06-03-2020, 08:18 AM | #1 |
Rep 497
Disconnecting car battery from Neg or Pos terminal? Is there any difference?
I've heard that some car settings can be reset by disconnecting the battery. From which terminal? Or would there be no difference, whichever terminal is disconnected?
Thanks, |
06-03-2020, 10:44 AM | #3 |
Rep 16,072
Everything I've seen says negative. The logical reason for that is if you put a wrench or driver on the positive terminal and touch it to the chassis with the negative in place you'll get a very unpleasant result. As for the car settings, anything stored in iDrive memory isn't affected by disconnecting the battery, as the memory is non-volatile. You may have to reset the clock, but even that will reset itself if you have nav. The main reason to disconnect the battery is if you unplug some items, the seat belts or air bags for instance, while the battery is connected that can cause fault codes to be thrown, and the only way to clear them is with an OBD diagnostic and repair tool.
06-03-2020, 03:53 PM | #6 |
Rep 923
Haha! In Australia they need to install the battery upside down.
06-03-2020, 04:29 PM | #8 | |
Rep 29
06-03-2020, 09:04 PM | #11 |
Gettin It Figured Out
1820
Rep 2,669
HA!! I see what you did there....🍻 .
06-05-2020, 03:40 PM | #12 |
Rep 497
06-05-2020, 03:48 PM | #13 | |
Rep 3,752
Example are old Jaguar and Austin Healey( when I mean old... i mean classic old) Enjoy |
06-05-2020, 05:27 PM | #14 |
Plank eyed saint
66
Rep 55
Drives: 2018 440i Gran Coupe M-Sport
To reset your electronics, you disconnect the source of energy, which is the anode, or negative terminal. Once you disconnect the negative terminal, you can apply a load to the system, such as putting on your 4 ways or pumping brakes to discharge remaining electrons from the system.
Disconnecting the positive terminal will only create a potential for arcing with the chassis ground or positive wire, since they are still being supplied energy from the anode. Hope this helps. |
