07-19-2020, 04:16 PM | #1 |
Rep 190,750
Active Autowerke B48 Catted Downpipe *** NO CEL GUARANTEE ***
Order Link
https://store-gd6olw6.mybigcommerce.com/active-autowerke-bmw-b48-f3x-230i-330i-430i-catted-downpipe/ Active Autowerke BMW B48 Catted Downpipe BMW introduced a new valvetronic, single turbo version of its direct-injection engine for the later F-Chassis models beginning in 2016. The Active Autowerke B48 downpipe for the 230i, 330i and 430i helps unleash some of the potential that is restricted by the OEM downpipe. Turbochargers are powered by spent exhaust gases created during the combustion process. The quicker these gases are evacuated, the better. Unfortunately, the factory down pipe in the B48 is quite restrictive, which results in slower exhaust gases and slower turbo spool. The Active Autowerke F-Chassis B48 Signature down pipe utilizes 3 inch diameter stainless steel piping in order to provide more power, quicker spool, and extreme durability. We've incorporated a stainless flex joint and then tapers down to 70mm to meet the OEM exhaust system. We never drop the diameter less than the stock diameter of 70mm. This variant includes a 4.5" high flow GESI catalytic converter that will NOT produce a CEL! The GESi® G-Sport Ultra High Output Catalytic Converter features full 304 stainless steel construction, including the substrate. GESi® UHO-Series Catalytic Converters are EPA certified in 49 states and fully OBD2 compliant, perfect for use on 1996 and newer vehicles. GESi® proprietary precious metal loading technology ensures greatly reduced emissions, eliminating most "Check Engine Lights". These high flow catalytic converters outperform stock converters and provide a reliable solution to the most common catalytic converter problems. The GESi® UHO-Series Catalytic Converters are rated for engines putting out between 500 and 850 horsepower while maintaining a high flow capacity. The reduced back-pressure from this high flow catalytic converter will allow you to maximize your engines horsepower without the harmful emissions. Say goodbye to Check Engine Lights and failed emissions tests! Please Note: These catalytic converters are not legal for use on vehicles registered in the state of California as a result of California Vehicle Code Section 27156 and 38391. Features:
Made in Miami, Florida Covered by 5 Year / 50,000 Mile Warranty (on shell and tube ends) Active Autowerke B48 Downpipe Benefits The speed of a turbo’s impeller wheel is limited by exhaust back pressure. A larger down pipe relieves some of this pressure, resulting in quicker and more efficient spool. With Active Autowerke’s downpipe, your B48 can rev quicker, and deliver more horsepower and torque. Minimizing back pressure while retaining daily drive-ability was the goal of our B48 downpipe. Owners can now upgrade to a product that is affordable, reliable, and easy to install. After months of research and development, our engineers settled on a 3 inch diameter pipe which utilizes the least number of bends possible. The large volume helps the turbo spool as quickly as possible by eliminating back pressure during spool up. We are ushering in a new era in performance where we maintain air control standards without significant losses in power by using the GESI super high output catalytic converter in our signature downpipe. Constructed entirely from 304 stainless steel with 1.5MM wall thickness, we are confident that you’ll be pleased with how robust and durable this down pipe is. Trouble-free installation and a long lifespan ensure that you’ll enjoy many miles of performance with your B48! [IMG][/IMG]
08-07-2020, 06:12 PM | #2 |
Rep 190,750
08-29-2020, 09:43 AM | #3 |
Rep 190,750
09-25-2020, 12:07 PM | #4 |
Rep 190,750
10-21-2020, 12:21 PM | #5 |
Rep 190,750
12-05-2020, 05:57 PM | #6 |
Rep 190,750
12-26-2020, 11:50 AM | #7 |
Rep 190,750
01-16-2021, 11:43 AM | #8 |
Rep 190,750
02-08-2021, 05:56 PM | #9 |
Rep 190,750
03-02-2021, 11:40 AM | #10 |
Rep 190,750
03-24-2021, 03:24 PM | #11 |
Rep 190,750
04-14-2021, 03:20 PM | #12 |
Rep 190,750
05-06-2021, 05:18 PM | #13 |
Rep 190,750
05-31-2021, 03:02 PM | #14 |
Rep 190,750
06-24-2021, 11:13 AM | #15 |
Rep 190,750
07-19-2021, 11:48 AM | #16 |
Rep 190,750
08-11-2021, 11:46 AM | #17 |
Rep 190,750
09-03-2021, 02:49 PM | #18 |
Rep 190,750
09-28-2021, 02:12 PM | #19 |
Rep 190,750
10-22-2021, 08:37 AM | #20 |
Rep 190,750
11-23-2021, 05:12 PM | #21 |
Rep 190,750
