BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > How best to peel a boiled egg
proTUNING Freaks
      04-12-2024, 03:09 PM   #1
tranquility
sportscars only
tranquility's Avatar
Drives: 2011 Z4 sDrive 35i
I don't wanna google and just want real life accounts from you guys. Don't wanna buy specialized equipment either. Tired of burning my fingers haha but I wanna eat them while still hot.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
      04-12-2024, 03:25 PM   #2
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Saw a video of someone putting a hard boiled egg (with shell) into a jar with what I think was vinegar. Shook it well, and all the shell came right off in seconds.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      04-12-2024, 03:27 PM   #3
erickonphoenix
erickonphoenix's Avatar
1739
Drives: 2014 Gray 328xi Touring
We do a lot of deviled eggs for parties.
Eggs in room temp water, bring to boil in 15 mins, ice water, peel under running water.
I've cleaned 30 or so at a time and it was not bad.
      04-12-2024, 03:29 PM   #4
MassWholeBimmer
Drives: 2023 X5 M50i
...Eggs, vinegar..that reminds me.. I need to make a batch of pickled eggs....
2023. X5 M50i
2019. F150 SCREW 3.5 L Ecoboost
      04-12-2024, 04:08 PM   #5
Pauly Wauly
Drives: BMW 560X
If I`m eating them right away, I peel them under the tap running cold water over them, or I put them in a bowl of cold water and they peel much easier.
Karma is real!!!....You keep doing people dirty and being a complete asshole and think God is going to bless you. It may not be today, or tomorrow, or next week, but what goes around comes back around. And when that bitch comes for you it`ll be tenfold!
      04-12-2024, 04:51 PM   #6
Oldgixxer
Oldgixxer's Avatar
1993
Drives: nothing fast
Peel under water like mentioned above
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582)
Gone but not forgotten:
-'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG
      04-12-2024, 05:15 PM   #7
erickonphoenix
1739
Not related to eggs but having been kicked out of the house as a teenager, I was embarrassingly old when I learned instead of peeling a clove of garlic by hand just put it under the flat side of a chopping knife and smash it. Skin comes off quick that way. Wish boiled eggs had a trick like that.
      04-12-2024, 10:12 PM   #8
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
After boiling them put in a bowl with a lot of ice, after 5 mins you peel them. Its some 5-5-5 method wife uses weekly; 5 min in IP, 5 min pressure release, 5 min ice bath.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      04-13-2024, 12:48 AM   #9
Maynard
Drives: 228iX & M2C
They do - you gently roll it under your hand on a flat surface, just hard enough to crack the shell all around. I've done dozens at a time this way.
      04-13-2024, 06:14 AM   #10
tranquility
sportscars only
I remember a scene from Angel Heart, that's how 'Louis Cypher' does it.😅
      04-13-2024, 10:00 AM   #11
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
I "hardboil" the egg in the microwave.
In a 1 cup (8 ounces) Pyrex measuring cup fill with 1 cup of cold (tap) water. Crack egg and gently let it slide into the water. I put nothing in the water.
Put the cup in the microwave. I cover the cup with a paper towel. I set the timer to 60 seconds on full (950 watts) power.
There can be some variability if one switches from a small egg size to a larger egg size. And the temperature of the tap water can play a role. Occasionally the egg will emit a "pop" signaling I used too much time given the size of the egg and the tap water temperature.
You will probably need to do some experimentation on how long to let the egg sit in the hot water to ensure it is hard cooked to your satisfaction.
When the egg is cooked I carefully pour the contents of the measuring cup into a large slotted spoon. After some bit of drain time I put the egg onto a plate.
Added: For peeling pan cooked hard boiled eggs I use the technique I learned from my Mom. Pour off the water and then shake the pan hard enough the shells crack from the eggs hittihng each other and the side of the pan.
The eggs are hot but the shells come off pretty easily.
      04-13-2024, 11:54 AM   #12
tranquility
sportscars only
^Not sure if srs. If indeed, that's WAY too much work lol.
      04-14-2024, 06:35 AM   #13
ShopVac
Not willing to take advice
ShopVac's Avatar
Drives: F82 M4 - 6MT
I tap the fat end of the egg lightly with a spoon before cooking, to crack the internal membrane. sometimes takes 3 or 4 hits to do it, but should sound like one of those snap dragons. Note this also make them easier if you're separating the egg yolks too.
Cook normal, peels much easier, but I do always do it under cold water.
Proud owner of 4 Turbos and 1 Supercharger
      04-14-2024, 09:04 AM   #14
RockCrusher
Well, then peel the eggs the way it has been done for years.
Watched my Mom and she could have a pan of hard boiled eggs peeled in about as much time as it takes to type this.
Not quite the same but you could try French Style eggs. In non stick skillet add butter then when melted add one or 2 or more eggs. Add a couple of tablespoons of tap water and cover the skillet with a tight fitting lid.
Water steams the tops of the eggs and you can let them steam until they are hard cooked.
      04-14-2024, 09:44 AM   #15
///MPhatic
The Seeker
///MPhatic's Avatar
14151
Drives: OG M2 • Exige
I don't eat hard-boiled eggs, but if I did, there's only one way I'd peel the shell.
      04-15-2024, 01:35 PM   #16
tranquility
sportscars only
Don't forget to grow out those nails so you can also fingerstyle w the guitar
Actually, I dunno why Rourke's character was so shocked by him biting into it, unless he felt his soul being consumed. I'd just be thinking 'ok weirdo' lol.
      04-15-2024, 02:33 PM   #17
Esteban
Esteban's Avatar
Drives: a slow car fast
^ Good movie.
///MPhatic14150.50
      04-16-2024, 03:50 PM   #18
UncleWede
Long Time Admirer, First Time Owner
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
boil
cool by rinsing out hot water and dropping ice cubes in pan
drop one or two into a plastic glass, shake a bit
finish peeling, rinse in remaining cold water in pan
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
