06-09-2014, 01:15 PM | #27 |
Rep 232
I completed this brake upgrade on my 328i. This set up fits under the base 17" rims. You WILL need 335 parking brake shoes/hardware to use your parking brake with the rear 335 rotors.
I'll be posting a walk through with pics. Here's a sneak peek
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S |
06-13-2014, 03:34 PM | #28 |
Rep 1,556
[QUOTE=hevykevy420;16096121]I completed this brake upgrade on my 328i. This set up fits under the base 17" rims. You WILL need 335 parking brake shoes/hardware to use your parking brake with the rear 335 rotors.
I'll be posting a walk through with pics. Here's a sneak peek [/QUOTE Are you sure they will fit the base 17s? I was told by several people you have to have 18s. In your pic you have 18s. |
06-17-2014, 03:31 PM | #29 | |
Rep 232
Yes, I have 18" on in the pic, but for shits 'n giggles I put the base 393 17"s on first and took a few pics to settle the fitment question without doubt They fit, with plenty of clearance. See pics, these clearance pics are with the base 17" 393s (shown in first pic). 2nd pic is 335 front rotor/caliper on 328. 3rd is top of caliper clearance to 393. 4th is bottom clearance 5th is side of caliper/wheel clearance I didn't bother testing the rears because there is a lot more clearance there, the rears are a non issue... PS- I bet a lot of 335 owners just think you need 18" wheels to clear the 335 brakes because I think ALL 335s come with 18" wheels standard. ALSO, if you look at the inside of 393 wheels, the inner wheel areas are shaped in such a way as to provide max caliper clearance, and the "spokes" are relatively flat, also providing pretty decent caliper clearance. Maybe 335 folks tried to go to a non-OEM 17" wheel and had clearance issues...dunno...but the 393 fit for sure.
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S Last edited by hevykevy420; 06-17-2014 at 03:42 PM.. |
06-18-2014, 01:02 PM | #30 | |
Rep 1,556
DAYUM!!!! That's awesome. Now I know what my next upgrade is. Just shows to not believe what you read all the time unless it can be proven. I literally did not buys these listed after talking to a few saying the stock 17s wont work and I had no real way to verify. Thanks!!! |
06-25-2014, 04:30 PM | #32 | |
Rep 232
I don't have braking distances to compare but the brakes feel much better/stronger after the swap, easier to modulate, more feel. Hard to tell what did what as the lines help I'm sure and the M wheels/tires are a big help also. I also weighed everything during the swap to compare and the 335 front calipers are much lighter than the 328 stockers. Believe it or not the front 18" 441 M wheels/bridgestones weigh the same as the base 17" 393s/Pirellis (the rears are a little heavier though due to increased width). Be advised that The 335 standard OEM rotors are a couple of pounds heavier than the 328 OEM rotors (I want to say 2-3 lbs, but have to look at my notes). Overall, I'm OK trading off the increased weight for the bigger brakes. Rotors act like heavy flywheels so ideally you don't want to add weight there. Eventually I'll swap the OEM 335 rotors hopefully for some lighter weight ones. If you REALLY want to do this mod right and 0-60 times ARE a major concern I'd go with some lighter weight performance rotors (if they're available) but for what 335 folks are selling all this stuff for its a dirt cheap big brake kit.
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S Last edited by hevykevy420; 06-25-2014 at 04:49 PM.. |
06-25-2014, 04:58 PM | #33 | |
Rep 130
also , did you have to do any kind of coding or was it just a bolt on ? |
06-27-2014, 02:25 PM | #34 | |
Rep 232
I have a professional mechanic friend that recently purchased a very expensive scantool or computer set up for the current bmws for diagnostics and whatnot. I wish I had more detail on it, but he said it was ridiculously expensive (he works in a "pro" indy shop specializing in foreign cars). My plan is to research/identify the brake menu/table and maybe have him take a look. He said he wouldn't mind doing that, but I think he needs to know where to go in the menus. It probably is as easy as changing the rotor diameter values in a braking table. Alternatively I plan on building the OBD2-rj45 cable and jumping into E-sys/coding, I'm sure I can figure it out with enough time, but I'm not there yet. I need to get the parking brake functional, have the 335 parts so hopefully this weekend. The coding issue will follow. Will post up something when I have the info. I can say that you can do the physical parts with no mandatory coding without any adverse effects or CELs. To my understanding, the master cylinder is the same on 328i vs. 335 and proportioning is also the same (could be wrong, but I think they are the same.) I doubt changing the rotor diameter values is going to influence the TC/ABS in any big way, but that is just my $.02. I will get it done though as I'm the type to think if the factory designed the table, its gotta be for something...
06-30-2014, 12:17 PM | #35 |
Rep 232
Unfortunately the swap for the rear ebrake was not as simple as I thought it was going to be. Rather than continue to jack this thread (sorry OP) I'll just point you here for fitment information:
http://f30.bimmerpost.com/forums/sho...5#post16212955
07-08-2014, 10:21 PM | #39 | |
Rep 89
07-28-2014, 08:56 AM | #42 |
Rep 108
Drives: 2014 328i xDrive Sport Line
Still available? Please PM price shipped to Canada if possible. Thanks.
