BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > no CEL for catless downpipe
      07-12-2018, 12:33 AM   #23
475f30n55
Drives: 335IX
Originally Posted by bmwchue View Post
6months into still no code
damn impressive
      04-17-2019, 12:18 AM   #24
bmwchue
Drives: 2013 bmw 328i
allright some update info
cel finally comes on once in a while
but only when i floor it but not all times
i just open up my jb4 app and clear the codes and im good to go. its probably time to clean or install a new one. still for money ive spent for the spacer well worth it
      04-17-2019, 09:55 AM   #25
CandyRedRC46
CandyRedRC46's Avatar
237
Drives: 2013 328i
6 months and no code for me as well.
bmwchue222.50
      04-17-2019, 03:49 PM   #26
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
I've had this in my glove box for over a year and never installed it -- any chance of getting it on the downpipe without a jack and stands? i.e. can you reach it from the engine bay? I don't have a lot of my tools in this state, including my jack, and I'd hate to buy another one just to do this lol
2018 F87 M2
Stock!
2013 F30 328i (12/2015 - 09/2020) SOLD!
      04-17-2019, 10:55 PM   #27
bmwchue
if you have long arms i think you can. i did mine at the same time when installing my catless pipe.
      04-18-2019, 08:07 AM   #28
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Because you'd be putting it on the post-cat O2 sensor, I think it might be difficult to reach from the engine bay. It shouldn't take more than 30 minutes to throw it on from under the car though... Just take off the underbelly pans and you're there.
Instagram: rjd_f30 | Current: 2013 335i 6MT RWD | Past: FBO 2013 328i xDrive 8AT |
      04-18-2019, 01:56 PM   #29
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
I'm only on H&R sport springs but its still pretty low enough that I'm not sure I could squeeze under there. I'll have to give it a look next time I'm out in the garage.
I had previously purchased 2 different sets of ramps but both of them would have torn my front bumper off if I tried to drive up on them, so they got taken back with the quickness
2018 F87 M2
Stock!
      04-18-2019, 02:12 PM   #30
Carmichael
Drives: '12 F30 328i
Just get bm3 and forget it.
The last updated "Stage 2" map cleared my P0420 cat codes permanently. I've done 1k miles on the updated map and it hasn't come back.
Kev C.
'12 BMW 328i "TiLux": The Daily Racer - bm3 S2/CSF Intercooler/Injen intake/Downpipe/H&R Springs/H&R Rear Bar/Bilstein B8s/Powerflex Bushings/Style 405Ms/SAT
'86 BMW 325es: 80s Vaporwave Player | '73 BMW 3.0 CS: 70s Vaporware | '06 Porsche 911 Carrera 3.8: Ass-Engined Nazi Slotcar
      04-18-2019, 02:33 PM   #31
rjd_F30
rjd_F30's Avatar
Yah, you definitely want to get it up in the air some how. If ramps aren't an option, you'll of course need a jack. I wasn't recommending you try to slide under there without lifting it up, that would be a huge pain.
      04-18-2019, 08:02 PM   #32
bmwchue
some people cant afford $600. ive tried bm3 but i will stick with my jb4
      04-20-2019, 11:45 PM   #33
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
Spacer works great. CEL comes on for me every 500-700 miles or so but I just clear the code and I'm good to go.
2019 F32 430i Sport Line MG/CR: BM3 Stage 2 91 AGG | Injen SP1123 SRI | ER Anodized CP | ER 4" Catless DP | Resonated Straight Exhaust
Past: 2015 F30 328i AW
      04-22-2019, 08:14 AM   #34
CandyRedRC46
237
Drives: 2013 328i
I wanted to go BM3 right away after the down pipe install, but I installed the spacer, to keep the light off in the meantime. Well the car ran great, I never got a CEL and I had some other expenses come up. Here we are 6 months later and I am not in that big of a rush to flash BM3.
bmwchue222.50
      02-06-2020, 09:41 PM   #35
ibe_f30
Drives: bmw 2014 328i
so when I install the downpipe and use jb4, on which stage does it delete the check engine light and will it pass inspection.
      02-07-2020, 03:26 AM   #36
bmwchue
the old jb4 firmware used to delete the cel but the new one doesnt. if you have the app just delete it. if not use an obd2 scanner to delete it.
      02-10-2020, 04:41 AM   #37
Luverse
Luverse's Avatar
Indonesia
152
Drives: BMW F30
when i'm using N20 F30, i use local made high flow down pipe, without any remap, running for 3 years with no code since the beginning
      02-10-2020, 08:37 AM   #38
CandyRedRC46
237
Drives: 2013 328i
if mine would come on by chance I would either clean it or replace it. if that doesn't work I'll extend it
No, I get a CEL every now and again, kind of rare. Just double check, clear the code and keep on going.
      02-10-2020, 09:50 AM   #39
bmwchue
same here
      02-10-2020, 09:51 AM   #40
bmwchue
I want to see that downpipe
      02-15-2020, 11:38 PM   #41
Luverse
Luverse's Avatar
Indonesia
152
Drives: BMW F30
i dont have the photo of it
you can check their ig, amplify_performance for some reference
my car video was posted there, F30 N20 4inch downpipe, 3inch catback
      05-05-2020, 12:27 AM   #42
Socaln54
Drives: 535i
Wondering if this would work on an N54?
      07-17-2020, 05:59 AM   #43
stratman3
stratman3's Avatar
Drives: 2013 BMW 135i
I've done non-fouler on other cars but always used 2. One get drilled to make the bottom opening same diameter as O2 sensor, the second just goes over the first. Is the BMW 02 sensor shorter?
      07-23-2020, 02:14 PM   #44
rjd_F30
rjd_F30's Avatar
So I just tried this to pass emissions, and I got a CEL after 120 miles. I installed the spacer on the rear O2, did I do something wrong? Not sure how you all are going 10s of thousands of miles without a CEL, I got one after 120.
