05-30-2021, 02:46 PM | #1 |
M340i
392
Rep 967
Drives: BMW M340i
Rough running N55
I've got a 435i with just under 60k miles. Never had an issue with the engine until now. Drove the car all day Saturday and parked it around 5 pm. Go out around 9:30 on Sunday morning and the car starts running rough. It started fine and I didn't notice the rough running until about 3 minutes into the drive. My low gas indicator just came on so I figured I may need gas. I've run it below this level many time before without issue but filled up anyway. Filling up gas tank did not help. I also only use 93. Took the car home and decided to check the spark plugs for any abnormalities. All plugs looked fine. They are 1 step colder ngk recommended with BM3. I've been tuned stage 1 for about 15k miles. Put the plugs back in and started the car and it still sounds like it was on 4 cylinders not 6. Car runs rough in neutral and in gear. Makes no difference. No lights or indicators on dash. Not sure what else to check. Suggestions please.
2015 435i 60k miles BM3 stage 1 for 15k miles |
05-30-2021, 03:31 PM | #2 |
Rep 1,686
Drives: 2014 428i and 2018 X5
Replace plugs and ignition coils
Clean MAF sensor Clean throttle body
05-30-2021, 07:54 PM | #3 |
M340i
392
Rep 967
Drives: BMW M340i
Thanks. I will try cleaning the maf sensor and throttle body before replacing any parts. I'll research on how to test the ignition coils before replacing. Spark plugs look good.
05-31-2021, 12:29 PM | #4 |
M340i
392
Rep 967
Drives: BMW M340i
I was able to get these codes from bm3.
06-01-2021, 07:08 PM | #5 |
M340i
392
Rep 967
Drives: BMW M340i
Anybody else? Haven't been able to drive the car for 3 days now. Might have to break down and go to the dealer!!!
06-02-2021, 08:39 AM | #6 |
Rep 923
I'd look at the electrical system, starting with the battery. Check its voltage with multimeter or cluster (onboard obdii).
Your codes didn't seem to indicate a particular cylinder misfiring, but just voltage issues. Maybe you just need a battery--if it was an alt issue, you'd see a battery light.
06-02-2021, 10:00 AM | #7 |
Rep 174
Drives: 2014 F32 435i xdrive 6 speed
I'm no expert but check out your valvetronic actuator and see if it's leaking or if there's a bad connection. This is a good thread.
https://f30.bimmerpost.com/forums/sh....php?t=1717670 Check this article out too which talks about valvetronic issues. https://www.autoscopecarcare.com/car...ses-and-fixes/ |
06-02-2021, 10:14 AM | #8 | |
M340i
392
Rep 967
Drives: BMW M340i
06-02-2021, 10:21 AM | #9 | |
M340i
392
Rep 967
Drives: BMW M340i
06-02-2021, 04:23 PM | #10 |
M340i
392
Rep 967
Drives: BMW M340i
I checked what was suggested. Battery seems fine. Valvetronic actuator connector looks fine. No oil or damage noticed. Disconnected, cleaned and reconnected. No change. I cannot find a broken or damaged wire anywhere. Checked all the fuses could find and all were good. Not sure if there are relays and where they are located.
06-02-2021, 07:13 PM | #11 |
M340i
392
Rep 967
Drives: BMW M340i
Starting to believe the bmw reliability rumor's.
06-03-2021, 10:43 AM | #13 |
M340i
392
Rep 967
Drives: BMW M340i
Update is the car still runs like shit. I can't find anything wrong and I still don't have a cell on the dash. Seems to be down 2 cylinders. Can't drive it. If I can't figure it out in a couple of days I'll take it to a mechanic. I just fear it's gonna cost thousands.
06-03-2021, 01:09 PM | #14 | |
Rep 7,597
06-04-2021, 05:15 AM | #15 |
Rep 624
If you are smelling in burnt fuel then you aren’t getting proper spark. Change plugs and coil packs first. I would go back to stock heat plugs, especially if you are only sticking with stage 1.
If you want to troubleshoot the coil packs, you can do resistance checks on the primary and secondary windings using a multimeter and compare across your coil packs. You can’t do further ignition coil troubleshooting without specialized equipment. |
06-04-2021, 06:24 AM | #16 | |
Rep 417
I jumped to the 1st post and noticed that he had BM3. Flash to stock and start the car, I am pretty sure that you will have a CEL...
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
06-04-2021, 09:22 AM | #17 |
M340i
392
Rep 967
Drives: BMW M340i
Ok duly noted. Flashing back to stock today to see if I can find codes.
06-04-2021, 02:07 PM | #18 |
M340i
392
Rep 967
Drives: BMW M340i
Tuned back to stock and got codes for bad coil in cylinder 6. Swapped the coil to cylinder 1 and code followed that coil. I've only got 60k miles on this car. How can coils go bad that early? Never had another car that had a bad coil even with twice as many miles. Wonder if BM3 is to blame. So I am waiting for a replacement coil to arrive.
Thank you all that suggested coils and told me to tune back to stock. With the tune I was getting valvetronic shorts which seemed a lot worse than the coil issue. Hopefully I am right. |
06-04-2021, 02:11 PM | #19 | |
Rep 7,597
BM3 isnt to blame for the coil, though. 60-100k is about the range for coils, yours just happened to fall into the earlier part of the range. Could be a whole host of reasons, including the cars past life and environmental factors. |
06-17-2021, 06:23 PM | #20 |
M340i
392
Rep 967
Drives: BMW M340i
FCP EURO for the win!!! I've ordered my oil change kits here and they always have good prices and pretty fast shipping. Found 6 coils here and got them in about 4 days. Installed all the coils and the car is running great. I guess the coils were pretty worn out at 60k. I feel like the motor is smoother and quicker to rev even in comfort.
06-20-2021, 12:15 PM | #21 | |
Space Shuttle Door Gunner
6430
Rep 5,309
7 yrs/60K mi life for a coil pack doesn't seem abnormally low to me. |
06-20-2021, 12:45 PM | #22 | |
Rep 605
