02-16-2024, 06:10 PM | #1 |
Rep 60
do i have vss??
i have a 2015 bmw 428i xdrive
my vin: WBA3N5C50FK198110 i need to replace my steering rack, i just can’t figure out if i have variable sport steering or not. any feedback would be appreciated, i don’t think i do but i’d like to know before i spend the money on a steering rack. |
02-17-2024, 10:28 AM | #2 |
Rep 767
Have you checked realoem.com? That should have the info your looking for
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
f32christian18.50 |
02-17-2024, 10:49 AM | #3 |
Rep 886
If you had VSS, you’d have the Option Code S2VLA associated with your VIN.
f32christian18.50 |
02-18-2024, 04:25 AM | #4 |
Rep 161
Seems you don’t have it:
01CA Selection of COP relevant vehicles 01CB CO2 package 0248 Steering wheel heater 0258 Tire with run-flat functionality 02DW BMW LA wheel, Star Spoke 393 02TB Sport automatic transmission 02VB Tire pressure display 0319 Integrated universal remote control 0322 Comfort access 03AG Reversing camera 0403 Glass roof, electrical 0423 Floor mats, velours 0430 Interior/outside mirror with auto dip 0431 Interior mirror with automatic-dip 0459 Seat adjuster, electric, with memory 0465 Through-loading system 0488 Lumbar support, driver and passenger 0493 Storage compartment package 0494 Seat heating driver/passenger 04AB Fine wood trim burr walnut 04DM Accent strips, pearl-gloss, chrome 04NE Blow-by heater 0502 Headlight cleaning system 0508 Park Distance Control (PDC) 0521 Rain sensor 0522 Xenon Light 0524 Adaptive Headlights 0534 Automatic air conditioning 0544 Cruise control with brake function 0563 Light package 0575 Supplementary 12V sockets 05DS Emergency release, luggage compartment 0609 Navigation system Professional 0645 BMW US Radio 0655 Satellite tuner 0676 HiFi speaker system 0697 Area-Code 1 for DVD 06AC Intelligent emergency SOS call 06AE Teleservices 06AK Connected Drive Services 06AM Real-Time Traffic Information 06AP Remote Services 06NH Hands-free with USB interface 06WA Instrument cluster, expanded equipment 0823 Hot-climate version 0845 Acoustic belt warning 0853 Language version English 08KL Oil service interval 15,000 km/12 months 08S4 Decoding variable light distribution 08TN Daytime run.lights adjus.via light menu 0925 Dummy-SALAPA 0992 Control of number-plate attachment 0993 model year code in VIN 09AA Outer skin protection A090 90 AH AGM battery LEDE Leather trim |
f32christian18.50 |
02-18-2024, 11:24 AM | #5 |
Rep 1,372
I'd do a search for those who did a VSS retrofit. If it is a 1-to-1 swap, there is no fear that if you ended up with a VSS rack you wouldn't be able to put it in the car. My guess is that most rebuilt racks are probably fixed ratio racks. I haven't see a great demand for VSS so rebuilt VSS racks are probably rare. Since there is a change in ratio (steering wheel input angle vs front wheel angle) I would guess there is some programming involved to correctly tell the car what angle the wheels are at. Stability control may use this information in determining how to react to a loss of control situation.
f32christian18.50 |
02-18-2024, 11:32 AM | #6 |
Rep 60
thanks for all your guys input. i’m pretty sure i don’t have vss, but only concern i have is when i look on realoem.com for my car it shows the steering rack that is for vss according to the site where im buying the new steering rack from. i’m just gonna take my car to my local mechanic shop and have him identify which rack i do have. for now ive just been driving in sport which definitely stiffens my steering a decent amount until i do so.
my problem with my car in the first place is i have a lot of play in the steering and a slight drag to the right. everything else has already been checked and both of my close mechanics have already concluded it’s my steering rack. but i’m just gonna drive in sport which does honestly help a lot with the play or loose feeling in the steering but it does still have the slight drag until i do eventually replace the steering rack. i just know that the electric steering racks have always been a problem with these cars |
02-18-2024, 01:02 PM | #7 | |
Rep 1,372
To change the piston, BMW has a kit (Genuine BMW Steering Rack Repair Kit 32106891974). Probably going to run about $100. Make sure it includes the magic grease. Don't get creative here. Use the grease for that job. Any sh*t won't do. Plus don't buy some cheap-o knock off kick. Get a real kit from BMW or one of the big online guys (FCP, ECS, etc) selling legit BMW parts. It's your steering. Then you will also need a magic tool to take off the cap of the piston (likely in the kit). WARNING: Don't lose the spring or get confused with the old and new. Old parts out completely. New parts in. Loose any component and . . . you need a new kit. TIP: Clean the area around the piston first. Dirt is not supposed to get inside of it. Use a clean set of gloves on re-assembly. Follow instructions very carefully when putting the cap back on. Again, an oopsie won't do here. Despite the hassle, it's going to be a lot cheaper than $800 + 4-6 hrs of labour. From what you describe, this has a good chance to fix your issue. I swapped it on mine after 5 years.
02-18-2024, 01:04 PM | #8 |
Rep 60
casualDIYer
i’ve actually already replaced that bushing bought the tool and everything it did stop the noise that the steering rack made but didn’t stop my loose feeling unfortunately. |
02-18-2024, 01:40 PM | #9 | |
Rep 1,372
Damn!
f32christian18.50 |
02-21-2024, 12:11 PM | #10 |
Rep 482
So as far as I understand it there are 3 different steering specs-
Base S216A - Hydro steering-servotronic S2VFA - Variable sport steering Based on your VIN, I'm not sure you're looking at the correct steering racks. As previously mentioned, there is a genuine BMW Power Steering Thrust Repair Kit, but it is only applicable for ThyssenKrupp steering racks. Are you sure you have a ThyssenKrupp steering rack, and not a ZF steering rack?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
02-21-2024, 04:13 PM | #11 |
Rep 5,457
Drives: F30
rlesko do you know which rack is installed on vehicles optioned with S216A - Hydro steering-servotronic ?
02-21-2024, 06:32 PM | #12 | |
Rep 482
I only even became aware of these differences when I was reading up on the steering rack repair kit install and many people who went to install it realized the kit did not apply to their vehicle (They have ZF rack).
02-22-2024, 02:10 PM | #13 | |
Rep 5,457
Drives: F30
02-22-2024, 02:15 PM | #14 |
Rep 775
variable sport steering will not work on a used rack without some pretty heavy work. The EEPROM will need to be reset. To get VSS to work, you'll need an FSC code for your VIN number. If the used rack already had a VIN in it (it does because it's used) then any FSC code you obtain will not work, and VSS will not work.
rlesko234.00 |
02-22-2024, 05:59 PM | #15 | |
Rep 482
