03-24-2019, 11:24 AM | #1 |
Rep 351
Exhaust tips - Secure fitment
Been in two minds about either Carbon (which everyone has..) or burnt titanium style. I really like both.
Digging a little deeper I found these, obviously not OEM fitment but has a clamp tightened with a bolt. Has anyone had experience on any car with this style of exhaust tip? I’m more concerned it falls off on a random A road or motorway drive causing problems. Converse of that is OEM is spring clips only, but as they’ve been on for so long don’t seem to budge unless hit with a hammer/mallet. Outlet is even 4”, the next largest alternative are the BMS 3.5”. I’ve read most couldn’t fit BMS onto a MPE, but others have so at this price I’m happy to take the risk NB: I would want these to initially fit on standard dual exit exhaust, then a MPE which I’ll either sell the tips from, or purchase without any. https://ibb.co/8MKnVnY |
03-25-2019, 03:11 PM | #4 |
Rep 468
I got some carbon ones "Akrapovic" 63-89mm from Alixpress for around 20 aside. Be aware 100mm outer diameter will not fit the bumper cuts.
63mm is the closest fit, as the OE external diameter is 61mm. There is a bit of play but the clamps are strong enough to hold them well. What I did with mine, as the tips are slitted, they compress when the clamp is tightened, I slightly cut the slits to make them even wider to give them more room for a better compression when clamped. The quality of these exhaust tips is unreal. Titanium steel with carbon finish and a real quality clamp. https://www.aliexpress.com/item/Inle...4-042871f42a5c |
APJ245.00 |
03-26-2019, 06:44 PM | #5 | |
Rep 351
Managed to find 89mm outer diameter, I’m just dissapointed that 4” (100mm) wouldn’t fit based on your comment. I really like the look of a pair of exhaust tips I saw on a RS and they were massive, maybe 4.5” Is it the added carbon sleeve at 4” that makes it too thick to fit the diffuser cuts? |
03-27-2019, 04:42 PM | #6 |
Rep 211
I had 101mm (4") tips on my GC and they fitted fine
03-28-2019, 03:46 PM | #7 | |
Rep 724
04-01-2019, 11:09 AM | #8 |
Rep 724
Think it depends on where you have obtained the rear diffuser from , mine came with the car, but its not a genuine part, i've jut ordered some 63/89's tailpipes to go on mine, but i have noticed even with those that a little bit of trimming will be required
04-01-2019, 12:24 PM | #9 |
Rep 187
Drives: 330d f31 msport
I don't think you should worry about them coming off .as I have a pair of akropovic cans on my bike , fitted with similar style clamps .I be done 15,000 miles with no probs at all .
04-01-2019, 12:28 PM | #10 | |
Rep 724
Though the hardest part will be to get the old tailpipes off, but we will get there eventually, even if i have to take them to my mate's garage. |
04-03-2019, 07:07 AM | #13 |
Rep 468
Nice one. Just hope you ordered 2 pieces as the photo is misleading in showing 2 pipes but you receive only 1 as I have discovered.( small print lol) So another 3 weeks of waiting for another pipe.
The OE tail pipes come of very easy, jut get some wood behind it and tap it gently with a hammer and they literately just slide off. Good Luck |
APJ245.00 |
04-03-2019, 10:53 AM | #14 | |
Rep 724
04-25-2019, 02:08 PM | #16 |
Rep 724
Can't believe it, just waited a month for the two tailpipes to arrive and guess what they have sent me 68/73 by 89 tailpipes, so even fully clamped they still slide off . But now realised another problem that the 89 width will not fit side by side off my backbox, worked it out to be around 80 for each tailpipe for them to fit properly, ah well back to the drawing, but one thing i'm not doing is waiting another month for any replacements to arrive
04-25-2019, 03:31 PM | #17 | |
Rep 468
Anyways, mine arrived and all fitted. So far so good. |
04-25-2019, 06:57 PM | #18 | |
Rep 724
Probably explains why the 89's wont fit side by side |
04-26-2019, 02:59 AM | #19 | |
Rep 388
A touch more expensive and I can't vouch for quality but I'd imagine they'll fit. |
04-28-2019, 01:50 PM | #20 | |
Rep 724
04-29-2019, 02:14 PM | #21 |
Rep 388
Tags |
435 coupe, exhaust, exhaust 435i, exhaust tips |
