08-26-2016, 07:09 AM | #1211 |
Rep 40,789
There is no "conversion" between Europe and North America. Just Generate the Europe Map FSC Code you need and use it.
FlorinQCK-2.50 |
08-26-2016, 07:19 AM | #1212 | |
BMW Specialist
Rep 7
here is egzample: http://www.bmwfsc.ca/product/bmw-mini-fsc-code/ One time code is 35 usd and switching is 55 usd... so wondering if this is the same code as one for 35 just marketing trick... and there is explanation for this: Install country A map on country B car, then you need this code. Example: Install EUROPE Map on a United States car. Please leave me message what's map version you want to switch when you place order. Last edited by xxxyyyzzz; 08-26-2016 at 07:24 AM.. |
FlorinQCK-2.50 |
08-26-2016, 09:46 AM | #1213 | |
Rep 40,789
FlorinQCK-2.50 |
08-30-2016, 10:28 AM | #1215 | |
Rep 40,789
Europe NEXT 2016-2 = 00A90027
FlorinQCK-2.50 |
08-30-2016, 12:39 PM | #1216 | |
Rep 9
You're the best. I just remembered after reading your answer that I could take a look in the Info_Map.imp file You think it is worth a shot to try to use FF to generate a lifetime fsc? I also read in someones post that lifetime Fsc's don't work anymore, any news on that? |
FlorinQCK-2.50 |
08-30-2016, 12:48 PM | #1217 | |
Rep 40,789
FlorinQCK-2.50 |
09-02-2016, 03:17 PM | #1218 |
Rep 271
sorry I feel like an idiot, what is the enet cable used for?
I have a regular usb cable that I used for coding different modules. Can anyone link me to a good enet cable to buy? I have a dlink usb to ethernet adapter that I read on these forums works for connecting to CIC using the glove box usb port. Would this work? |
FlorinQCK-2.50 |
09-02-2016, 05:04 PM | #1219 | |
Rep 40,789
FlorinQCK-2.50 |
09-11-2016, 05:38 PM | #1220 | |
Rep 9
So, switched back to E-SYS - Tried from the main computer but Java 7 simply didn't work on Win10 x64 and E-SYS doesn't work with Java 8. Next attempt is from the VB Win7 with E-SYS but getting a connection error. Tried both "connection via gateway url" (tcp://127.0.0.1:6801) and "connection via ICOM/Ethernet" (tcp://127.0.0.1:50160) but both say "connection check failed, however, function using ODX-Data can be used". I had selected F025 for my F25 (not direct). If I proceed to FSC Extended, and diagnostic address 0x63, "identity" button doesn't work. Also all subsequent operations fail with connection error so it's clear the connection was never established with car. The IP address does show 169.254.xx.xx so it can see the car once the ENET cable is attached. Thanks for any pointer. |
FlorinQCK-2.50 |
09-11-2016, 06:37 PM | #1221 | |
Rep 40,789
FlorinQCK-2.50 |
09-17-2016, 03:51 PM | #1224 | |
Rep 32
Drives: 2016 BMW 535i Xdrive
What would the SWID_FscShort be for "NORTH AMERICA Premium 2017-1"? Trying to generate fsc code for CIC unit. |
FlorinQCK-2.50 |
09-17-2016, 03:52 PM | #1225 |
Rep 40,789
002D0029
FlorinQCK-2.50 |
09-24-2016, 03:46 PM | #1229 |
Rep 230
TROJAN Virus
https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q, BMW_CIC_NBT_FSC_Generator.rar I attempted to download BMW_CIC_NBT_FSC_Generator.rar and my Trend Micro immediately quarantined it with report of TROJAN virus. fsc.exe in CIC directory is infected by TROJAN_GE virus. Any reliable source? I have CIC need 2017-1 North America... Thanks Last edited by F30ed; 09-24-2016 at 05:56 PM.. |
FlorinQCK-2.50 |
10-03-2016, 06:58 AM | #1232 |
Rep 40,789
0x88 0x29
