01-04-2016, 10:09 PM | #45 | |
Rep 272
I was the second one in the group buy or something, so that might be one reason it was shipped so soon. Shipping was very quick for here in the USA though. It was shipped Next Day which I was surprised and happy to see.
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
01-05-2016, 08:16 PM | #46 |
Rep 832
Here's the software downalooad. please use version 2.93
http://www.audiotec-fischer.de/cms/l...p-pc-tool.html Here's the manual http://www.audiotec-fischer.de/lng/en/pp-82dsp.html please make sure dip setting 2 and 4 on the amp are ON. |
01-06-2016, 07:01 AM | #47 | |
Rep 272
01-06-2016, 02:40 PM | #48 |
Rep 4,323
Did anyone get tools? Mine came in a box with just the amp, and I'm scratching my head here!
01-06-2016, 02:41 PM | #49 |
Rep 4,323
Or can anyone recommend an installer in NJ? I'm a little overwhelmed looking at this....( do I start by unplugging battery?)
01-06-2016, 03:06 PM | #50 | |
Rep 272
If you read through the thread put together by JNoSol (http://f30.bimmerpost.com/forums/sho...ght=bimmertech) you will be fine. There are instructions in there for both the install of the amp and loading tune files for your setup. Let me know if you need any help though, just did mine so it's still fresh in the head.
01-06-2016, 03:38 PM | #51 | |
Rep 4,323
Ok, will try this weekend and drop you a note if I get sad, confused, frustrated
01-07-2016, 06:26 AM | #52 | |
Rep 272
I installed a seperate class D mono amp and true 10" subwoofer for the trunk last night, that was a breeze too. Probably one of the easiest installs I have done. So if you ever want to fill out the system even more that makes a huge difference, and takes some strain off of the under seat woofers. Now all that's left for me is a thorough tune...
01-07-2016, 09:39 AM | #53 | |
Rep 4,323
Not that I'd venture to do this (because I'm an idiot with electronics, i'm a geneticist by training), but I assume you plugged the mono into the bimmertech amp? Post up pics!
01-07-2016, 09:50 AM | #54 | |
Rep 272
I am no Geneticist so I think you would be surprised at how reasonable the installations are. I think if I posted some pictures you'd be able to swing it. You are correct, I utilized the RCA output from the Bimmertech Amp as well as the remote turn on (between the power leads that run to the harness) which are both under the left hand panel in my wagon. Then I wired the power and ground leads from the battery area under the right panel. Pictures will help convey how simple it was, literally took two nuts off once the plastic tray that sits atop the battery was out. I had the leads from both side meet up under the cargo area and she powered right up. Ran the left and right speaker cable leads straight up to the box and done.
01-08-2016, 08:01 AM | #55 |
Rep 346
I found out that my Bimmertech amp switches mode were all turned off. I just switched mode 2 and 4 to "on" and what a difference the +2dB made to the overall sound.
01-08-2016, 01:54 PM | #56 |
Rep 272
Yeah, I found that by reading around in another thread after my install. Glad Nelson posted it here to help some people out. Made a big difference
01-08-2016, 06:48 PM | #57 | |
Rep 346
When my underseat sub arrives, I will add some balance soundproofing from stage 1 inside the enclosure to reduce the resonance of the plastic enclosure and see if it is better. It is ported enclosure so I don't think it will be a problem. |
01-09-2016, 08:56 PM | #59 |
Rep 346
See post #46 from Nelson. If you read the manual, page 13 onwards is in English. I think two files are preloaded. Stock tune and Bavsound stage 1. That's what I was told. I have not gone into the tune files yet as I still waiting for my subs. Others can chime in?
01-14-2016, 08:26 AM | #61 | |
Rep 124
01-14-2016, 09:00 AM | #62 |
Rep 272
There are tiny white switches that are numbered on the Bimmertech amp. #2 and #4 will increase your gain.
01-19-2016, 01:20 AM | #64 |
Rep 337
Ok... I need some help understanding what exactly this is.... So for context I am guessing I have the base sound system in my f30 2013 328i (not hi-fi since I don't see it anywhere in my car details nor the HK system) so does the amp work with the base sound system or is it not compatible? If not I'm assuming that the next best option would be to purchase the entire "BMW speaker upgrade" on Baysound's website?
01-19-2016, 11:40 AM | #65 | |
Rep 832
01-22-2016, 09:19 PM | #66 |
Rep 18
Drives: AUDI RS5 Sportback 2022
Thank you Nelson, Patrys and the OP who set up the group buy ...
Received the amp yesterday via DHL from Poland. Fitted it today, it took about 1 1/2 hrs taking it carefully and un-rushed. Bracket fitted well eventhough I have OEM reversing camera. It's much louder than OEM amp with my OEM speakers. It's LOUD!!! The preinstalled tune I'll reserve judgement on ... but then what's the fun of having a DSP if I leave it all to others. Once again, thank you ... great price, great service, great product, great forum. |
