04-19-2016, 03:13 AM | #1 |
Rep 36
435i cats getting cherry red?!!!!
Hey guys I think I may have a problem. When I drive spirited in sport plus on mountain roads I noticed a smell and when I popped my hood I noticed what you see in the following pictures. I have noticed the cats turning red on two occasions.
I would like to state that BMW changed the Turbo due to whistle (defect) and diverter valve at 1200 miles and the car now has 3000 miles. Is it normal for the cats to get this Hotttt? Outside temp = 60 degrees at time of drive. |
04-19-2016, 09:05 AM | #2 |
Rep 333
I'd get that checked...I don't believe things are supposed to glow...seems like something is blocked
2018 F80 M3 6MT (current)
2014 F31 328i Touring (sold) 2008 E92 M3 6MT (sold) 2011 E90 335xi (lease up) |
04-19-2016, 09:49 AM | #3 | |
Rep 3,990
04-19-2016, 12:26 PM | #7 |
Rep 962
The only thing that I've ever seen glow on these cars is the turbo, and that's after some serious track driving...at night. The cats do get very hot but I've never seen them glow like that.
04-19-2016, 02:54 PM | #8 |
Rep 4,728
I think you should touch them next time to see how hot they are. ;-)
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-19-2016, 03:35 PM | #9 |
Rep 1,584
A friend of mine, with a non-BMW, had this same issue. It was caused by excess fuel getting to the cats. Since the cats are designed to keep emissions down, the excess fuel was being burned in the cats. In his case part of the insides of the cats melted and restricted the cats air flow.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
04-19-2016, 03:49 PM | #10 |
Rep 711
Drives: 22 TR X3MC
If excess fuel is going to the cats, get a catless downpipe and you'll be shoot flames!!!
2022 X3M Comp
2013 335i xDrive (Sold) |
04-19-2016, 05:22 PM | #11 |
Rep 194,563
Another reason to go catless
Get that checked OP
04-22-2016, 09:40 PM | #13 |
Rep 36
So this morning I took in my car to get the oil toped off since it was showing low oil "add 1 quart". while I was there I showed two service advisors these photos of my catalytic converter red hot and they said it was normal. one said "Iv seen 2series models do this as well".
Im still not sure why it needs to get that hot? Also could my engine be needing a quart of oil at 3k miles because of this possible issue? |
04-22-2016, 10:05 PM | #14 |
Rep 5,776
+1...just take that bitch off and pop a tune as well. Problem solved and win.
Last car: 2011 335i Msport. JB4. Vrsf CP |
04-22-2016, 10:25 PM | #15 | |
National Championship #17 and Counting!
791
Rep 1,508
You mention having a spirited drive; cool. But how long (miles)? We talking switchbacks with rapid acceleration, braking, repeat? What was the outside temp? Hot day, cool, chilly? What were your number of runs? Length of sustained heavy driving. Mountain drives can simulate track conditions. Tail of the Dragon really wears on a car and the driver for example. Also, your car is new and under its original oil change, so hard driving should be minimal; you're still in break in period. If this happened under normal load or highway driving conditions under 5 hours, I'd be more concerned. May still be an issue, but we could use more data from you. Hope it's nothing.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
04-22-2016, 11:35 PM | #16 | |
Rep 36
duration: 25min....cooldown driving at least 5 times for about 3min each outside temp: 60 degrees F... cool night length of heavy driving: 10-12min on straights rapid acceleration and breaking. I did give the car cooling time with normal driving about 5 times in the 14 miles. I don't think 10-12 min of aggressive driving on a BMW should cause catalytic converter to turn cherry red like this. Perhaps this car isn't designed to sustain aggressive driving. |
04-23-2016, 04:49 AM | #17 | |
Rep 2,118
04-23-2016, 06:04 AM | #18 | ||
791
Rep 1,508
Not sure if warning bells would go off with this until something failed since it wouldn't run the car hot usually. If you take it back to the service department, they'd need to recreate the condition which would mean one hell of a road test; not sure you'd want that. The fact that you smelled a burning is a little concerning, but my car, which is at about 10K miles, also had a few early smells from under the hood. Happens often during break in, but should settle out after 5K and a first oil change. I'm due for my second change. Car is 1 year old last month. Just keep an eye on it, but it doesn't mean drive it softly. Your car is a bad girl and she likes to be rode hard and put away wet! Keep pushing her to speed up break in. As long as you don't have any mods (forgot to ask in last post), it's nothing to worry about because you are under warranty, so have some fun.
04-23-2016, 08:28 AM | #19 | |
Rep 598
Cats can only glow in the presence of fuel. The more fuel that reaches the cats, the hotter they will get and the more red the glow. Typically, fuel is burned in the combustion chamber. What is left over (unburned) during combustion, goes thru the headers, to the cat, and out the exhaust. Bad coils, plugs, and/or ignition timing can reduce the efficiency of the combustion process. This leaves excess unburned fuel causing red hot cats. Whenever the dealer tells you "it's normal", you need to verify that it is indeed normal. I have never seen a properly running engine light its cats up cherry red like that. If that lasts too long the cats will have a reduced service life. Furthermore, depending on what ius causing the unburned fuel, there could be other problems brewing too. Now this may very well be normal but I would not accept that until I had seen a similarly specd car behave the same way. Maybe run a loaner car through the same route to see if happens to it too. Have any friends with N55 engines? It's time to compare and contrast. Maybe some N55 owners here on the forum can check how theirs look after some brisk runs at night?? |
