09-17-2018, 05:43 PM | #1 |
Rep 64
Driver Front Tire/Wheel Losing Air
Hello all,
Driver front tire/wheel loses air frequently. On cold mornings, I can expect to need to fill it up with my portable air pump. I also randomly need to air up even on warmer Southern California days. I definitely leaking somewhere. Both America's Tire and Sam's Club Auto have water dunked my wheel/tire and saw no leaks. I personally think it's a wheel issue, as this wheel was difficult to balance when I first purchased them. Does the below make sense? Any other suggestions to resolve this? 1. Mount/remount tire to see if it helps 2. Take it to a BMW service center, maybe they'll know? 3. Buy new wheel, tire, or both. Wheel: 19" 351m Tires: 245/40-19 |
09-17-2018, 06:58 PM | #2 |
Rep 5,457
Sometimes corrosion around the bead can cause this... although usually in snowier/saltier climates...
Id try to dismount tire from wheel and clean BOTH the mating surfaces of the tire and wheel real good (with grinder/sand paper). See if that works before ditching an other wise nice wheel and tire. |
09-18-2018, 11:23 AM | #3 |
Cheapskate
4447
Rep 4,993
I think the soapy spray solution is a better indicator for a slow leak. Mix some car wash with water in a spray bottle and spray it around the wheel/tire to see where it bubbles up. On my car I actually had a loose valve stem so it was a quick and easy fix.
09-18-2018, 08:00 PM | #4 |
Rep 64
I'll give the soap test a shot and then do a remount/cleaning if it is still a problem.
I suppose going back to stock is not really a big deal since I plan to trade the car in at the end of the year anyway. It's just I like to go into the mountains for hiking/fishing and don't want to be stuck out there unable to pump a flat up... Thanks for the suggestions! |
kern4174446.50 |
