08-09-2021, 10:32 PM | #8471 | |||
Rep 412
2015 m235i 6mt
08-09-2021, 10:47 PM | #8472 | |
Rep 36
And for the disconnection problems I was having, it's the USB mount I installed, confirmed. Will try with a replacement. |
08-10-2021, 12:27 AM | #8473 |
Rep 376
does the andream CIC revision B support being able to play BT audio through the combox after some coding changes (thereby eliminating the need to connecet the aux cable from the MMI unit to the armrest aux port)?
from my understanding other boxes have the ability to do this after making some coding changes below: 3000 HMI CDMM_AUX_HU aktiv 3003 TELEFON_TELEMATIK_ONLINE CDMM_USB_AUDIO_SINGLE nicht_aktiv CDMM_USB_AUDIO_DOUBLE_0B nicht_aktiv
2010 E92 Monaco Blue 335i / Gray Dakota Leather / Steptronic / Sport / Premium / Navi / L7 / 18" Performance Wheels / HPFP fail @ 8400 miles (replaced with #933 pump) // MODS: Mishimoto OCC | VRSF CP + Turbosmart Dual Port BOV | RB PCV Valve // Maintenance: Walnut Blast @ 56k | Spark Plugs Replaced @ 56k | Addons: BN2000 Combox // Andream Carplay // Rear Camera // Spark Plugs (.022 gap) and Coils Replaced 73.1k
2019 G01 Carbon Black X3 M40i / Premium / Driver Assist / 21" on Bridgestone Alienza RFT |
08-10-2021, 01:50 AM | #8474 |
Rep 1
Hi all,
I just bought a Andream Box with label CICHL and I just cannot get it to work in my F11 5-series from 03-2011. I have the CIC system still and we tried 2 different modules, and 2 different cable sets. So that (most probably) rules out any defective items from Andream. We tried all 3 connection methods (cable route & dipswitches) as displayed in the attachment, and no luck. When we try method #3 (which is supposedly for F10/F11 with CIC), for the idrive wiring harness, if we only connect the large connector, the iDrive controller doesn't work. As soon as we also connect the 2 smaller (4 pins I believe) connectors together, the iDrive controller works. The mechanic working with me told me that the smaller connectors are not supposed to be linked, as they are intended for another iDrive controller type. Maybe something is wrong in that aspect. What does work: - CIC works as it's supposed to - When connecting iPhone via USB connector, it finds the Carplay functionality Just when long-pressing the menu button or the backbutton has no result (also no 'clicking' sound comes from the MMI unit) Do you guys have any idea in what direction I must look to solve this issue? Last edited by Elimination; 08-10-2021 at 04:47 AM.. |
08-10-2021, 07:52 AM | #8475 |
Rep 25
FYI. Still pending issue but if it happens to you...
My device is from Aliexpress, unknown HW, 3.1.2.gpe.b, MCU 20.22 something. It was installed in April and working perfectly with my iphone. I came back from vacation. The car have been sitting in the driveway for two weeks. Battery was old. Anyway, I cranked the engine and drove for 100m. Car was still on the NBT screen and the MMI was booting. It "tried" to switch to carplay. Suddenly, NBT screen went black and turned off (black to really black). The NBT started to reboot every 30 seconds (dvd drive clicking). I tried to unplug the battery to reset it. I even changed the battery because it was old and it can cause gremlins to appear. It solved nothing. I've plugged in Ista and E-Sys.. Kombi, NBT and AMP were showing red. It could not communicate with them. Not a good feeling. I've disassembled again the dash. Pulled the NBT, it was still extremely hot. I've removed the quadlock t-harness, plugged back the original cable back in with the fiber optic cables. I did not even move back the screen cable. The system is back alive. So my next step, it is remove the glove box and unplug the MMI box. It smells like something is shorting the bus. It will check if the harness was damaged or something obvious blew up in the box, a cap? Don't hesitate to share your ideas... |
08-10-2021, 11:19 AM | #8476 | |
Rep 499
Wireless AA on Android 10 means developer mode Then Dev settings and choose Wireless projection Video focus Works OK on a 3 year old Oneplus 9 |
08-10-2021, 07:30 PM | #8477 | |
Rep 36
I've managed to enable that on the phone. What's the carplay wifi password? And I can't remember how could you give data to the phone, as the wifi you connect to, it's the MMI one and that won't provide internet connection. |
08-11-2021, 12:14 AM | #8478 | ||
Rep 341
Technically there isn't a WiFi password. You have to set MMI device to link Bluetooth AND WiFi then it will just connect. You might need to connect by wire, the first time if your phone isn't a late Samsung or Google pixel phone, I remember reading something about that before, unfortunately I can't recall exactly where I read it. |
08-11-2021, 04:35 AM | #8479 |
Rep 71
What phones are compatible with Android Auto wireless?
Wireless Android Auto is supported on any phone running Android 11 or newer with 5GHz Wi-Fi built-in. ... Samsung: Galaxy S8/S8+ Galaxy S9/S9+ Galaxy S10/S10+ Galaxy Note 8. Galaxy Note 9. Galaxy Note 10. And now it's any phone with android 11 and 5GHz wifi support |
08-12-2021, 12:00 PM | #8480 |
Rep 14
Hello,
Just quick thank you for this thread, I read all the pages and ended up ordered this one : https://www.aliexpress.com/item/4000...17bf4c4dCThlUh SDK:25.0.0.7.0.0.2.0 CUST: B2_V1.5.9 MCU: 21.6.7.116 HW Version: BMW_NBT2_1_G I have a Mini Cooper F60 2017 no nav, no touch, 6.5 screen and everything works great! I was scared at first because it came with the AUX cable and I didn't understand because AUX, from what I understood here is only used for CIC, so I didn't plug it and I still have the AUX Front and everything works great still. From the version number do you know if there is an update for this model ? THank you |
08-12-2021, 12:07 PM | #8481 |
Rep 1
I could not read all the posts on this topic so apologies if this has been discussed already, but I wanted to give you an update on Bavarian Automotive. I bought my NBT box earlier this year. Seller has been responsive in giving info before purchase and as I received the box without instructions he send me the pdf in a matter of minutes. I am now in contact with him to sort out a "problem" (see below) and again they are on it.
Only note - the supplier states in the instructions that any unauthorised software update will void the warranty. Said that - I can recommend this company. For the sake of understanding the software version, please find the screenshot of the SW as out of the box (purchase Mar21) I think the software is pretty old. Has the reverse camera menu, but audio is all over the place in the main menu. the "problem" I tried to search in the discussion, despite finding someone mentioning a "funny car image" I could not find any info. I have installed a reverse camera, everything works but the radar shows a mercedes SLK Any info on how to change the image into a mini F56? Given the warrenty clause, I have addressed this issue to the seller too and I am expecting him to provide direction (likely to be a SW update), unless you have other tips. Last edited by birillo_79; 08-12-2021 at 12:15 PM.. |
08-12-2021, 12:25 PM | #8482 |
Rep 3
Please help. Wife acceptance factor at all time low.
Currently, the following problems exist; 1. When getting in the vehicle, the MMI auto displays Waze. But not able to access Waze on phone. 2. Phone audio is not good. Using Android phone ( Pixel 4G + 3XL). BMW i3 with standard (basic) sound system. Question: what are the settings that I should have on my phone and MMI to achieve the best result; Bluetooth ? WiFi ? I think that I would prefer to simply use Autolink exclusively, if that makes life simpler. Please advise me and help save my marriage. |
08-12-2021, 05:10 PM | #8483 | |
Rep 14
for the music go to settings and disable loudness and then make all your settings on the equalizer and on the stock car menu |
08-12-2021, 11:05 PM | #8484 |
Rep 625
So I'm hoping someone can help with two minor issues I'm having. I have the Andream unit for the CIC system.
1. When I get into my car and start it up either one of two things will happen. The CIC system will boot up normally and wireless Carplay will be connected and the Andream MMI will automatically come up and display carplay. But there are times where the CIC system will boot and just stay stuck on the BMW GUI. And my iDrive controller will actually not work either. As soon I long press the menu button the iDrive works again. And if I long press again it will go right into Andream and Wireless Carplay. So I know my phone was connected already during this time I'm just wondering why there are times the system is stuck on BMW GUI and I need to long press the menu button to get iDrive back and once more to get into Andream. 2. And I'm not sure if this is an Andream issue or something else but there are times where I'll go into Pandora and there is no audio. If I switch to a different audio app like spotify or iheart radio it will play audio fine. If I switch back to Pandora audio is perfectly fine. Hope someone can help! |
08-12-2021, 11:16 PM | #8485 | |
Rep 20
Based on the CUST version you have an Andream B2-Version. Your software seems to be newer than that of the first page, but I recall seeing a link to updates a few pages back, but think it was to the same version you currently have. I know the first page links needs some maintenance again, there are a few newer links that are not on there yet. Firefly1337 has probably been a bit busy. |
08-13-2021, 07:19 AM | #8486 | |
Rep 14
08-13-2021, 08:03 AM | #8487 |
Rep 625
Well yes I have tried many software versions and they all result in the same behavior.
I'm just wondering if it's "normal". Since both issues aren't "huge" issues I know I can live with it. The biggest thing for me was stability and it works really well without any crashes or any random reboots. It just takes an extra button press when I first get into my car to get to Andream. I just want to know from anyone else if they experience the same? I'm wondering if it has something to do with when the BMW displays the iDrive notification vs. when it doesn't. |
08-13-2021, 08:54 AM | #8488 | |
Rep 14
I Noticed one problem tho, when I back up if I stop the car the screen stay on the camera and when I press menu it goes back to the defaut screen and no way to get back into the MMI without turning the engine off, but if I backup and then go forward for a bit the screen revert back to the MMi by itself. |
08-13-2021, 09:27 AM | #8489 | |
Rep 14
Hello, Do you have a diagram for that ? I would like to do the same thank you! |
08-13-2021, 10:00 AM | #8490 |
Rep 9
So I have the andream cic version b. I tried updating the software and mcu. The software updated fine to 1.5.5. But once i updated the mcu to 21.1.28.10, It auto starts android auto fine. But the thing is i cant control anything except scrolling with the wheel. Holding menu button doesnt bring me back to cic. So i disconnect my phone from android auto and it goes back to cic but I can only scroll, cant click, cant press any of the shortcuts on the controller.
What happened? any help I would appreciate greatly |
08-13-2021, 01:56 PM | #8491 | |
Rep 25
08-13-2021, 02:09 PM | #8492 |
Rep 14
maybe you took a bump and it switch I see your are in Montreal too, on connait la qualité des routes ici ahah
andream, android, android auto, apple, carplay, mmi, retrofit |
