BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 340i exhaust valve doesn't close
proTUNING Freaks
      07-06-2018, 12:11 AM   #1
Panda340i
Drives: 340i
On startup, the valve is closed for 1 min then it opens and remains opened regardless which driving mode I'm in
To check, I also kept the Rpm below 3k in comfort/eco pro and it still open
Is this behavior normal?
      07-06-2018, 02:01 AM   #2
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
If it is able to open and close, I'd imagine that it is normal behavior. Do you have any modifications or the MPPSK?
      07-06-2018, 02:58 AM   #3
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
You have two valves, are they both behaving the same? The valves have a +ve, -ve and a PWM based signal feed so it's unlikely it's wired incorrectly.
      07-06-2018, 09:04 AM   #4
EggoEspada
Drives: BMW 340i '18
Crazy. The same thing started to happen to me a couple weeks ago. If I recall correctly, this should be the correct behavior:
Open on startup; closes after a minute. Closed in Comfort and Eco; open in Sport/Sport+.
      07-06-2018, 09:31 AM   #5
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
330i here, so not quite the same but my valve is always open after cold start unless the vehicle is in motion.
I can hear it rattle when I'm driving around the underground garage as it opens/closes.
      07-06-2018, 10:19 AM   #6
Panda340i
Drives: 340i
Nope just the stock exhaust
I checked with another 340i but it's a 2018
The exhaust valve is closed for 1 min on the startup then it opens then after a while driving in comfort/eco pro it closes and when driving above 3k rpm or in sport/sport+ it opens.
Driving behind 2018 340i I can see the valve closing when decelerating and opening when accelerating.
      07-06-2018, 11:55 AM   #7
Ducati182
Drives: BMW 340i X
I tried to disconnect my exhaust valve on my 2018 340 but the wires on very tight and I dont want to break the clips.
Does anyone know which fuses to pull to disconnect the valves?
      07-06-2018, 12:21 PM   #8
Kevin_Trxn
Drives: '17 340i
Your car is brand new it won't break.
I ended up unbolting the 3 10mm holding the evalve on to get a good enough grip on the clip to unclip it
      07-06-2018, 12:25 PM   #9
Kevin_Trxn
Drives: '17 340i
As for OP,
the valve will close on cold start and open up once the car is warm
In comfort mode the valve will open when idled and open on harder acceleration. It will close on deceleration.
In sport mode there are certain times the valves close, i want to assume this is for better back pressure, but that's a WAG. Most of the time however the valve will remain open.
If you have a manual when you clutch in to shift gears the valve will close briefly until you reengage into gear. I know this because I had a very squeak valve for sometime....
      07-06-2018, 02:03 PM   #10
Panda340i
Drives: 340i
Originally Posted by Kevin_Trxn View Post
As for OP,
For me, it's aways in the open state except for the 1 min upon startup
I don't know what to do
Can updating a module on E sys fix the problem?
If so, which module to update?
      07-06-2018, 02:15 PM   #11
Beek
Beek's Avatar
Drives: Most folks crazy.
What do I have to do to get this "problem"? I'd love my valves to be closed on cold start and open at all other times.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter.
      07-06-2018, 02:30 PM   #12
Panda340i
Drives: 340i
Hahaha I know most people would love having their exhaust valve open at all time
But I like everything to work how they supposed to and check if this behavior is normal.
Beek707.00
      07-07-2018, 05:14 AM   #13
Panda340i
Drives: 340i
Solutions?
      07-08-2018, 10:43 AM   #14
Panda340i
Drives: 340i
Bump
      07-11-2018, 10:00 PM   #15
Panda340i
Drives: 340i
bump
      07-12-2018, 09:24 AM   #16
dorkiedoode
dorkiedoode's Avatar
Drives: 2018 BMW 340i M Performance
wow, here you have me, who disconnect the fuses so I can have my valve open all the time.
      07-14-2018, 10:14 AM   #17
B58
B58's Avatar
558
Drives: 922 Turbo
Just disconnect the pigtail and get this: https://www.ecstuning.com/b-genuine-...r/18302411427/
2024 X3 M40i
2014 BMW M5
Beek707.00
      07-14-2018, 04:30 PM   #18
Beek
Beek's Avatar
Thanks but with these installed my exhaust valves would be open during cold start. I would be fine with that except I'm in a condo with underground parking and the MPPSK cold start is already pretty loud.
      07-14-2018, 09:09 PM   #19
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
Is there a second valve on the 340? I thought there was only one right there on the left muffler.
I too would prefer it to be open all the time except closed when I am near the house to not bother the neighbors... I'd like to tap into that wiring and take control of it, but not worth the effort
      07-14-2018, 11:17 PM   #20
Beek
Beek's Avatar
I have MPPSK which does have a second valve, stock exhaust is single valve.
      07-14-2018, 11:34 PM   #21
B58 parts
B58 parts's Avatar
Right .. thanks
I unplugged the thing and taped it for now .. I'm starting to want for a proper exhaust, but .. I would like to be able to mute it when leaving for work. The WRX with exhaust was beyond obnoxious at 0430
Beek707.00
      07-14-2018, 11:42 PM   #22
B58
B58's Avatar
558
Drives: 922 Turbo
Right .. thanks
You can try this:
https://www.ecstuning.com/b-cg-preci.../0004vsc1~cgp/
