!, thank for responding.
I find OEM springs to be "flat" - for the lack of a better word - in how they respond to road imperfections. I sense OEM springs are linear va progressive. Do you know by any chance if that's the case? |
07-14-2019, 02:41 PM | #22 |
Rep 3,537
The OE springs are indeed linear. The M2, and M3/4 competition pack rear springs are progressive though.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 07-14-2019 at 02:49 PM.. |
