08-20-2018, 01:35 PM | #1 |
Rep 59
Starting the mod process, couple questions
So I think I'm ready to start the modding process but very slowly and very selective. I'm being selective because i did get an extended warranty for the additional 4 years and would try to not to void it with performace parts that i can clearly identify wouldn't be the root cause of something. First i want to get a catted downpipe; but will this throw a CEL? And from what im reading the only way to not have a CEL is with a jb4 or BM3 tune, correct?
Next i was thinking about a charge pipe and with all the threads on this im pretty well informed that yes it would void my warranty, however i doubt there would be in any way they could prove that a aftermarket charge pipe could cause any problems, correct me if im wrong. Then i was thinking about getting a jb+, would that clear the code of the CEL from the downpipe? I believe my car is fast enough as it is therefore im not really interested in pushing my car with a stage 1 or 2 tune. Any advice would be appreciated and i understand these topics are highly debatable and I'm not trying to start a war just trying to get an idea of what people think about this setup to start. I have each brand of performance part picked out so no need to sell me on whatever one you have on your car. DISCLAIMER: I did a forum search for these topics and they all turned into a war and was hard to follow what was going on! Thank you in advance for your advice and knowledge it will be greatly appreciated! |
08-20-2018, 01:53 PM | #2 |
no relation
130
Rep 442
The JB+ is a simple boost controller and does not have ability to suppress CEL, if you get JB4 or any other tunes, the JB+ is not needed or required (the JB4 is more advanced version of JB+). This is what most people get that just want a simple tune/boost to their power without modifying much else (it literally takes less than 3 minutes to install/remove). JB+ does not have ability to adapt/take advantage of your other mods (it simply tricks the ECU/DME into providing more boost). A lot of those on lease or still under warranty will go with this option.
Depending on which version of JB4 you get, it may or may not suppress the CEL from catless downpipe. IIRC, the newer versions of JB4 CANNOT suppress CEL codes. BM3 should have the ability to suppress CEL without issues, however it is a full flash tune and most likely easier to detect from a warranty perspective (however I do not know this 100%). Instead of a catless downpipe, I would recommend getting aftermarket interooler and CP upgrade first. The CP in the N55 engines are a bit weaker and known to pop off/crack, so I would get this first and foremost before increasing power. |
08-20-2018, 02:06 PM | #3 | |
Rep 59
08-20-2018, 02:29 PM | #4 |
Rep 4,314
while posting here in the "general" subforums is perfectly fine, you'd get much better response in the N55 subforums, here...
https://f30.bimmerpost.com/forums/sh....php?t=1473388 regarding warranty, since the downpipe and piggy back sport tune you are considering add hp/torque, they are also your biggest warranty liability. even if removed, both leave trace that is detectable if the need arises. although you have your brands picked out, you should know, not all catted downpipes are equal. be sure it has a 300-cell catalyst(typically by HJS Euro) if you want the highest possibility of no CEL. HFDP with 300-cell usually cost $1300 and up. only flash and early jb4 piggy can clear CEL. sport piggy back cannot clear CEL. |
08-20-2018, 02:45 PM | #5 | |
Rep 59
08-20-2018, 03:41 PM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3124
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Agree with uncleruckus post. It's thought out & logical for a lite tune. Ran a similar JB4 package in a 335is (N54). My N55 is a JB4 only.
The JB4 gives a lot more usable functionally than the JB+. My stock charge pipe broke twice at 18.5PSI. The FMIC will not give you more power but will retain what you have longer. Flash tunes will usually trip a counter in the ECU where piggy backs tend to slip through undetected without a serious look by the tech people. Some flash tunes claim to spoof the counter but have no experience with one so can't comment.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
Breezin20.00 |
08-20-2018, 04:12 PM | #7 |
Rep 10,249
First - welcome and congratulations. 2015 BMW 335i xDrive sedan is a great vehicle. I owned 2013 version of the same vehicle.
Modifications typically fall in several major categories - each one with a prioritized list and budget of course. 1. Engine performance 2. Suspension behavior 3. Wheels / tires 4. Cosmetic 5. Audio / entertainment / navigation 6. Preventive (charge piple replacement would be one of the first items) N55 engine can be tuned within a wide range but it does have an OEM charge pipe made of plastic. Replacement charge pipe from Evolution Racewerks is about $300 + 2 hours labor. Looking forward to updates about your mods! |
08-21-2018, 09:54 AM | #8 |
Respect My Authoritah
368
Rep 873
As someone previously mentioned, go for the chargepipe and intercooler before you touch the DP. Don't spend $900 on a Dinan intercooler though. There are cheaper options with great performance. I went with Active Autowerks for $350 and couldn't be happier. Wagner, ATM, AA, and VSRF all make good intercoolers for well below the cost of Dinan. If you can find a used Dinan one, go for it! I wait until I find their stuff used because of how spendy it is new.
For the CP, ER is a great brand and is probably the most popular (high quality) brand for the N55. Replace this before you do anything else, as they are known to blow at stock boost pressure. The mod war is real. It's pretty hard to suggest something without someone else attacking your choice for being too expensive, cheap, whatever.... Watch your back and start modding!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
Breezin20.00 |
08-22-2018, 09:03 AM | #9 |
Rep 59
Thank you all for the advice, the charge pipe is at the top of my list for my first "Mod" that being said i will be getting the ER CP it seems to be a popular must, and it looks like i will be adding the FMIC 2nd in line after the CP. I'm starting to believe that dinan is basically BMW with the same price, which doesn't seem logical to pay that amount for something like you guys have said, there are other options. Out of curiosity how hard would it be to change out the FMIC on my own, i believe I'm pretty mechanically inclined but when it comes to fabrication to make things fit that is where i draw the line. Thank you all again. As for the jb4 would it make more sense to get that first and maybe think about the DP later on?
08-22-2018, 09:12 AM | #10 | |
368
Rep 873
If you have the time and money, buy the CP and FMIC together and install together. The hardest part about the FMIC install was getting the old pipes off the old FMIC. Definitely go for the tune before the DP. Some tunes take the DP into account.
Breezin20.00 |
08-24-2018, 03:02 AM | #11 | |
Rep 181
Have fun! |
08-24-2018, 03:21 AM | #12 | |
Rep 366
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
Breezin20.00 |
08-24-2018, 05:33 AM | #13 | |
Rep 5,776
A DP does improve sound, but if that is the goal, might as well go for an exhaust and call it a day. |
Mountain_Commando303.00 |
