BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
      11-24-2019, 10:32 AM   #485
pcherian
Drives: BMW320d
Hi. I have fitted an Android 9.0 (10.25inch) screen for my 2013 F30 car with CIC unit. From reading the various posts I notice that if I have HU_CIC I cannot upgrade to a higher (non Android) display. Everything is working fine after installing the Android display. However on the original BMW side the image looks stretched on the Android 10.25 screen. Is there any way to code the car to a 8.8 display for a CIC car? Appreciate inputs and suggestions. Thanks.
      11-27-2019, 10:06 PM   #486
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
If you don't want a stretched screen and would like to use an OEM display, you will need to change the head unit to any of these. ENTRYNAV and ENTRYNAV2 can be coded to use the 8.8" screen and NBT and NBTEVO can use them natively.
NBT
NBTEVO
ENTRYNAV
ENTRYNAV2
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      12-04-2019, 11:50 AM   #487
pete in fate
Drives: 2016 320i
Originally Posted by bill_f31 View Post
I'm about to upgrade the 6,5 screen on my 08/14 (HU_ENTRYNAV) F31 Touring to the 8,8 one.
My car is pre-LCI and I have already retrofitted the BMW Integrated Navigation System on my 6,5 screen.
Do you think that a 8,8 screen from an LCI model (part number 65509387453) can be retrofitted to my car or I need to instal the 8,8 screen from pre-LCI model (part number 65509292248)?
Are there significant differences between these two 8,8 screens?
Also the split screen function of the 8,8 screen needs some coding to work or it is automatically set as a menu option as long as the 8,8 screen is installed?
Any help would be hugely appreciated. Thanks in advance.
can you tell me about the integrated nav retrofit?
      12-20-2019, 04:18 AM   #488
bimleaf
Drives: G20
Hey gurus, I recently bought an 8.8 touchscreen (part number 8709339) for NBT2 and ran into a weird behaviour. The screen turns off after awhile or doesn’t turn on at all when starting the car. The screen is just blank, resetting doesn’t help. Radio and everything else still works.
When the screen works it works great.
In ISTA I see the following error:
No communication to CID
Any suggestions on troubleshooting?
      12-24-2019, 04:11 PM   #489
MarkoSK
Drives: BMW G20 330eX
What car do you have and when was it manufactured?
      01-24-2020, 06:03 PM   #490
Lak1990
Drives: F30
Could someone confirm me that ?
I have preLCI f30 05/2015 with Entrynav and navigation on borad.
On specific od car there is a 0606 navigation system business.
And have a question.
The preLCI screen 9292248 fit info my car but the question, the LCI screen 9387453 will fit info my car ?
Some people say somethink about diffrent voltage.
Dont want BLUETINT. Thats why i want LCI screen
      01-28-2020, 08:17 AM   #491
mateos
Drives: F11
Hello,
i am trying to get my F21 from 7/2014 running with entdynav2 id6 65128798036 with a F15 APIX2 65506816387 display.
The radio turns on (there is music playing), but on the display I only see "NO SIGNAL".
The following coded:
CID_APIX_MODE -> apix2
CID_COLOR_DEPTH -> 24
CID_COM_MODE -> mii
CID_RESOLUTION -> 1440 x 540
CID_DISPLAY_SIZE > 10_25
DISPLAY_VARIANTE = breites_display
maybe it worked on somebody?
thanks
      01-28-2020, 10:04 AM   #492
cupra
Drives: x3 n57z
Hi could you please help me to change the exact display before LCI or LCI
the car is F26 03/15 WBAXX110700L95743
HU_ENTRYNAV
thanks in advance
      02-09-2020, 10:58 AM   #493
iurydanchev
Drives: bmw e90f30
Hallo everyone, I'm F31 2016y owner with base multimedia which is hu_entrynav with 6.5 inch screen. I have replaced with 8.8 inch with number 9281688 which is superseded on realoem to all F30 F31s till 2017y. The screen won't start up before I coded with BMWai codder. Display starts when I put display variant to breites_display without changing the resolution because Icoder don't have this option. I used BMWaicodder because E- sys is too difficult for me. The problem is that my 8.8 inch display is not enough brightness It is like unfocused. If I change somehow the resolution of the display could this be the solution of the problem?
      02-19-2020, 03:54 PM   #494
Rameez_209
Drives: BMW 320D F30
Can someone help bimmercode for bigger size resolution CIC headunit
Hi, I'm new to this form. about half an hour a go i did learn alot about bimmercode and coded my car aswell.
I have an android screen which is 10.25" it works perfect but the BMW idrive system has small screen it doesn't look good. can someone help me with what code I need to increase the screen resolution size (display size).
i have a bmw f30 320d auto 2014 and the head unit is CIC (on bimmercode it display hu_cic) it's got built in satnav.
The code i found is for NBT unit
Screen Swap then code code:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But for my unit I don"t have the display size resolution.
can anyone help me with the code how to make the screen size bigger for CIC head unit
Thank you
      02-21-2020, 04:03 PM   #495
escanorbmw
Drives: bmw 2014 428i
hi i have 428i 2014 with a L7 cid entry 6.5 and i want to upgrade to 8.8 can you plea
Originally Posted by kromix View Post
What parts are required other than the screen itself?
What codes are needed?
My plan is to buy the 8.8" screen on ebay, is there a specific part number i need to look for?
What other requirements are there to upgrade?
This should work with the latest version of hardware and HU_ENTRYNAV with no navigation?
From what I understand this is what I need to do
can you please advise what to do?
      02-28-2020, 05:35 AM   #496
Jackstew2
Drives: Scirocco R, ST3, GLA45, 335Dx
Hi Guys,
completely new to BMW, but just grabbed an F31 335Dx. I'd like to upgrade to nav system and bigger screen and have NO clue where to start, coding, units, screens ect.. if anyone can help that would be awesome!
      03-02-2020, 11:42 AM   #497
Erlendg
Drives: BMW 330e
Originally Posted by jdoc999 View Post
I have a 2016 F33 with entry nav and no navigation. My 6 inch screen is model # 9270393. Insatlled a new 8 inch screen # 9387453. I am able to get video but it is cut off. I think i coded correctly with Bimmercode .
I added photo to show. What am i doing wrong?
Jason
Hi, i have the same problem with my 330e 2016 mod. No nav aswell
I am not sure what to do now, i have coded it correctly with bimmercode, and i get the same resultat. Added a photo aswell.
Anyone who know what i am doing wrong?
Link for picture: https://ibb.co/BCzwh28
      03-02-2020, 02:04 PM   #498
nitsuj17
Drives: F30 328ix
Did you code the resolution change too? Most of us didn't have to, but check what it is set to
      03-02-2020, 02:12 PM   #499
El Conquistador
Drives: M240 Vert - 6M as god intended
What if you don't have hu_entrynav?
      03-02-2020, 02:18 PM   #500
nitsuj17
Drives: F30 328ix
you need nbt or entrynav. Entry can't be coded for the change
      03-02-2020, 02:20 PM   #501
El Conquistador
So strange. Mine is a 2017 (F23) and seems to have none of the equipment.
      03-02-2020, 04:32 PM   #502
nitsuj17
Drives: F30 328ix
You have entrynav2 then probably. You would need a different screen. I think there have been posts in this thread about that. Just look through
Or the other 6.5 to 8.8 thread
      03-02-2020, 04:50 PM   #503
El Conquistador
I don't have entry nav. That is why I am asking.
      03-02-2020, 06:22 PM   #504
nitsuj17
Drives: F30 328ix
I believe it's 65506822626 for your car, but you should confirm on real oem
      03-03-2020, 01:29 PM   #505
Erlendg
Drives: BMW 330e
Yes, i tried all 3 of the resolustions (6.5/8.8/10.25) They all made the same result.
      03-03-2020, 02:09 PM   #506
nitsuj17
Drives: F30 328ix
don't have a good solution for you then. it seems like the other people who posted about the same issue never got it fixed and tried a different screen. did you buy the pre lci or lci screen?
i guess it wouldn't hurt to take it out and reconnect the cable to the screen and head unit
