02-09-2019, 12:07 PM | #23 |
Rep 1,805
See screenshot. Let me know you don't have all those available.
The rest will need to have a connection to the car. Look through the DPF submenu (no idea why it's called that way) and INJECTION FUEL, for charge air pressure nominal (request) and actual. And many other parameters if you snoop around. Towards the bottom of jobs list there are dozens of other relevant parameters. Keep in mind, the boost values will be in absolute pressure: atmospheric+boost.
02-09-2019, 12:14 PM | #24 |
Rep 1,805
Be sure to also check your egr delete plates, etc.
02-09-2019, 01:27 PM | #27 |
Rep 1,805
Yea, ICOM will work as well. That's what I use, as I don't have an ENET. You just have to use itoolradar to get icom IP and set up ediabas using easyconnect
02-10-2019, 11:35 AM | #28 | |
Rep 3,540
You might want to check your intercooler for any punctures. A pressure test on that can probably be run pretty easily. |
02-11-2019, 08:07 AM | #29 | |
Rep 368
02-11-2019, 12:15 PM | #31 |
Rep 1,805
These work incredibly well for all types of leaks
https://www.ebay.com/itm/264134468462
02-15-2019, 10:14 AM | #32 |
Rep 368
Knock on wood, but so far the errors havent come back since pulling everything apart and reseating it last weekend. Could be I unknowingly fixed whatever it was. If it returns I'll have to look into the pressure testing or smoke testing.
04-03-2019, 04:08 PM | #33 |
Rep 368
Well, The check engine lights have continued. I got the OBD fusion app and have been logging commanded boost versus actual boost. There really isn't anything too exciting to see though. They seem to follow each other in a very predictable manner. I'm guessing the only way this loggingwould be useful it would be to see it when the error actually occurs. Unfortunately that is only once every 50 to 500 miles.
The code that it reads indicates that it is a overboost condition. Can anyone fill me in on what exactly causes over boost? |
04-03-2019, 04:42 PM | #34 |
Rep 1,805
Have these errors for overboost just now started coming up, or could they have been there for a much longer time?
Overboost is not really an error for the smoke machine to solve. On a tuned car, there can be too many variables on what may have caused it. Seeing the boost follow requested is good news. When you get the error, use ISTA-D to pull the environmental conditions when it happened. It will give you a lot more clues.
04-24-2019, 10:43 AM | #35 |
Rep 368
Turns out the charging pressure sensor is just the MAP sensor that is located right on top of the intake manifold. It came up as a short to ground yesterday and the car was stuck on "drivetrain malfunction" mode. The car was still driveable, but noticeably different since it's guessing at the boost pressure.
I had the sensor overnighted but I wasn't really sure what sensor it was going to be until it arrived lol. Luckily that was an easy one, Had it replaced in 5 minutes.. I notice the old one had a lot of crud on it, so I can see why it wasn't happy. I cleaned what I could reach in the mounting hole with a 6 inch q-tip. The inside of the intake manifold is definitely a caked mess. |
05-21-2023, 05:09 PM | #36 |
Rep 11
hello, I cleaned the intake manifold and I get these errors, the car went crazy for a while, it was losing power and coming back, can you help me with some advice? thank you
05-23-2023, 07:18 AM | #37 |
Rep 368
It looks like the sensor is working properly from the diagnostics that you ran. The measured values all seem to be where it says they should be.
I would think your issue probably has more to do with that "Short Circuit to B+" error code. I would maybe follow the wiring loom that goes to the sensor as far as you can follow it and look for any pinching or damage. |
11-07-2023, 11:36 PM | #38 |
Rep 1
Hi! I’m new to this forum. Here’s my situation. Brought my x5 35d into dealership for coolant loss and egr recall. After repair, sluggish acceleration and later cel. Brought back to dealership and they said that was car is tuned and that they couldn’t don’t anything unless they default program it. Husband bought used from dealership not knowing it was tuned. Gave them to ok to reprogram it but then they said they weren’t going to bc they didn’t want to mess up car. The code was charging pressure too high. Recommend replace turbo. I was worried that after egr recall triggered fault code and that turbo was fine. Took to two independent shops and they both said it was turbo. Spent $6+grand on replacement of turbo. Still feel that egr cooler is causing car to rev during deceleration. I don’t have anywhere to go to have anyone experienced with x5 diesel tuning to help. Anyone with suggestions greatly appreciated. Thx
