BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Exhaust tips - Secure fitment
      03-24-2019, 11:24 AM   #1
KTE
Drives: A slow car
Been in two minds about either Carbon (which everyone has..) or burnt titanium style. I really like both.
Digging a little deeper I found these, obviously not OEM fitment but has a clamp tightened with a bolt.
Has anyone had experience on any car with this style of exhaust tip? I’m more concerned it falls off on a random A road or motorway drive causing problems.
Converse of that is OEM is spring clips only, but as they’ve been on for so long don’t seem to budge unless hit with a hammer/mallet.
Outlet is even 4”, the next largest alternative are the BMS 3.5”. I’ve read most couldn’t fit BMS onto a MPE, but others have so at this price I’m happy to take the risk
NB: I would want these to initially fit on standard dual exit exhaust, then a MPE which I’ll either sell the tips from, or purchase without any.
https://ibb.co/8MKnVnY
      03-25-2019, 09:34 AM   #2
KTE
Drives: A slow car
Bump?
      03-25-2019, 02:23 PM   #3
skipraider
skipraider's Avatar
398
Drives: F31 BMW 335i
Not sure about the carbon ones, but there have been a few posts about the BMS tips on here and how quickly they corrode.
      03-25-2019, 03:11 PM   #4
xpro
Drives: 335XD
I got some carbon ones "Akrapovic" 63-89mm from Alixpress for around 20 aside. Be aware 100mm outer diameter will not fit the bumper cuts.
63mm is the closest fit, as the OE external diameter is 61mm. There is a bit of play but the clamps are strong enough to hold them well.
What I did with mine, as the tips are slitted, they compress when the clamp is tightened, I slightly cut the slits to make them even wider to give them more room for a better compression when clamped.
The quality of these exhaust tips is unreal. Titanium steel with carbon finish and a real quality clamp.
https://www.aliexpress.com/item/Inle...4-042871f42a5c
APJ245.00
      03-26-2019, 06:44 PM   #5
KTE
Drives: A slow car
Managed to find 89mm outer diameter, I’m just dissapointed that 4” (100mm) wouldn’t fit based on your comment.
I really like the look of a pair of exhaust tips I saw on a RS and they were massive, maybe 4.5”
Is it the added carbon sleeve at 4” that makes it too thick to fit the diffuser cuts?
      03-27-2019, 04:42 PM   #6
PJJD
PJJD's Avatar
Ireland
101
Drives: Sakhir Orange II F32 M Sport+
I had 101mm (4") tips on my GC and they fitted fine
      03-28-2019, 03:46 PM   #7
APJ
APJ's Avatar
Drives: F36 435d M Sport Plus
Cheers for the info, just ordered some of these for mine
      04-01-2019, 11:09 AM   #8
APJ
APJ's Avatar
Think it depends on where you have obtained the rear diffuser from , mine came with the car, but its not a genuine part, i've jut ordered some 63/89's tailpipes to go on mine, but i have noticed even with those that a little bit of trimming will be required
      04-01-2019, 12:24 PM   #9
hilift
Drives: 330d f31 msport
I don't think you should worry about them coming off .as I have a pair of akropovic cans on my bike , fitted with similar style clamps .I be done 15,000 miles with no probs at all .
      04-01-2019, 12:28 PM   #10
APJ
APJ's Avatar
Not worried about them coming off at all, i was talking about the space for the two tailpipes.
Though the hardest part will be to get the old tailpipes off, but we will get there eventually, even if i have to take them to my mate's garage.
      04-01-2019, 03:01 PM   #11
hilift
1mm cutting disc on an angle grinder no bother .!!!
      04-02-2019, 03:42 AM   #12
APJ
APJ's Avatar
Not quite what i had in mind !!
      04-03-2019, 07:07 AM   #13
xpro
Drives: 335XD
Nice one. Just hope you ordered 2 pieces as the photo is misleading in showing 2 pipes but you receive only 1 as I have discovered.( small print lol) So another 3 weeks of waiting for another pipe.
The OE tail pipes come of very easy, jut get some wood behind it and tap it gently with a hammer and they literately just slide off.
Good Luck
APJ245.00
      04-03-2019, 10:53 AM   #14
APJ
APJ's Avatar
Good Luck
Cheers, yes i did remember to order two, didn't think they's send two for the price it was showing, delivery was more expensive than a single pipe !!
      04-19-2019, 08:17 AM   #15
KTE
Drives: A slow car
Ordered the ones from the original link, will update when they arrived and attempt to fit.
      04-25-2019, 02:08 PM   #16
APJ
APJ's Avatar
Can't believe it, just waited a month for the two tailpipes to arrive and guess what they have sent me 68/73 by 89 tailpipes, so even fully clamped they still slide off . But now realised another problem that the 89 width will not fit side by side off my backbox, worked it out to be around 80 for each tailpipe for them to fit properly, ah well back to the drawing, but one thing i'm not doing is waiting another month for any replacements to arrive
      04-25-2019, 03:31 PM   #17
xpro
Drives: 335XD
Ah man thats shit buzz.. I also had to wait the second time round due to one 1 being dispatched..
Anyways, mine arrived and all fitted. So far so good.
      04-25-2019, 06:57 PM   #18
APJ
APJ's Avatar
Looking good there, my other other problem is, they are both on the left hand side, standard exhaust booo
Probably explains why the 89's wont fit side by side
      04-26-2019, 02:59 AM   #19
asif03
asif03's Avatar
Drives: 2016 430d Coupe
I've seen some twin exhaust style ones on AliExpress. See link - https://www.aliexpress.com/item/2-Pi...hannel=twinner
A touch more expensive and I can't vouch for quality but I'd imagine they'll fit.
      04-28-2019, 01:50 PM   #20
APJ
APJ's Avatar
Cheers, unfortunately though they wouldn't work as there are two pipes that come out of the back box not a single one
      04-29-2019, 02:14 PM   #21
asif03
asif03's Avatar
Ahh my bad!
      04-29-2019, 05:19 PM   #22
APJ
APJ's Avatar
Ahh my bad!
Its okay, just need to look for some that are 63 x 80, they should fit side by side
435 coupe, exhaust, exhaust 435i, exhaust tips
