BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > UPDATE: Upgrading Just the Rear M Performance Calipers
      06-15-2016, 10:12 AM   #1
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
I started looking into getting rid of the ugly Bosch rear calipers. I went in on a deal with peterparker , he needed the front and I took the rear. They were super cheap $1250 from eBay for yellow M performance kit.
Why did I do this? Well simple to save money $850 and the performance is 95% the same as having the 370mm up front for street use. Why waste a good 4 piston brembo caliper because it uses a slightly smaller rotor
It took me a while to find all the info, since not many go this route so I am confirming It does work! After much controversy I found out that the M235i runs this setup from the factory. 340mm front (blue) 345mm rear (blue).
You need rotors for the rear I ordered part #34206797607
1. Painted the front calipers Phoenix yellow code 455
*i used m performance cast sticker logo on front just to add a bit of uniqueness to it.
2. Install rears, use Motove bleeder to bleed the calipers.
3. CODE the rears to appropriate size under DSC
It's c_variante_bremsscheibe_hinten_c and change from 20/330 to 24/345.
If you don't, you may end up with some pedal moosh.
I did. But after coding it went away
It works! DSC works ABS works, Launch Control works as it should. No issues at all.
Tip: if you have a 35i series car do not swap out the dust shields, they're the same size in the m performance kit. And to boot I got the wrong ones designed for a 320i/328i hub.
Plus the hub needs to come off to instal the shield appropriately. SKIP this the 345mm rotor has no issue clearing a 335 shield.
Downside is I have the M performance pads in the rear right now as it came in the kit and they do not have the same bite or "grip power" as we all know like the U.s. Spec m sport pads do.
If you want to do this, and are worried don't be. It all works as it should. It's proven and I have put in a lot of time to find all info on this otherwise I wouldn't have done it.
370mm rotors are cosmetic to me and I've read that the stoping power isn't any different then the 340mm.
The positive to the 370mm dimpled rotors is less weight and better heat dissipation IF you track the cars.
Happy Modding
FBO-PS1 and stuff
      06-15-2016, 12:56 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Nice upgrade!
Thanks for sharing.
      06-15-2016, 03:56 PM   #3
Vinboyblue
Drives: BMW 335
what's the part # for the brake pads (m-perf) ?
      06-15-2016, 04:49 PM   #4
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Rear-34216876422
https://www.turnermotorsport.com/p-3...335i-f32-435i/
FBO-PS1 and stuff
      06-16-2016, 01:45 AM   #5
aacabriolet
aacabriolet's Avatar
Drives: '14 435i Coupe
Nice!
Where did you get the sticker? And did you just simply stick it on after spraying? Or is it under the clear coat?
      06-16-2016, 06:42 AM   #6
Lancelot
France
568
Drives: 2017 m550i
Congrats!
It does look very good, if I had been more confident in my skills I'd have done the same as you - perhaps only in blue - and saved a ton of money.
But brakes isn't something I'm prepared take chances with, so went for the full M performance kit, dealer mounted.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      06-16-2016, 07:12 AM   #7
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Originally Posted by aacabriolet View Post
Nice!
Thank you. I bought them from an eBay vendor out of Novi Sad Serbia. Guy makes great stickers, and these are made from a very nice quality vinyl. He ships right away and I've got them in less then 10 business days.
I applied the sticker after the paint was dry, then I did 2-3 coats of high gloss clear over it all.
http://www.ebay.com/itm/201513391419?redirect=mobile
Originally Posted by Lancelot View Post
Congrats!
Thanks I'm probably in the minority but I like the Phoenix yellow a lot especially on a blue car. I think the orange or red would have looked out of place. Plus for whatever reason the yellow M perf kit new on eBay is $1250. That's a steal. So it was a no brainier. The blue calipers would have been great and a perfect match, but the only two sets I found are used and one is $1200, and the other is $1700 on eBay.
Plus I didn't want to have to repaint a perfectly good set of rears that have factory paint finish.
I don't blame you one bit for not wanting to mess with brakes especially opening up the lines. Plus you get the warranty benefit at the dealer.
FBO-PS1 and stuff
      06-16-2016, 11:18 AM   #8
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
Smart idea- perfect work!
You can use M3 rear pads (and front as well) to get both initial grip and tirelessness.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
      06-16-2016, 11:51 AM   #9
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Ahhhhh that's right I forgot those are interchangeable. Thanks for the reminder.
Thanks for the compliments
FBO-PS1 and stuff
      06-16-2016, 04:52 PM   #10
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Drives: E46 E90 E84 F30 X3G01 LCI
Nice job there. I like yellow or orange m perf. Blue is too common now. I might try to repaint it one day.
But I wonder why you didn't paint the rusty part of the front disc as well to make it all look new.
DON'T MAKE ME ANGRY!
GO1 LCI PHEV 30e. M Sport plus Pack, Tech Plus Pack, Comfort Pack, Pano sun Roof, Sensatec dash with Blue stitching, HUD, Galvanic controls.
      06-16-2016, 05:52 PM   #11
Jadar
Dejan
Jadar's Avatar
Serbia
1753
I'm going to clean the rotor hat. It's not rust it's super dirty from brake dust. Between school and my job I haven't had time to do everything the way I want to
FBO-PS1 and stuff
      12-13-2016, 12:21 PM   #12
Dmitry83
Russian Federation
54
Have you cleaned the hats already?
I used Autosol Aluminium Polish for that- amazing paste!
This post is on Russian, but you can see the pictures- no.6 & 7 show the polished hats:
https://www.drive2.ru/l/460227805792207574/
F32 bottom V-bar
      03-10-2017, 04:38 PM   #13
Cammy5
Drives: 2016 BMW 328i M Sport 6MT
I found this thread linked in another thread I was doing some reading on and it seems it's the perfect solution to my dilemma. I confirmed through the local BMW parts dept that my 328i has the following:
Specs:
• Front: Brembo 4-piston calipers, grey/unfinished; 340mm blank brake rotors
• Rear: OEM (Bosch, Ate, etc) 1-piston calipers, grey/unfinished; 330mm blank brake rotors
So the weak point is the rear caliper really. If I purchase a set of 2 piston Brembo 335i rear calipers from Ebay (approx $200), 345mm rear blank OEM rotors ($275ish), and better pads all the way around ($300ish) I should have a budget friendly 90% version of the M Performance BBK that retails for $1700 or so on sale for the yellow kit, right?
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune
*Evolution Racerwerks Competition Intercooler & Chargepipe
*M Performance Big Brake Kit
      03-10-2017, 04:46 PM   #14
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Specs:
Yep basically you will have the exact same brakes that come stock on an M235i, is that good enough for ya?
FBO-PS1 and stuff
      03-10-2017, 06:57 PM   #15
Cammy5
Sweet! Now I just have to find some bona fide 2 piston Brembo rear calipers as most of the ones I'm finding on the secondary market are what I have now 1 piston.
      03-10-2017, 07:02 PM   #16
Jadar
Dejan
Jadar's Avatar
Serbia
1753
There are a few used on eBay (blue) but over priced IMO.
I paid $500 bucks for my rear yellow with pads and sensors. You gotta find someone that needs the front set. You're tempting me to be that guy lol as I'm wanting to put bigger brakes on my wife's 228 .
FBO-PS1 and stuff
      03-11-2017, 12:02 PM   #17
Cammy5
Be that guy so we can split the package. lol.
      08-18-2017, 12:37 PM   #18
adhuang217
Drives: 2013 F30 BMW 335i xdrive
Happy Modding
Sorry for the question but do you have more info on how I can code the rears to be bigger? Does this have to be done at a dealership? Can I do it with jb4 or Enet cable?
      08-18-2017, 12:45 PM   #19
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Happy Modding
Dealership yes but they charge a lot. You need esys software and an e net cable and then VO code the brakes.
Jb4 doesn't have capability to code.
FBO-PS1 and stuff
      08-18-2017, 12:50 PM   #20
adhuang217
Hey thanks for that super quick answer. I have the enet cable and esys but didn't know i could code this type of stuff with it.
      10-11-2017, 11:13 AM   #21
adhuang217
One more question. Can this be done on esys lite or do I need the full version?
      10-11-2017, 11:31 AM   #22
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Esys lite is fine
FBO-PS1 and stuff
