04-27-2016, 04:47 AM | #1101 | |
Rep 2
One question: You said you generated the 1B File for your F30, but in the SWID software you checked E-Series. Is that right or do you actually have an E-Series BMW? In both cases: What were your network settings in windows? (e.g. in adapter settings did it show you were connected to a network? was it a private 'home' network or anything else? In what order did you set it up to achieve connectivity: Plug in cable -> turn on engine -> turn on LAN?) Many thanks in advance for your help and greetings from Germany! |
FlorinQCK-2.50 |
04-27-2016, 04:25 PM | #1102 |
Rep 3
Hi Guys, I have the 1B file for my 2013 F30 CIC and I used base64 to convert it. When using CIC/NBT FSC code generator I get the 20 character code followed by two vertical bars that look like ||
The code does not work for Premium NA 2016 maps, wondering if I have a corrupted utility or lookup.xml? |
FlorinQCK-2.50 |
04-28-2016, 06:08 AM | #1103 |
Rep 11
Do I need to edit any files before the software works? SWID and Esys both don't seem to be able to connect to the car. I bought the ENET cable and I'm running a 32bit windows XP in VMWare ( mac osx). In OSX I see the ethernet cable has a self assigned IP.
FlorinQCK-2.50 |
04-29-2016, 01:36 AM | #1106 |
Rep 11
I've made progress: was an misconfiguration in VMware.
Used Esys and was able to Store FSC. Afterwards I opened DOS and used 'nbt.exe xxxx.fsc 0xA8 0x27' I got a code, but however the car says it's wrong.. Updated yesterday, (no code asked), but when starting the car this morning it asked for a code. I noticed there was a lookup.xml file in that folder as well( where nbt.exe is). However I did not change anything in that file. Do I need to make changes there too beforehand? Is 0xA8 and 0x27 correct? For Europe Next 2016-2 |
FlorinQCK-2.50 |
04-29-2016, 04:00 PM | #1109 | |
Rep 17
There are 3 different IP addresses assigned to clients by CIC (that I know): 169.254.199.98 (mask 255.255.255.0, gateway and ftp server address 169.254.199.99) 10.250.89.3 (mask 255.0.0.0, gateway and ftp server address 10.250.89.2) 160.48.199.98 (mask 255.255.255.128, gateway and ftp server address 160.48.199.99) If none of those IP addresses work, then you need to set your PC to DHCP mode using TFTPD64. Then CIC will get IP address from your PC's DHCP. You can check which address CIC got using Tool32 (when you are connected to it with DCAN, and ENET is on USB), load CICR.PRG and start the Job "status_get_ipconfig". For example set your PC to a static IP address (e.g. 192.168.10.10/255.255.255.0) Launch TFTPD64 and bind it to your wired adapter. Under the options tab, set the start address to 192.168.10.20 with at least 2 for the pool size. Reboot your CIC by pressing the VOLUME button for about 30 seconds. The CIC will now be accessible at the address you specified, 192.168.10.20 in this case. Hope this helps, if it doesn't then your CIC is most probably not wired to OBD and then your only chance is USB-Enet adapter with ASIX chipset. |
FlorinQCK-2.50 |
05-02-2016, 12:23 PM | #1110 |
Rep 501
Ok, so I downloaded the FSC generator and 2016-2 NA NEXT maps. Put the unarchived map data on a flash drive, and inserted it just to try and see if I could upgrade without the new code. It gave me a message saying something similar to 'The navigation data in the car is incomplete, please see your dealer'
I'm assuming it was referring to the 2016-2 map data on the flash drive, not what is installed in the car currently (112113.2.121 - Next 2013 - NBT_A12201I) Have any of you seen this before? Thanks Brad
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
FlorinQCK-2.50 |
05-04-2016, 09:43 PM | #1112 |
Rep 1
Hello friends, I managed to generate the file by ESYS and generate the FSC code for my car, always but with wrong codes.
My map is SOUTH AMERICA NEXT 2016 00AF 0004. I tried the BMW-FSC-NBT generator by ms-dos and windows, and the FSC GENERATOR by windows. All generated codes, but all the wrong codes. Now, after a few failed attempts, my NAV does not start, and is asking for code, even without me asking to upgrade. I can no longer use my NAV, I press the NAV button and immediately idrive asks the code, like a new car at the dealership. I'll have to buy a new code FSC? Is possible to generate the right FSC code maps SOUTH AMERICA? Thank you very much |
FlorinQCK-2.50 |
05-08-2016, 10:55 AM | #1115 |
Rep 15
@shawnsheridan I am trying to update my F30 navi with europe move 2016-2 but I don't know which parameters set in the batch file of fsc generator. I tried with 0x88 for the navi version and 0x09 for the year but didn't work. Any suggestions? Thank you very much
FlorinQCK-2.50 |
05-08-2016, 11:00 AM | #1116 | |
Rep 40,783
FlorinQCK-2.50 |
05-10-2016, 11:51 AM | #1119 |
Rep 2
Hi Shawn,
I have a BMW F10 (2011) with CIC and Europe premium maps. Have downloaded 2016-2 West europe premium maps. I have ESYS so will generate IB/1D file as required. Could you pm info on how i can get access to fsc code generator and any other info i would need to generated the code. Many Thanks. PS. Used various posts from yourself and others to update my auto box settings from 205 to 2TB with ESYS. Very pleased with that. Thanks. |
FlorinQCK-2.50 |
05-10-2016, 12:06 PM | #1120 | |
Rep 40,783
FlorinQCK-2.50 |
05-16-2016, 10:47 AM | #1122 | |
Rep 3
I have the same conditions as you. Have you solved your problem? (per PM) Many thanks Last edited by zoomm; 05-16-2016 at 11:08 AM.. |
FlorinQCK-2.50 |
