12-12-2013, 02:50 PM | #1 |
Rep 32
Drivetrain Malfunction w/ JB4 stg 1 & injen CAI
Need help here guys, I recently installed JB4 stg1 & injen. Performance feels better. Yesterday, I floored the rev to 6000 in 3rd I believe and the car just went limp and said drivetrain malfunction - power output limit reached.
I'm wondering has this happened to anyone!? I have been revving it since the install a week ago and it was fine until yesterday. Was it just a misfire or what? |
12-14-2013, 06:47 AM | #4 | |
Rep 115,980
Mike |
12-15-2013, 08:03 PM | #6 |
Rep 923
Any update ? Was it your oem charge pipe ?
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
12-15-2013, 11:44 PM | #7 |
Rep 32
So far so good after Terry told me not to connect the blue solenoid wire on the stage 1.
Today the CEL actually lit up under comfort mode when I was holding a gear going uphill. I am wondering what could cause that. Can anyone jump in with your experience? Do I need a CP when I only hv stage 1 and an intake?! |
12-16-2013, 05:23 AM | #8 |
Rep 923
You would need a CP if your OEM one has cracked. Opinions will vary about the need of a CP.
12-16-2013, 07:13 AM | #9 |
Rep 71
First thing I would do is connect your laptop to the JB4 and read the code your car is throwing. Open your JB4 performance tuner app, click file connect then go to the settings tab. Choose to read DME codes.
If you haven't already installed the app, you can get it from here http://www.n54tech.com/flash_files/jb4_interface.zip Also, read this thread (it gives you a good general understanding of the JB4 for the F series): http://www.n54tech.com/forums/showthread.php?t=18588 |
12-16-2013, 12:49 PM | #10 | |
Rep 32
12-16-2013, 04:03 PM | #11 | ||
Rep 53
12-17-2013, 09:32 AM | #13 |
Rep 1,997
If it's a stage 1 then it wouldn't have the connector on the box. Only stage 2 comes with the ability to connect to a laptop (assuming you purchased the connector from BMS)
11-07-2017, 12:41 AM | #14 |
Rep 1
Have you resolved this issue? I have an Ingen CAI. I have driven about 5k miles and have not had any issues. I'm thinking about purchasing the BMS stage 1, i'm concerned I may run into a similar issue.
11-10-2017, 01:06 PM | #15 | |
Modder of everything I own
147
Rep 491
I do have an Injen CAI with the JB4, no issues with mine. I only have Drivetrain Malfunctions when I disconnect my MAF sensor for some reason otherwise no issues. Hope this helps.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
