06-05-2020, 01:38 PM | #1 |
Rep 31
My key won't work! Help please
Hey guys so I have a 435i and my key won't work. I changed battery twice. Still didn't work. Checked and replaced damaged fuses, still nothing. I even got my key checked to see if it's working and it's 100% functional. I was told that it could be the module but most likely the antenna that is in the back of the car. I know if I replace it it'll need to be coded but I can't seem to find the part or the part number anywhere. Any help would be greatly appreciated! Thanks so much
06-05-2020, 02:02 PM | #4 |
Rep 7,480
Which aspect of the key isn't working? The remote fob performs multiple operations that are kind of separate/independent of each other:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-05-2020, 02:28 PM | #7 |
Rep 31
So it won't unlock or lock or start the car. I'd have to remove the metal piece to unlock and lock the car and put the key up to the steering wheel for it to turn on and it's getting so annoying 😭
06-05-2020, 02:29 PM | #8 |
Rep 31
06-05-2020, 03:56 PM | #9 | |
Rep 7,480
Just an FYI (for those that don't know)...the battery is used to power the remote for locking/unlocking & arming/disarming the car. For starting the car...the remote is self powered through induction. There's a ring antenna behind that little icon on the steering column that powers up the transponder chip inside the remote that allows the remote to communicate with the CAS/BDC/ECU/DME control modules which need to share the encrypted individual serial number (ISN) assigned specifically to your car. If that ISN doesn't match in all components the car won't start. So even with a dead battery inside the remote...you should still be able to start the car by holding the remote next to the little icon on the steering column. That's why it was asked as to what feature of the remote wasn't working.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-05-2020 at 04:02 PM.. |
06-06-2020, 12:07 AM | #10 | ||
Rep 31
06-06-2020, 08:43 AM | #11 |
Rep 5,995
If the car is under warranty I would bring it to the dealer. But looks like holding it to the steering column works so it's not receiving power from the battery as stated. Are you sure the 2nd battery you used wasn't DOA? Sometimes these Amazon batteries are garbage.
06-06-2020, 03:49 PM | #12 |
BMW CCA #257
75
Rep 190
I had a problem with the remote and replaced the battery and it still did not work. I solved the problem by cleaning the contacts in the remote (inside the remote and on the cover) with alcohol. The remote picks up moisture in your pocket and deposits can attach to the contacts. Problem solved.
2014 F31 328 xDrive Touring
2020 G20 330 xDrive Sedan 2023 G01 X3 xDrive BMW CCA # 257 |
