10-19-2017, 01:46 PM | #639 |
Ridin' thru Atlanna
26
Rep 64
Drives: 2017 340i M Sport Dinan S1
I have the Stage 1 (non-MPPSK) and FreeFlow Exhaust. I love them both and highly recommend either.
Current: 2017 F30 340i Mineral Grey/Black Dakota - 8-sp AT - M Sport - Track Handling - Driver's Assistance - Technology - Adaptive M Suspension - Dinan ECU Flash - Dinan FreeFlow Exhaust
Past: 2007 E92 328i Space Grey/Black Leather - Sport - 6-sp Manual 2004 E46 325ci Grey/Grey Leather - Sport - 5-sp Manual |
10-19-2017, 05:23 PM | #640 |
Rep 104
Drives: M3 6MT ordered, AR 4C Spider
10-27-2017, 02:46 PM | #641 | |
Rep 70
F30 335. Dinan Stage 4 including suspension. Wavetrac LSD.
phinole25.50 |
11-26-2017, 03:19 AM | #642 |
Rep 8
H&R Lowering
Can somebody who has H&R springs as their suspension please tell me their daily driving experiences... I'm debating on whether I should get coilovers or springs. Mind you that I do plan on selling my vehicle 2-3 years. Therefore, an investment on coilovers may not be necessary.
I feel like all I've read are the cons(Riding H&R springs on a speed bump can be hell apparently???) I'd like to hear the positives to the springs :\ If you can recommend other springs that can fill my stock gap but doesn't sacrifice too much performance it'd be great. Last edited by F32_6o4; 11-26-2017 at 03:26 AM.. |
11-26-2017, 11:51 AM | #644 |
Rep 8
11-27-2017, 03:27 PM | #645 |
Rep 403
Can you confirm this is the right part number as another member posted a different one for the front (335xdrive sedan 2013)
He posted 31332225377 for the front |
06-01-2018, 11:04 PM | #646 |
Rep 357
Just did it; a transformative experience! Waited until having a full summer with it, all R&D issues ironed out (which eliminated H&R as contenders due to low performance and spring rate). Had everything installed (sways, springs, handling kit + ER charge pipe) two days ago.
Everything Dinan_Engineering or JamesNoBrakes say in their comments/review is accurate. They were also helpful with spec requirements and instructions.
These work with the Dinan Shockware Adaptive program, installed a year ago. The upgrades eliminate any considerations I may have had towards the 340i, as I exceeded specific cornering benchmarks that I noted when driving 340i M Performance Demos. 340i would also require suspension upgrades. Driving it, I understood the trade-off design philosophy of the OEM springs. Lower spring settings, even 18 mm, is more uncomfortable but multi-fold sporty. Noisier- not much, but noticeable with frontal and side winds, or some iffy highway surface. Drivers uninterested in driving dynamics would find it too connected, too sporty. BMW could have offered a better option, but there may have been no R&D interest in the F3x chassis. At least Dinan did that homework. Yet, clearly, some lessons were incorporated in the 340i, which I suspect mainly Adaptive Flash, a stiffer ZF rack and the rear multi-link change. Yet R&D is not easy- some known brands offer generic products, springs bottoming out or spring rate ill-suited to Adaptive M. For example, although lower, I scrape less the lip in one particular location, as the car does not bounce up or down anymore. So higher, softer BMW OEM spring was worse in that aspect than the lower Dinan. Last edited by Musashi; 09-05-2018 at 08:46 PM.. |
VP_5675.50 |
07-24-2018, 03:28 PM | #647 | |
Rep 63
09-05-2018, 08:40 PM | #648 | |
Rep 357
Now testing custom made FRONT 3d continuous fiber CCB brakes (technology exceeding what Brembo has and superior in any M3/Porsches that I drove) for future 3 series production. The effect of removing 15 kgs of rotor mass on acceleration and steering, plus having unparalleled linear braking has given me a new appreciation for this platform. 150-200 lbs sprung weight equivalent removed, have no words to describe the effect it has. Last edited by Musashi; 09-05-2018 at 08:53 PM.. |
11-08-2018, 04:01 PM | #650 |
Rep 2,044
Hello BMW Experts!
I am running Dinan springs with Billy B8s & 440i sway bars, Konig 17" 17lb flowform wheels. It finally handles! Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-10-2018, 08:07 AM | #652 |
Rep 2,044
11-11-2018, 06:54 PM | #653 | |
Rep 385
Also, I didn't even know it was possible the 440i sway bars fitted. What was your reason getting that over any other aftermarket sway bars? |
11-12-2018, 05:34 AM | #654 |
Rep 2,044
Hi MK,
The good with coilovers is getting matched spring & damper rates, with adjustable ride height. I think Bilstein, Dinan, & the other better companies try to match their product to car also, often down to the individual model. IMHO, Bilstein match my needs (NYC & north to mountains) very well (I often have liked the 'action' of Konis a little better, but I've broken too many of them). I don't have to fiddle with settings, & Billies never need a rebuild, which even Olins do. So for this car I tried a couple of springs. My car came stock & I wanted as little drop as possible (snow & dirt roads often) & to keep a good cruising ride, so I got a set of M-sport springs from the adds here. Fronts were OK, but the rears were too soft. Dinan springs only dropped me another 1/4", firmed up the car nicely, & they seem right on with the B8s. Some may prefer a softer shock, but not I! To try & keep a nice ride, I didn't want too big sway bars (Dinan bars are bigger). I liked the 'factory max' on my E46, & so went with them on this car. The table I used is in this thread, then I found them in a junk yard (I got the biggest '440i/335i M-Sport' F: 25/22.2mm, R: 15mm): https://f30.bimmerpost.com/forums/sh...light=sway+bar I think I went moderate on spring rates, moderate on sways, & heavy on shocks. YMMV! And, of course, I couldn't find Olins for even twice what I paid.... Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-26-2018, 10:55 AM | #655 |
Rep 254
I just did springs (+ bumpstops) this weekend with a mechanic buddy on my RWD 335i, took us about 6 hours. Granted we were bs'ng along the way, but anyone that claims it's a 1-3 hour job without having done it before is full of it.
Aaaanyway, here she is, as others have said the ride quality hasn't been compromised from stock at all, we'll see how long that lasts for, but I'm very happy with these! Really looks so much better with the wheel gap closed up. |
11-26-2018, 03:34 PM | #656 |
Rep 26
Looks great everyone! I will most likely go with these springs for my 328i! Will this bottom out the rear with passengers and luggage in the trunk? OR, with the stiffer spring does it not settle as much with the added weight?
2015 328i M Sport
11-27-2018, 10:13 AM | #657 |
Sedan Driver
389
Rep 1,018
Dinans are stiffer AND linear (what most ppl seem to forget) so it won't just bottom out with passengers and luggage.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
11-27-2018, 06:42 PM | #658 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
What a joke.
11-28-2018, 06:34 PM | #659 | |
Rep 2,044
I haven't driven enough on the Dinan springs yet, but I think they are much better than the base & the M-sport springs, for handling loads, or luggage loads. Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
01-29-2019, 12:52 PM | #660 |
Rep 2,044
Hello BMW Experts!
When using Dinan springs with Bilstein shocks, is it recommended to use the bump-stops (Dinan or regular) in the rear? I have heard the front Bilsteins have bump-stops internally, and with the fat rod can't use external bump-stops anyway. Are the rear Bilsteins the same in this way, and might using the external rear bump-stops cause an unwanted loss of travel? Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
