09-06-2020, 10:39 AM | #1 |
Rep 144
F36 reverse led lights
Does anyone on here know how to remove the reverse lights on an F36. Can't find info anywhere and want to change my reverse lights to LEDS
09-17-2020, 04:09 PM | #2 |
Rep 614
Drives: 2016 F36 M Sport
You can find the instructions in the onboard owners manual, but the process is tricky - or at least I thought it was.
On the inside of the lift gate, you pop off the plastic piece (one on each side) that covers the bulb housing. The tricky part is getting the housing out. There's 2 clips that you have to pry carefully and then the bulb housing slides straight out, which have both the inner brake bulbs and the reverse bulbs. Hope that helps!
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
Carlosskrr32.50 |
09-17-2020, 09:12 PM | #3 |
Rep 16,054
Carlosskrr32.50 |
