01-07-2019, 07:52 PM | #23 |
Rep 1,677
XxThe_RemedyXx It does look like the zinc didn't properly set on the inside part where there's the rust buildup and we apologize for this. However, this will not affect the rotors all since the pads don't touch that specific area. As stated, you can spray that area with a black high temp caliper spray paint to prevent it from rusting.
As for the center hub and the outer rim of the rotors where it is "white" you can say, that's just because you live on the East Coat where there's salt and snow. This shows more on the black zinc coated rotors compared to the silver zinc. The Carbon Geomet rotors which have the Geomet coating isn't really affected as you can see because it's an overall stronger coating and holds up better in conditions where there's salt and snow. |
01-07-2019, 09:14 PM | #24 | |
Rep 2,653
Are there any options under warranty where we could get these swapped out for Geomet rotors?
01-08-2019, 12:01 PM | #25 |
Masterchief
362
Rep 1,012
why did you get geomet for the fronts and eline for the rears?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-08-2019, 12:12 PM | #26 |
Rep 2,653
E Lines were originally purchased for the whole setup but one of the front rotors was warped on arrival. R1 was good enough to send me a replacement set of Geomet front rotors under warranty and they have been great since.
01-08-2019, 12:39 PM | #27 |
Rep 1,677
Unfortunately we warranty our rotors for 1 year only on warping or cracking. I can help you out a get you a discounted set for the rear rotors in our Geomets if you're interested.
01-08-2019, 01:11 PM | #28 | |
Rep 2,653
01-08-2019, 04:01 PM | #29 |
Rep 1,572
Still unanswered is: "What is that gouged line or crack on the rotor in the 3rd and 5th photos running from the center to the outer edge. That should not be there."
01-08-2019, 04:09 PM | #30 |
Rep 2,653
Absolutely, looks like a hairline crack to me. I will investigate when I get home from work and update. Currently driving my wife's car because rain
01-09-2019, 02:15 PM | #31 |
Combined Applications Group
1059
Rep 680
looks more like a pad imprint which is common to see when brakes are hot and you have the pedal down for some time - waiting at a red light
01-10-2019, 09:00 AM | #32 |
Rep 1,572
To me, that appears to be gouged out and not pad material deposited on that spot. XxThe_RemedyXx can you confirm if that is pad material by scratching it off or a depression?
01-10-2019, 09:07 AM | #33 |
Rep 2,653
Hey bud, definitely not pad material, it's a gouge. Not sure why this happened but my calipers and pads are on correctly, no noise or rubbing.
01-10-2019, 11:38 AM | #35 | |
Rep 2,653
01-10-2019, 06:52 PM | #37 |
Rep 2,653
Kevin from R1 is making things right. Customer service is top notch.
01-16-2019, 10:46 AM | #38 |
Masterchief
362
Rep 1,012
Put on the carbon geomet and looks great
r1concepts89.50 XxThe_RemedyXx967.00 |
01-16-2019, 10:52 AM | #39 |
Rep 2,653
Nice! The Geomets are great. I'm waiting for my rears to come to complete the setup.
01-23-2019, 07:15 AM | #40 |
Rep 2,653
Just had my rear rotors replaced with the Geomets. Night and day...
01-23-2019, 10:28 AM | #41 | |
Masterchief
362
Rep 1,012
have you had any weird noises?
01-23-2019, 10:35 AM | #42 | ||
Rep 2,653
yoon_209362.00 |
01-23-2019, 10:36 AM | #43 |
Masterchief
362
Rep 1,012
you can definitely hear it when the sound can bounce off something, but its significantly audible when the windows are down, does this sound ever go away?? ive been reading that others are saying the same thing and its the nature of the rotors
01-23-2019, 10:38 AM | #44 | |
Rep 2,653
