08-13-2018, 06:33 PM | #1 |
Fool
1857
Rep 3,542
Learnt something new about the F3X adaptive LEDs this evening
I'd always assumed that the F3X adaptives weren't as fully featured as the 5 series but the other day, while reading stuff about the G30s, I found the trigger for 'motorway light' and how the default when 'on' isn't actually the highest but is 'country light'.
On the 5s, when the headlight switch is all the way over to the right, they are on 'country light' mode and I always assumed this was as far as you ever got with the 3 series, but after reading about how you have to drive over 68 MPH for a duration (can't recall how long), you then get 'motorway light' I decided to give it a go. Sure enough, once you hit the criteria with the switch to 'auto', the headlights raise a bit to give further throw. Switching back to 'on' dipped the beam a bit (putting them back to 'country' mode) and noticeably reduced the throw. Basically it has all the functionality of the M3/4 pre-lci lights but without tourist adaptation (attached).
08-14-2018, 06:47 AM | #2 |
Rep 735
Interesting! Can I ask what year you car is and do you think this feature would work on a 2014 car with adaptive LEDs?
A shame one has to twist the switch from Auto (from the left) to On (all the way to the right), but I've had to live with worse. That said, reading my manual it states; The light distribution is automatically adapted to the speed. The city light is active as of a speed of less than 50 km/h, 30 mph. The motorway light is switched on at a speed higher than 110 km/h, 68 mph after approximately 20 seconds or as a speed of 140 km/h, 87 mph. There is no mention that the switch has to be turned fully over to the right. |
08-14-2018, 08:00 AM | #4 |
Rep 19,982
Geeky, but interesting!
Do you know if the M3/4 adaptive LEDs are different to the standard F3x adaptive? I say this as my M4 headlights are way better than the 330e ones, when I thought they were the same system. I used to prefer the 335d adaptive xenons till I got the M4.
08-14-2018, 08:13 AM | #5 |
Rep 542
The F3x adaptive leds maybe different.
Mine are really poor with a cut-off which is far too close to the front of the car. I hate driving in the dark with no street lighting. The E90 adaptive xenons give a much better throw of light.
335d xDrive
08-14-2018, 08:39 AM | #6 | |
Rep 19,982
The xenons and the M4 absolutely maximised the distribution and the spread was very even, with no dark patches or areas.
08-14-2018, 08:47 AM | #7 | |
Rep 735
I'll take it over 87 tonight and pay closer attention |
08-14-2018, 10:09 AM | #8 |
Rep 310
My 440i has adaptive icon LED and the throw of those lights is quite a bit better than the standard LED's which are bright but have a lot of hot spots in front of the car without lighting up the kerb particularly well.
Certainly the LED icon adaptive are significantly brighter than the Xenon non adaptive and the adaptive Xenons main advantage - on the E90 that I had at least - was their ability to focus the beam on high beam and when travelling at speed on the motorway. The standard Xenons on e90 or F3x series don't do that and the LED achieves something very similar - except they are brighter than Xenon to start with. Haven't noticed the spread at town speeds being that much different - unlike my Adaptive xenons when it was VERY noticeable. Also the e90 adaptive Xenon cornering light was much more effective than the LED foglight that is used on the f3x |
08-15-2018, 09:11 AM | #9 | |||||||
Fool
1857
Rep 3,542
Pre LCI 4 series adaptive LED (no reason to doubt LCI ones aren't as good, just never experienced them - your comment implies they're still good) 3/4 series adaptive HID 3/4 series non-adaptive HID 3 series adaptive LED 4 series non-adaptive LED 3 series non-adaptive LED Quote:
