BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Wanting to max power, expected gains?
      09-23-2020, 08:23 PM   #1
djacinto
Drives: F32 428i Xdrive
So as title suggest, I'd like to just see what other's experience is with my shared platform and what the highest/expected gains are
I drive a 2014 428i xdrive with an n26
If I were to go full bolt on, say max out everything I could with out touching internals, new turbo, the lot
What am I looking to get power wise? And on another note, what's my mpg go down to?
      09-23-2020, 10:34 PM   #2
bmwchue
Drives: 2013 bmw 328i
fbo stage 2 tune your looking at 270whp and 300 wtrq. you might get an extra pony with a e30 tune.
      09-23-2020, 10:36 PM   #3
djacinto
Wow that's not a lot. I guess I'm expecting a little more from what I've seen
      09-24-2020, 01:48 AM   #4
Dronamashina
Dronamashina's Avatar
22
Drives: Bmw 320 lci
Depends on fuel. I think pump gas is 280 whp max, ethanol mix 300 whp max. Wouldn’t expect anything more than these numbers.
      09-24-2020, 07:17 AM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
No matter what you do there's only so much you're going to get out of an N20/26. If it was only 170HP bone stock like a Toyota Corolla there would be a lot of room for improvement, but it's not.
      09-24-2020, 09:14 AM   #6
djacinto
Yeah that makes sense. I've got 93 luckily in my town as well as my state for the most part
      09-24-2020, 09:16 AM   #7
djacinto
Yeah it makes sense for sure, I was just confused as to what B005t did to his cause I just saw thicf30's vid on the dyno
      09-24-2020, 09:32 AM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
OTS Bootmod3 maps
N20 (low-compression 28i)
Stage 1 91 octane: 16%HP / 20%TQ
Stage 1 93 octane: 18%HP / 22%TQ
Stage 2 91 octane: 20%HP / 24%TQ
Stage 2 93 octane: 22%HP / 25%TQ
Stage 1 E30 octane: 21%HP / 24%TQ
Stage 2 E30 octane: 25%HP / 27%TQ
N20 (PWG 20i)
Stage 1 91 octane: up to 24%HP / up to 38%TQ
Stage 1 93 octane: up to 26%HP / up to 38%TQ
Stage 2 91 octane: up to 28%HP / up to 42%TQ
Stage 2 93 octane: up to 30%HP / up to 42%TQ
Stage 2 E30 octane: up to 33%HP / up to 45%TQ
Stage 2 racegas: up to 33%HP / 45%TQ
N20 (EWG 20i)
Stage 1 91 octane: 48%HP / 54%TQ
Stage 1 93 octane: 52%HP / 56%TQ
Stage 2 91 octane: 54%HP / 58%TQ
Stage 2 93 octane: 56%HP / 60%TQ
Custom map will net you another 10-20% depending on how aggressive you want to go.
Pure Turbo stage 2
Check Out Our Sale Section!
Phone 725-221-5267 || website www.x-ph.com
      09-24-2020, 09:35 AM   #9
djacinto
Originally Posted by mike@x-ph.com View Post
OTS Bootmod3 maps
N20 (PWG 20i)
N20 (EWG 20i)
Pure Turbo stage 2
Thanks Mike!
I'm a little confused though, what is PWG and EWG?
And I have an n26, would that lower the top end by a significant margin?
      09-24-2020, 09:37 AM   #10
mike@x-ph.com
Originally Posted by djacinto View Post
Thanks Mike!
PWG is pneumatic wastegate (older models)
EWG is electronic (newer models)
      09-24-2020, 09:39 AM   #11
djacinto
Thanks Mike!
Got it ok, that's a little more what I was expecting. So what does it take to go from 300 to 382?
      09-24-2020, 10:29 AM   #12
sqwinny
Drives: 2013 328i M-Sport
Thanks Mike!
Full bolt ons, larger turbo (MHI, pure stage 2, hexon turbo). Otherwise you might be able to get really close with FBO and a 100% e85 tune.
FBO:
Catless downpipe
Axle back exhaust
GFB+
Turbo inlet
Intake
Chargepipe
Turbo to intercooler pipe
Intercooler (Wagner comp 2, Evolution raceworks, ATM, CSF, turner Motorsport)
Tune (bm3, JB4)
custom tune.
Good luck.
      09-24-2020, 10:32 AM   #13
djacinto
Thanks Mike!
FBO:
Catless downpipe
Axle back exhaust
GFB+
Turbo inlet
Intake
Chargepipe
Tune (bm3, JB4)
custom tune.
Good luck.
Good to know, I really appreciate it!
      09-24-2020, 10:40 AM   #14
sqwinny
Something to be aware of is when you aim to go further than 350whp, it's advised to change rods and bolts minimum as the rods and bolts are known to let get above that range. It's the nature of the motor having full torque available below 2500 rpm.
