10-15-2021, 12:09 PM | #1 |
Cheapskate
4447
Rep 4,993
TU vs Dorch Stage 1 vs. Dorch Stage 2
I have ran all pumps from stock (obviously ), TU, Dorch Stage 1, and Dorch Stage 2. I took the opportunity while I had all the pumps in front of me, to make a quick comparison video. Hope this helps.
10-15-2021, 05:43 PM | #2 |
Rep 148
Well done Kern! I have the stage 1 HPFP, and I definitely am glad I chose it over the TU. For E85 lovers, I've never had any issues running E30-40 mixes. Never tried the straight E85 as I prefer WMI with my 93 OTS tune, but I bet the stage 2 would kill it.
10-26-2022, 08:36 AM | #3 |
Rep 54
Great video!
I will be soon be upgrading the pump. I have really bad fuel where I live so I can't even run MHD Stage 2 98 map on 98 fuel E15. My stock HPFP starts dipping below 2200 psi at E20. Not sure if it's something else causing these issues. My logs looks fine with MHD Stage 2 95 with 98 fuel E15. I'm thinking either the TU pump or Dorch stage 1. Any pros and cons between them. Reliabilty etc? Or should I just go with Stage 2? I will probably run E30-E40. |
kern4174446.50 |
10-26-2022, 05:09 PM | #4 |
Rep 190,777
Thank you for the video
kern4174446.50 |
10-26-2022, 11:48 PM | #5 | |
Rep 942
10-27-2022, 06:50 AM | #6 |
Rep 2,639
Seems like TU HPFP best price and option, unless you're planning on running high % of Ethanol.
10-30-2022, 06:53 PM | #8 | |||
Cheapskate
4447
Rep 4,993
12-27-2022, 07:33 AM | #9 | |
Rep 54
This is a long shot, but do you have idea if you can code in a oil temp gauge on a pre-lci m140/m240? |
12-27-2022, 01:56 PM | #10 | |
Cheapskate
4447
Rep 4,993
Regarding the oil temp, I have seen it on a hidden menu, but you have to turn it on every time you start the car. Or you can buy a gauge like P3 Gauges or Awron to have it always visible. |
12-27-2022, 09:22 PM | #12 |
Novice
303
Rep 695
12-28-2022, 08:01 PM | #13 |
Rep 22
01-10-2023, 04:31 AM | #14 | |
Rep 54
The reason I want a new HPFP is because I can't run MHD Stage 2 98 with 98 fuel. I need more then E20 because of timing corrections. But my HPFP starts dipping below 2200PSI at >E16-17. Is it possible that there is another issue causing the timing corrections, bad plugs etc? |
