09-30-2019, 07:24 AM | #111 | ||
Rep 54
FlorinQCK-2.50 |
09-30-2019, 11:16 AM | #112 | |||
Rep 210
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
10-02-2019, 04:18 PM | #113 | ||
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I'm planning to install a rear half cage (I don't use my rear seats anymore), so I'll be passing along my Brey-Krause bolt-in harness bar to someone... : ) Quote:
EstorilMSport83.50 FlorinQCK-2.50 |
10-03-2019, 09:11 AM | #114 | ||
Rep 2,639
Normally if you run BM3 or MHD, you'll have much smoother power delivery and if your octane is crap, it'll pull timing slightly to make sure you won't have knock. I run OTS map on the track and it runs great when you have the octane. Quote:
Do you mind posting a pic of your harness bar? I'm interested in getting one.
FlorinQCK-2.50 |
10-03-2019, 09:34 AM | #115 | |
558
Rep 1,477
Drives: 335i
10-05-2019, 07:06 PM | #116 | ||
Rep 54
FlorinQCK-2.50 |
10-05-2019, 07:11 PM | #117 | |
Rep 2,639
You could use JB4 as a meth controller no problems. I personally use BM3 for the track and it runs great, I was a PWG beta tester and OTS guinea pig so I'm really confident you'll have no problems with it.
10-05-2019, 07:12 PM | #118 | ||
Rep 54
FlorinQCK-2.50 |
10-06-2019, 01:06 AM | #119 | ||
Rep 5,393
Tried to attach photo to show stock versus H&R bar but this Bimmerpost app has had problems attaching photos recently |
FlorinQCK-2.50 |
10-06-2019, 01:18 PM | #120 | |
Rep 2,639
FlorinQCK-2.50 |
10-12-2019, 08:46 PM | #122 | |
Rep 2,639
Ohlins is the best suspension coilovers you can get. Period. They're used in all Koenigsegg hypercars.
FlorinQCK-2.50 |
10-23-2019, 12:09 PM | #123 | |
Rep 54
Does anyone know of a company who makes a full roll cage for the F30? RSR makes the roll bar, but that is all I can find. |
FlorinQCK-2.50 |
10-25-2019, 02:54 PM | #124 | |
558
Rep 1,477
Drives: 335i
Autopower makes a full roll cage for the F80, which should be the same as the F30. I'm planning to go with their rear cage ('Race Roll Bar'), but with some extra floor/chassis reinforcement to mitigate the risk of the feet punching through in the event of a roll over. You can pay 3-4x more for a fancy roll bar, but all of them have the same single, glaring weakness... a relatively small plate at the feet of the upright hoop, which could punch right through an unreinforced floor.
10-25-2019, 05:36 PM | #125 | ||
Rep 54
11-15-2019, 06:03 PM | #126 |
Rep 928
What spring rates is everyone running and if you had to do it again what would you run? Don't want too stiff for street use so I'm thinking 8k front and 14k rear?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
FlorinQCK-2.50 |
11-18-2019, 10:09 AM | #127 | |
558
Rep 1,477
Drives: 335i
With 6kg front springs, the car was very prone to over steer.
FlorinQCK-2.50 |
11-19-2019, 09:44 AM | #128 | ||
Rep 1,934
FlorinQCK-2.50 |
11-25-2019, 07:49 AM | #129 | ||
Rep 54
FlorinQCK-2.50 |
11-28-2019, 09:49 PM | #132 |
Rep 54
Yes, now I need to decide which flash to get: BM3 or MHD. Looking for what will be most compatible with my JB4, since it will still be installed and controlling my WMI. Seems like MHD is most compatible, but I'd have to buy an Android device to use MHD. I'll probably go with Bootmod3.
FlorinQCK-2.50 |
