11-13-2018, 04:49 PM | #23 | |
Rep 96
I haven't looked into changing the turbo setup yet. I'm not going for super high HP, but something more focused for the track. If it could manage around 450 whp with the responsiveness of the PS2, I'd be very happy. I've heard that the PS2 is good for around 2.5bar, I'll see how long it holds up around 2bar. |
Stubok471.50 |
11-13-2018, 05:06 PM | #24 | |
Rep 5,457
Drives: F30
take1step100.50 |
11-13-2018, 07:45 PM | #25 | |
Rep 3,679
11-20-2018, 03:08 PM | #26 |
Rep 96
Some more photos:
Some pretty cool pictures of the cam assembly and the porting and polishing on the cylinder head. And you could see how the rods failed. All the rods had some degree of warping (you could see the slight "S" shape). The one that failed was warped enough that it started scoring the cylinder wall and the piston finally gave out. |
11-20-2018, 05:03 PM | #27 |
Rep 227
Drives: 2000 BMW E39 M5
Wow, it takes a ton of torque to warp a connecting rod like that. Thanks for the pictures!
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe Waiting for: Bootmod3 - xHP Flashtool - xDelete |
12-07-2018, 02:54 PM | #29 |
Rep 96
Picked up the car, she's running good. I'm going to drive it for about 500km to break it in. Then we'll throw it on a dyno for a re-tune and to turn up the boost , should have some dyno charts in 2 weeks
12-07-2018, 04:28 PM | #30 | |
Rep 3,679
Not sure if it was mentioned before, but what setup were you running when you bent a rod?
12-07-2018, 04:34 PM | #31 |
Rep 891
Very cool take1step, thanks for the contributions.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
rjd_F301999.50 |
12-07-2018, 08:16 PM | #32 |
Rep 96
I was running 28 psi on a Pure Stage 2 Turbo with 50/50 methanol. I was running it at 28 psi for about 2-3 months before the ringland gave out.
12-07-2018, 10:39 PM | #33 |
Rep 3,679
Damn that's not that bad actually. I'm surprised it even lasted that long at 28psi. I suspect you won't have that problem anymore though
12-07-2018, 11:41 PM | #34 | |
Sedan Driver
389
Rep 1,018
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
12-08-2018, 11:25 AM | #35 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
Any updates?
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
12-27-2018, 12:59 PM | #36 |
Go Fast Dont Die!
407
Rep 472
Drives: '12 328i Sport 6MT
Here for the info
BootMod3 stage 2 93 octane AGG| K&N Drop In| Turner Motorsports Intercooler| BMS Catchcan| FTP Chargepipe & TIC| MST Turbo Intake Pipe| CW Catless Downpipe| BAV Coils| KW DDC Coilovers| Active Autowerke Exhaust| CF Mirrors| CF Spoiler| Rohana RFX11| Black Painted Roof| @instagram.com/fastactionjax/
@youtube.com/fastactionjax/ |
01-12-2019, 02:05 AM | #37 |
Rep 176
If you're after any help at all, i just posted my build log on building this engine here in my 220i https://f30.bimmerpost.com/forums/sh...6#post24135816
Good to see im not the only one to be posting a built n20 thread, i ended up sleeving the cylinders, and semi closing the deck, i also went with 10x 11mm ARP2000 headstuds from the N55. Awesome to see you had the head ported, thats not something i thought was necessary but it's definitely not off the cards, i may look into it. Well done man interested to see power results! So far I've done 2800kms on the rebuild and damn! This engine takes some boost now! Last edited by navardi; 01-12-2019 at 02:43 AM.. |
take1step100.50 |
01-14-2019, 02:06 PM | #38 | |
Rep 96
I've been driving the car for about the same time now. I recently got it retuned but I'm still working out some minor issues (with the tune because of the head porting). We're currently looking into it but I think we have to readjust the valve lift tables (Valvetronic), I'm getting throttle closure and hesitation during normal driving above 3000 rpm. After I have the tune finalized, I'll put it back on the dyno to see final numbers with the Pure Stage 2. |
01-14-2019, 02:08 PM | #39 | |
Rep 3,679
01-16-2019, 07:27 PM | #40 | |
Rep 176
Awesome, if head porting is worth it, ill get it done! Keen to see the numbers, who are you getting to tune it? Local BM3 tuner or a remote BM3 tuner? Im still waiting on Halim from HCP to tune, i requested months ago, still waiting... But hopefully something soon. Also keen to know what boost numbers you're hitting, with associated fuel? Looking forward to more updates! |
01-17-2019, 04:28 PM | #41 | |
Rep 96
I'll be getting it tuned on our pump gas, 94 oct (10% ethanol) with a 50/50 mix for methanol injection (Single CM 7 nozzle for now). To hit 400 awhp I think the PS2 will have to run 35 psi but the turbo wasn't made for that kind boost, they say it's rated for 31 psi. We'll see how it performs after this tune is dialled in. Custom turbo setup?.. G25, EFR ect.. lol |
01-18-2019, 02:54 PM | #42 | |
Rep 14
2012 BMW 328ix N20 - BMS JB4 | VRSF 5" intercooler | FTP chargepipe | GFB DV+ | VRSF 4.5" catless DP | Sweet wrap & straight pipe
INSTA: @f30.nyxie |
03-09-2019, 03:36 PM | #43 |
Go Fast Dont Die!
407
Rep 472
Any Updates my Friend?
LordRuxpin103.50 |
