10-28-2020, 02:58 PM | #1 |
Rep 424
overall tire diameter for RWD
after researching it is a bit unclear to me if overall tire diameter matters on RWD car?
the setup that I have recently switched to is 235/35/19 and 255/35/19 on 8.5j square wheel which results in 2.2% taller back tire. My question is does it matter that the circumference difference is above 1% on RWD? Is it safe to ride on this setup or should I be switching back to my OEM set some clarification would be great.
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
10-28-2020, 05:13 PM | #2 |
Rep 424
Surprised no ones ran into this before
10-28-2020, 06:22 PM | #3 |
Rep 1,560
If you have the same size on both sides on a RWD car it shouldn't break anything unless it rubs. Your speedo will be off as will be your odometer.
The 1% issue is for AWD between axles.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
