02-16-2016, 09:54 AM | #23 |
Rep 104
That was an official release, not sure why it was hard to figure it out. Here is a more "official looking" release:
https://www.press.bmwgroup.com/usa/p...=T0216443EN_US |
02-16-2016, 11:04 AM | #24 |
Rep 263
Despite of no LCI also the F34 has the same new navigation version NBT Evo since 7/2015. Thus OTA is available as well (but not in all countries).
Anyway the F34 already got a lot of updates from 7/2015 on. |
02-16-2016, 12:15 PM | #25 | |
Rep 366
F34 (2019 330xi): Luxury, ZCV, Nav, ABSD, Alp White
F34 (2016 328xi): Nav, ZDA, Alp White F30 (2013 328xi): ZCP, Nav, PDC, Alarm, Shades, GS Metal [Ret] E90 (2009 328xi): ZCP, iDrive, BMW Assist, PDC, Alarm, Shades, SG Metal [Ret] E90 (2006 325xi): ZSP, ZCP, iDrive, BMW Assist, PDC, CA, Xenons, Shades, CrO3 Exhaust, TiAg Metal [Ret] |
02-16-2016, 12:39 PM | #26 |
Rep 104
That is what I've been saying all along. In US, F34 does not get NBT2 (read the press release again). Only the sedan and sports wagon do. I will have to go to UK to get into an F34 with NBT2. Sponsoring my ticket?
02-16-2016, 02:43 PM | #27 |
Rep 263
I´m not from the US. But just checked US BMW parts catalog (realoem.com) for a September 2015 F34 335iX and it states Head Unit High2 = new NBT2 Evo.
It is normal that they mention in their press releases mainly the details of the LCI models. But at the same also other models might get some technical updates. In Europe for example the F34 received at the same time "silently" also the new Nav Prof/NBT2, new B47 diesel engines, new AC control panel, new cup holder and so on - everything which was introduced in the F30/31 LCI. Last edited by TePee; 02-16-2016 at 02:51 PM.. |
02-16-2016, 10:08 PM | #28 |
Rep 366
No need to go to the UK. Go to your nearest dealer in USA and check out an MY16 F34 with nav. The Navigation System Version will read "NBTevo".
02-16-2016, 10:27 PM | #29 |
Rep 366
Interesting you mention this. I've noticed that the AC panel on USA MY16 F34s has white digits (in photos), instead of orange. That was a change with the LCI treatment noted in the LCI press release, which made no mention of the F34.
02-17-2016, 09:32 AM | #30 | |
Rep 104
And if you haven't yet sat in a 2016 F34, perhaps you should do that yourself first rather than taking comments from here and there. |
02-17-2016, 01:49 PM | #31 | |
Rep 104
http://parts.bmwofsouthatlanta.com/p...126809245.html http://www.realoem.com/bmw/enUS/part...&q=65126819421 suggesting it fits cars made as far back as in 2013. |
02-17-2016, 03:50 PM | #32 |
Rep 263
It is not easy to persuade you...
If you have a little bit to do with navigation or retrofits it is just known that HU High 2 is the new NBT2 or NBT Evo, which is the new navigation Professional. You can also recognize it on the pictures in parts catalogs at its smaller 1,5 DIN size (NBT1 is bigger 2 DIN): http://bmwfans.info/parts-catalog/F3...h_2/#6809245_1 You can also see that it is used for F30 models from 7/2015 and is not exchangeable with older part number headunits, just use proper parts catalog like here: http://bmwfans.info/parts-catalog/65126809245/ Last edited by TePee; 02-17-2016 at 03:56 PM.. |
02-17-2016, 04:29 PM | #33 | |
Rep 104
http://bmwfans.info/parts-catalog/65129389859 In any case, granted Headunit High 2 is with NBT2, I just don't think these parts websites will have it all correct always when it comes to minute differences between production of European vs. US vehicles. |
02-17-2016, 04:56 PM | #34 |
Rep 263
And if you now click on your linked site under "usage" at F30 then you will see on the following site that this part number is not used for 7/2015 F30!
If you do the same for X5 F15, then you will see that at this car it is used. Reason: X5 still uses the old NBT as it haven't yet received an update to new NBT Evo. Maybe you should believe real arguments and not just try always to find the opposite |
02-17-2016, 05:05 PM | #35 | |
Rep 104
http://s3.bimmerfile.com.s3.amazonaw...Series_LCI.pdf It explains clearly what Headunit High 2 is, and says explicitly that automatic map update is enabled through the updated telematics unit (Telematic Communication Box 2 TCB2). That was good reading! Now the question remains if US F34 has this new head unit. And again, I don't trust the parts websites. Some say one thing, and some say else. See for example, the following, which excludes F34. Note sure where these dealer websites populate their databases from.. http://parts.bmwofsouthatlanta.com/p...126809245.html |
02-17-2016, 07:41 PM | #36 | |
Rep 366
I don't think NBT2 headunit comes with 4G automatically. I *think* you only get 4G when you add the enhanced btooth option. Only based on others' posts! ("think" not "know") Per the press note, BMW is notorious for being incomplete. They never stated that the F34 did NOT get any of those features. In fact, there was a debacle the last time they updated navigation to NBT announced in early 2012. BMW was never clear as to what F30 models got it and when. It ended up that non-US models got it mid-year (11/2012) and they waited until 07/2013 to get it on US models. Many actually had to wait thru 12/2012 to see if US F30s would get it in MY13. So, I never take BMW announcements as settled law. Just keepin' it real, yo!
02-17-2016, 08:52 PM | #37 | |
Rep 104
(See for example bmwusa configuration site for 2 series convertible, it clearly says navigation system has map updates, and then EBT is an extra among options.) |
02-17-2016, 11:12 PM | #38 |
Rep 18
I received a navigation update today. It said I had to reset the navigation system or wait till next time I started the car. I have a 2016 328 gt west coast USA. Is that the ota update you are talking about?
02-18-2016, 07:43 PM | #39 |
Rep 366
Why yes it is.
02-19-2016, 09:00 AM | #40 |
Rep 104
Well I guess this settles it. It means OTA map updates can indeed happen over a 3G connection, which I earlier thought was absolutely not possible. There is no official BMW documentation that I could find which suggests about this possibility. So it is indeed very vague communication by BMW. All press releases seem to suggest that it the the 4G LTE connection that is enabling the OTA map updates.
02-19-2016, 10:01 AM | #41 | |
Rep 366
BMW is known to be a precise manufacturer, but not a precise communicator IMO. We cannot get the navigation/iDrive manual electronically. It's only in hardcopy with the BMW. The regular users' manual has sparse details about nav. Sometimes I think they are playing games with us; maybe it's a marketing scheme to keep us invested.
02-19-2016, 10:19 AM | #42 | |
Rep 104
http://f30.bimmerpost.com/forums/att...9&d=1441950445 On p-34, it says that 3 series LCI (which has NBT2) has 3G connectivity as standard. It has 4G LTE reception only when you add 'Enhanced Bluetooth option' (code 6NS). I am assuming the same applies to 2016 F34. |
02-21-2016, 02:37 AM | #43 |
Rep 10
hahaha
2015 435i Coupe / Black Sapphire Metallic / M Performance
