10-24-2015, 04:59 AM | #1 |
Rep 30
smart closer
Hi guys.
Do you know how do I code for smart closing of tail gate ??? I know 4 series (F36) and 5 series (F10) can active. I'v changed FEM_BODY --> CAM_SMART_CLOSE --> nicht Active to Active. It is succeeded LED flash but no gate close. Let me know and share how can I do it ??? Thanks. |
10-24-2015, 04:21 PM | #2 | |
Rep 129
Do you mind posting your HKFM cafd filename? I'm interested to know which version you're on. Let me dig through my notes and see if I can find the setting change. Thanks -Dan |
10-24-2015, 04:34 PM | #3 |
Rep 129
Here is what I found:
Search for FUNC_SMO in the HKFM module. Change it's value to 1. Let me know if it works. Here is the translation from the comments section. Tailgate closing function via smart opener on / off 0 : Function Smart Opener inactive 1 : Function Smart Opener active When the tailgate is closed , open by SMO is independent of encoding value always possible . Last edited by DanITman; 10-24-2015 at 04:45 PM.. |
10-24-2015, 05:18 PM | #4 | |
Rep 30
Thank you for your suggestion. My HKFM cafd name is 0000157F_008_000_003.ncd. Let you know my pofile as below for your reference. VIN=WBA3X12040xxxxxxx Production date = 09.10.2013 S322A Comfort access included ISTA/P version = P2.50.4 I-STEP = F020-13-07-506 Hope to suggest from you. Thanx |
10-24-2015, 05:28 PM | #5 | |
Rep 30
Year , I also found and change vert 0 to 1. However , still no function. Also , SMO_ONLY_CLOSE and FUNC_COMFORT_CLOSE changed to vert=01, but incompleted. Hoom... |
10-24-2015, 09:36 PM | #6 |
Rep 129
10-26-2015, 06:35 AM | #9 |
Rep 30
10-26-2015, 07:31 AM | #10 |
Rep 30
I found official news release as below.
https://www.press.bmwgroup.com/usa/p...tem=node__4101 According to 2015 GT changed , add smart close function newly. ************************************************** ************** 2015 BMW 3 Series Gran Turismo Changes to the standard equipment: •Deletion of the center console cupholder lid and the lid storage net in the glove compartment. •The door accents are now in interior world color (black or beige) regardless of the interior trim on models not equipped with Lines. On models equipped with Lines or M Sport, the accents on the doors are in the same material as the trim accent on the dashboard. •The time display in the instrument cluster is moved to the bottom right, under the tachometer. •The labeling of the memory button for the driver's seat adjustment is changed from "M" to "SET". An acoustic signal will be heard upon memorizing a position. Lines and Package changes: Luxury Line (ZLL) •Oyster Dakota leather (LCOM) is now available •Brushed Aluminum trim (4AB) is now available •19" light-alloy wheel W-spoke style 440 (2WG) is now also available with all-season tires as option code 2W9 on 335i xDrive Sport Line (ZSL) •Beige Dakota leather (LCDF) is now available •Dark Burl Walnut wood trim (4AB) is now available •19" light-alloy wheel double-spoke style 466 (2L8) is now also available with all-season tires as option code 2T8 on 335i xDrive M Sport (ZMM) •Fineline Anthracite wood trim (4CE) is now available Premium Package (ZPP) •Comfort Access (322) now includes the hands-free trunk closing function, similar in operation to the hands-free trunk opening function. Technology Package (ZTP) •Addition of a demo mode for Head Up Display. •Deletion of Enhanced Bluetooth and USB + Smartphone integration, now that Bluetooth Audio Streaming is standard. Driver Assistance Plus Package (ZDB) •The Active Blind Spot Detection is now also available in combination with M Sport (ZMM). The price of the package is therefore $1,900 in any configuration. Please note the following changes to standalone options for the MY2015 F34 3 Series Gran Turismo: •248 - Heated steering wheel (included in ZCW Cold Weather Package): a confirmation message will now be shown in the instrument cluster to make it clear the feature is activated. •2DY - 18" light-alloy wheel star-spoke style 396 now available as a standalone option on 428i / 428i xDrive not equipped with a Line or M Sport ($600) •4CE - Fineline Anthracite wood trim: now available outside of Lines at no extra cost •5AS - Active Driving Assistant (included in ZDB Driver Assistance + Package): now includes the attention assistant. •6NS - Enhanced Bluetooth and USB + Smartphone Integration is now a standalone option ($500). •LCOM - Oyster Dakota Leather: now available outside of Sport Line ($1,450 or included in Premium Package) BMW 3 Series Gran Turismo Pricing (including $950 Destination and Handling): 328i xDrive Gran Turismo $42,700 335i xDrive Gran Turismo $48,050 ************************************************** ****************** The point of view is just changed option S322 that smart close is added. I believe I can code it. |
10-26-2015, 03:22 PM | #11 |
Rep 129
10-26-2015, 04:37 PM | #12 |
Rep 30
10-29-2015, 08:02 AM | #14 |
Rep 129
I'll play with it this weekend and see what I can find out. Since my i-step version just recently was updated, I bet if I change my build date it will automatically activate. This will take me some time to confirm and then find out what is changing.
10-31-2015, 04:03 PM | #16 |
Rep 129
I had a chance to mess with this today and was not able to get it to work. I changed my build date to 0715 and it re-coded the module that controls the smart opener. I then played with some of the coding and I still wasn't able to find the correct values. I'm thinking something might need to be changed in FEM_BODY as well. I'll keep digging.
-Dan |
11-01-2015, 08:37 PM | #17 | |
Rep 30
Good try ! I also still not succeeded. I anticipate your report. THX
F34 320iGT 2013 OCT manufactured by Dingolfing , Germany |
11-02-2015, 07:41 PM | #18 |
Rep 129
Can you try another value for me. I won't be able to do any coding for a few days. Other cars with smart closing have this value as 1.
COMF_CLOSE_TRANS_FUNC_ON = 1 It would be helpful to get my hands on a newer car that has this feature working. I could then do a compare to mine and see what has changed. |
11-03-2015, 02:28 AM | #19 | |
Rep 30
Thank you for your replying. I also studied new info day by day. My friend (F34 2015 latest model) has sent me HKFM ncd file. It's file name is different of mine. friend : "cafd_0000157f.caf.008_001_005" mine : "cafd_0000157f.caf.008_000_003" And I found new parameter as you mentioned "COMF_CLOSE_TRANS_FUNC_ON" in my friend's cafd. There is no my cafd. So , I tried to inject to my car but I can not find it. According to specialist said , " U need update software by dealer or follow below file". https://mega.nz/#!VwIzGJJY!oHCQrh-ax...syn-9eEytBH1qo I have no time to upgrade myself now. So , please try it and respond me your result. Thank you.
11-03-2015, 06:24 AM | #20 | |
Rep 129
11-03-2015, 06:40 AM | #21 | |
Rep 129
11-04-2015, 04:13 AM | #22 | |
Rep 30
I got PSDZDATA56.3FULL in my PC now. But I follow your suggestion and will claim to dealer that I want to upgrade I-step. I appreciate your support and notice. Let me know how is your result. Succeeded or not...
