BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel advice?
proTUNING Freaks
      05-15-2020, 06:48 PM   #1
oma3710
oma3710's Avatar
195
Drives: ?
Wheel advice?
For weight reduction purposes and to get a beefier tire I am thinking of downsizing to 18's. I am currently running TSW Watkins 20 inch wheels. 20x9 et 35 and 20x10 et 44. Leaning towards apex sm10 18 inch wheels. Will I notice a big difference?
SOLD! X5 35i sdrive- JB4
SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~
Aldor2787.00
      05-15-2020, 07:10 PM   #2
oma3710
oma3710's Avatar
195
Drives: ?
Originally Posted by alohasurftoad View Post
depends on what wheel and tire sizes you are using and what you are going to change to, in other words, total weight reduction, rolling resistance and pavement gearing.
but yes you will notice a big difference
I am on 245/35/20 and 275/30/20 right now.
      05-15-2020, 07:23 PM   #3
oma3710
oma3710's Avatar
195
Drives: ?
what size of wheels and tires are you switching to? the specs of wheels and tires are available for you to calculate change in weight, diameter and width.
I am not totally sure of the exact size but I want to go with apex 18's.
      05-15-2020, 07:48 PM   #4
oma3710
oma3710's Avatar
195
Drives: ?
18's, that's fine, but different widths and offsets have different weights. same for tire sizes.
are you going square? staggered?
If I go squared, will it be flush?
      05-15-2020, 08:04 PM   #5
oma3710
oma3710's Avatar
195
Drives: ?
how the wheel looks on your car depends on the width, offset, and tire size and whether you're lowered or not.
here's a lowered F30 with 18x9 ET30 245/40/18 square. take a look at it and tell me your thoughts on it...https://f30.bimmerpost.com/forums/sh...38;postcount=1
Really like it. I am lowered on eibach springs.
      05-15-2020, 08:17 PM   #6
oma3710
oma3710's Avatar
195
Drives: ?
ok good, so one option is use the same wheel and tire specs
option 2 is 255/40/18 tire size instead for more grip. it'll look beefier and be 5mm more flush, though.
I saw this setup and really liked it.
WHEELS
Apex Sm-10 - Anthracite
Front: 18x9
Offset: 30
Backspacing: 6.2
Stance: Nearly Flush Rear: 18x9
Offset: 30
Backspacing: 6.2
Tires 255/40/18
eksigned139.00
      05-15-2020, 08:23 PM   #7
oma3710
oma3710's Avatar
195
Drives: ?
WHEELS
Front: 18x9
Offset: 30
Backspacing: 6.2
Offset: 30
Backspacing: 6.2
Tires 255/40/18
you found a better example
i say just copy that. your 435vert has a lot of extra power with your mods so 255/40/18 square for sure.
Would I need spacers?
      05-16-2020, 08:42 AM   #8
oma3710
oma3710's Avatar
195
Drives: ?
no spacers required. it's always better to find fitment without spacers, whenever possible.
I'm thinking 255/40 in rear will be to small. I need more tire like a 275 or 285.
      05-16-2020, 09:51 AM   #9
oma3710
oma3710's Avatar
195
Drives: ?
SM-10 in 18X9 ET30, 18X11 ET44 or
FL-5, ARC-8R, EC-7R in 18x9 ET30, 18X10.5 ET40
With 245/40/18 front, 285/35/18 rear
Will I get any scraping? Thanks so much for the help.
      05-16-2020, 10:20 AM   #10
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
If I may chime in, also consider tires if you are looking at weight reduction.
Tire Rack was super helpful with this because they list tire weight as part of the product description.
I mention this as I was counting calories some years back on my BRZ. I went with a wider rim back then (17 x 8.5 vs stock 17 x 7), which added about almost 2 pounds to the rim weight. But I made up the difference by finding a tire just under 2 pounds lighter.
The idea was that I wanted to keep as near (or lower) the stock wheel weight so not to kill the handling of the lightweight car.
But to reinforce one of the questions, is reduced wheel weight noticeable?
On my former 95 M3, I went from the stock 23lb rims to 17lb rims. It was staggeringly noticeable. I *felt* I could charge into turns faster, brake, and turn and recover quicker.
      05-20-2020, 03:15 PM   #11
oma3710
oma3710's Avatar
195
Drives: ?
So I called and spoke to apex rep. He told me he would suggest going with 18x9 et30 in the front and 18x9.5 et35 in the rear. He said I could do 245/40/18 in the front and 275/35/18 in the rear. I would prefer to go 285/35/18 in the rear. He said I will probably rub going with that tire size and need to get fenders rolled. Is anyone running this tire in rear?
      05-20-2020, 10:46 PM   #12
johnung
aps has 245/35/19(25.8"), 285/30/19(25.7") on 19x9 +29, 19x10 +40 here...
https://f30.bimmerpost.com/forums/sh...;postcount=291
if you want to run 285/35/18(25.9") rear, you'll need a rear rim with offset between ET40 to ET45(preferred). which is why i recommended the rear wheel fitments in post #16.
(Flow Formed)Apex rear wheels that can fit a 285/35/18 with offsets that will fit are:
18x9.5" ET43: EC-7
18x10.5" ET40: FL-5 & (ARC-8R & EC-7R forged)
18x11" ET44: EC-7, FL-5, SM-10
11" ET44 inside will be close to touching the strut. rays340i fit a 295/30/19(12" section width) ET45, -1.9 camber here...
https://f30.bimmerpost.com/forums/sh...8;postcount=85
therefore, 18x11" ET44 should fit with 285/35/18 however, here is the disclaimer. i do not know if your F33 fenderwell space is the same as a F30
Wow, you did a lot of work on this thread! Impressive! 🤟
      05-20-2020, 11:27 PM   #13
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
roger that! i should be paid for this
      05-21-2020, 12:57 PM   #14
oma3710
oma3710's Avatar
195
Drives: ?
I just found these and I may pull the trigger if they fit.
https://www.m3post.com/forums/showthread.php?t=1722747
      05-21-2020, 01:09 PM   #15
oma3710
oma3710's Avatar
195
Drives: ?
Rear offset is too low. Post some pics after you get them.
so will they not fit in the rear?
Honestly, I appreciate all your help bro.
      05-21-2020, 03:08 PM   #16
weehe126
Drives: 2017 340i
19x10.5 et 22 will stick out 2/3 of an inch past the fender with normal camber. Definitely not advised
oma3710194.50
      05-21-2020, 06:20 PM   #17
Gen13 F36
Gen13 F36's Avatar
I haven't seen a F30 with fender flare (wide body kits). 1" flare go for it
