11-13-2020, 11:29 AM | #1 |
Rep 414
BM3 8AT trans tune upshifting too many gears in comfort mode causing lugging in city
Does anyone else experience BM3 8AT trans tune upshifting too many gears in comfort+non-sport trans mode when cruising around town? If I am driving between 25-50mph in town the trans tune will put me into a gear that runs at 1050-1200rpm. This causes the car to lug if I press the throttle gently, so I have to throttle hard to force a shift, change to sport trans mode or paddle shifters to deal with this. Right now just running manual shift mode to deal with it.
I've got a ticket open with PTF, just need time to grab some logs but wondering if I am not the only one. I expect to hear feedback that I shouldn't be driving a tuned car in comfort but my wife likes to take the car out as well and just wants to get in and go without playing around with settings. Appreciate any feedback
328ix 8AT Sport Line N26 | Navardi Custom Stage 2 93 | xHP Stage 3 | VRSF 5" HD FMIC | ER CP | ER Catted DP CTC | aFe Pro Dry S | MST Turbo Inlet | TMS Upper Air Intake Tube | 2nd Cat X | GFB DV+ |
11-15-2020, 08:35 AM | #3 |
Rep 414
I agree it lugs a little stock but it doesn't slip up that extra gear and usually remains in the 1350rpm+ range. I just hate it going down to 1050-1150rpm range.
11-17-2020, 06:27 AM | #4 | |
Rep 159
PTF modified my S1 tune so that it's stock until 2000RPM and then it gradually turn into normal S1 tune figures. This makes the transmission to shift more easily on those low RPM low throttle situations. It still lugs more than stock but is acceptable now. Of course there's now only stock amount of torque available below 2000RPM but I guess that just makes it less stressful for the engine anyway so I don't complain. Sport mode keeps RPM above that anyway so I can use it if I really need more power quickly. I don't fully know what causes this though. Some of it is because of added low end torque but it doesn't explain all of it. I guess my tuned 320i is close to stock 328i figures but stock 328i doesn't lug that much. Even xHP didn't fully remedied the issue for me so there got to be something else PTF should alter in their tune. I just don't know what and I guess they don't know either |
GreenF30N26153.00 |
11-17-2020, 10:04 AM | #5 | |
Rep 414
11-17-2020, 08:52 PM | #6 | |
Rep 24
what i found out is that when i drive at around 80km/h at highway, with bm3 8at tune, it will go lower rpm compare to stock (eco mode tested), i think this is due to bm3 tune will go upto 8th gear while stock only goes upto 7th, plus i also find that the steer wheel will vibrate when i want to put more gas to takeover at around 80km/h. |
11-19-2020, 10:19 AM | #7 |
Rep 356
FYI... The new g20 allows the motor to lug down to below 1000RPM, around 750-800 when booting around town. I believe it is all in an effort to conserve fuel / emissions.
2016 340i | M-Sport | Mineral Grey | Coral Red | Bone Stock
11-19-2020, 11:23 AM | #8 | |
Rep 414
11-19-2020, 11:26 AM | #9 |
Rep 414
really? that's horrific. BMW, and I am sure other auto makers as well, do all kinds of weird stuff to meet dumb standards. But this really confirms that BMW really only cares that the cars last the length of the warranty. unfortunate
11-19-2020, 06:31 PM | #10 |
Petrolhead
1942
Rep 3,521
Really? The M340i? My G20 330i doesn't do that. Or at least, mine doesn't. Lowest I've seen it fall in eco pro with shifter in D was around 1100-1200RPMs?
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
11-20-2020, 05:39 PM | #12 |
Petrolhead
1942
Rep 3,521
Ahhh. They might be re-tuned the 2021. I wouldn't ever want my car to lug. Which is why I always drive in S instead of D.
Current:
03-15-2021, 08:20 AM | #15 |
Rep 414
03-15-2021, 10:06 AM | #16 | |
Rep 29
03-15-2021, 12:55 PM | #17 |
Rep 414
I think if everyone impacted opens a case with PTF we could get some momentum for them to change the tune. Agreed it doesn't make sense to have the gears up-shift the way they do on comfort.
03-15-2021, 03:59 PM | #18 |
Rep 75
So for someone who hasn't flashed BM3 yet (me)... it sounds like i should avoid flashing the transmission for now. I will stick with just a stage 2 flash. I am often at slow city speeds so I do not want to run into this lug issue people are talking about.
03-15-2021, 06:24 PM | #19 | |
Rep 29
03-16-2021, 12:24 PM | #20 | |
Rep 414
let us know how it goes |
03-16-2021, 12:41 PM | #21 | |
Rep 414
1) The trans tune helps support the stage 2 tune with better clamping during shifts. This should benefit the longevity of the transmission with the stage 2 tune. No alternative to this if you don't use the trans tune, but many people have run the stage 2 tune without the trans tune so it may not be necessary. 2) Trans tune causes upshift while cruising in city in comfort mode which leads to lugging. Obviously not good, but you can avoid this by changing comfort to sport or sport+ mode or moving trans shifter into sport. Allows you to keep the trans tune but you will lose some gas mileage since you can run comfort mode in city. 3) Tune both then take logs and work with PTF to see if they can fix the trans tune shifting. Likely the best option since you should datalog and get them to review after you flash stage 2 to ensure everything is clean. |
03-16-2021, 06:27 PM | #22 | |
Rep 75
