11-09-2023, 07:08 AM | #1 |
Rep 11
F30 2017 LCI no longer read speed limit road signs!
Hi BMW fellas
Recently I did a region convert coding on my F30 LCI imported from Korea to Europe, Now the problem is that car doesn't recognize speed limit signs anymore! Prior to region and Nav. update Car was recognizing the signs and showed them on HUD correctly! Any help would be appreciated |
11-09-2023, 05:06 PM | #2 |
Rep 230
Drives: 2022 G20 330E
did you install EU maps? does car have 8TH from factory?
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
11-10-2023, 02:43 AM | #3 |
Rep 11
Yes Gerry updated the maps and did region change! yes it has 8TH since prior to updating the maps and doing region change it recognized speed limit signs. Gerry said that it could be that I could be in a blocked country for SLI! Though I don't know if there's logic behind that! Since kafas cameras read the signs as car drives and before it was working on the same country! |
11-10-2023, 06:31 AM | #4 |
Rep 591
If you are in Serbia... then with kafas2 you can forget on SLI. Kafas 4 working in this land
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
11-10-2023, 06:39 AM | #5 |
Rep 11
11-10-2023, 06:52 AM | #6 |
Rep 591
You can try fdl code in kafas 2
COUNTRY_SLINPI_MODE werte 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
11-10-2023, 07:07 AM | #7 | |
Rep 11
Since I am a newbie on E-Sys I am taking my time first to learn it before coding, even though I am an IT and have understanding of hardware flashing and software use! What E-Sys ver. you recommend to start? Right now I have E-Sys 3.27.1 with psdzdata 57.0.400 together with an ENET cable which I built myself. If you have E-Sys software with tutorials and psdzdata to get started I would appreciate if you share them! |
11-10-2023, 07:23 AM | #8 |
Rep 591
Esys alone is not enough launcher is needed for fdl coding. Esys 3.27 is to old so you will need to buy some newer launcher like esysultra or bimmerutility. I can code over remote for you no problem. you need just windows pc and enet cable
11-10-2023, 08:06 AM | #9 |
Rep 11
06-27-2024, 02:56 PM | #12 | |
Rep 3
My car has SLI from factory but it never worked, dealer does not care so was hoping to fix it myself. I only get the 3 dashes on the cluster/hud. Car has 5AS. |
06-27-2024, 03:22 PM | #13 | |
Rep 591
If you are in car right now we can try to code it
07-18-2024, 03:24 AM | #14 |
Rep 5
Hello Siki78 hope you are doing very well .
My name is abdo from Morocco , I have a 640xd 2014 with kafas camera , and I lost road signs reading after updating my map from Europe to North Africa , and I have read that you can fix it , could you please tel me more ? Really appreciate your help . Regards |
