11-10-2018, 03:32 PM | #1 |
Rep 29
Exhaust flaps open
I have a 2015 328i sport and I wanted to know how I can keep my exhaust flaps open all the time. if I keep them open will I get a light on the dash and is there any side effects of keeping the flaps open ?
11-10-2018, 04:13 PM | #2 |
Rep 242
Drives: 2013 328i 6mt
JB4 stage 2 has an option for an exhuast flap adjustability. Otherwise just keep it in sport mode
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
11-10-2018, 04:15 PM | #3 |
Rep 29
11-10-2018, 04:23 PM | #4 |
Rep 965
Drives: 2016 F36 435x MSport
Remove the spring between the motor and the valve. Use ss wire to hold valve in open position.
11-10-2018, 05:04 PM | #5 |
Rep 15
Drives: F30
I have mine open all the time, no issues. While it it was open I unplugged it from underneath, around the exhaust. You can find YouTube on where it's exactly located.
11-10-2018, 07:03 PM | #6 |
Rep 504
I think there must be some regional coding differences.
If I put my 328i into sports or sports+ mode, it does not change the behavior of the exhaust flap. I have mine flashed with BM3 stage 1 and if I use diagnostics, I know the flap operates (can open and close). Does anyone elses 328i's flap do this too? |
11-10-2018, 08:01 PM | #7 |
Rep 965
If you have an f36, it behaves differently. Flap doesn't open automatically by switching to sport unless under load
11-10-2018, 09:33 PM | #8 |
Rep 3,680
Just wait for it to open on it's own, and then unplug the little motor that controls the flap. It's located right behind the exhaust tips. You won't get any lights on the dash or anything like that.
11-11-2018, 02:00 AM | #9 |
Rep 943
Drives: F30 328i Msport
To be precise, it does throw a silent code. What I did was leave everything plugged in, just remove the spring with some pliers and secure the valve notch in the open position.
11-11-2018, 04:11 AM | #10 | |
Rep 504
I think you can change it though so I might have a chat to the BM3 guys once I go Stage 2. I'm pretty sure it can be coded into the tune or something. |
11-11-2018, 09:09 AM | #11 |
Rep 3,680
It does, hence why I specified lights on the dash not just codes generally. But yah that works too if you want to remove the spring. Lots of options OP
11-11-2018, 12:23 PM | #12 |
Rep 965
Fyi worked with them on this. We got closer. Right now the latest tune version for n55 we have it so that as soon as you hit the pedal the flap opens and stays open. Which is nice because it keeps the car quiet on cold starts, then once i tap the gas it opens up.
11-11-2018, 05:14 PM | #13 |
Rep 16,082
11-12-2018, 12:37 AM | #14 |
Rep 537
Just use Bimmercode with Bimmerlink and you can have full control over it.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
11-12-2018, 06:53 AM | #15 | ||
Rep 504
Same behaviour with or without BM3. |
