02-22-2020, 04:34 PM | #1 |
Rep 10
Loosen "plastic part" in rear suspension? Can i use 3M tape to put it back?
Today I find out both of my rear wheel shocks got this part loose. (Photo attached).I try to use my bare hands to pry it up back to the strut mounts but it still falling down. It seems there are no clips or some kinds of things to hold this "spongy" thing back to the mount? Can I just use some 3M tape or glue to make sure it stabilized inside the strut mount?
I really need your advice now since its winter in Canada and those salt would eat the shocks I believe. 2014 BMW 328Xi Thank you all. |
02-22-2020, 06:05 PM | #2 |
Rep 3,539
That's your bump stop. Not an issue if it's not captured by the top mount, but feel free to shim the outer edge of it with duct tape or something so it sticks in there better.
02-24-2020, 09:44 AM | #3 |
Rep 1,827
It sort of seems like the rubber has oxidized and shrunk, making it loose. Replacement bumpstops are relatively inexpensive but it would be a pain to take apart your rear shock assembly just to replace them. Not difficult at all, but a decent amount of work just for the bumpstops, however, that'd be my recommendation. I think the official name that BMW calls them are guard tube rear auxiliary dampers.
As FaRKle! suggested, some sort of adhesive strip applied around the top of the rubber to increase the radius enough to re-seat the friction fit into the upper shock mount should do the trick. Try to clean it out beforehand if you can. You probably don't want a bunch of salt and dirt permanently wedged in there.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
02-24-2020, 01:00 PM | #4 |
Rep 541
My guess is its contracted in the cold and lost the grip in the top plate. Have you tried pushing it back up and twisting at the same time to see if it stays in place?
If not, I would put a bit of silicone sealant on, push it in place and leave to dry |
