03-10-2020, 01:49 AM | #23 | |
Rep 151
Kirill @ OdinTuned
03-10-2020, 01:56 AM | #24 |
Built Motor F30 340i
403
Rep 257
Planning to go pick up a new motor tomorrow as well as pulling the old one.
03-10-2020, 04:29 AM | #25 | |
Rep 585
After the 4/5 gear change Target AFR is 12.7 but actual AFR never gets below 13, perhaps lean condition in one cylinder? Ring broke, crankcase pressurized.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
03-10-2020, 06:16 AM | #26 | |
Rep 1,010
Sorry for your loss, Is there a way to find Spec 2 M340i B58 and make it fit in your car?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
03-10-2020, 06:48 AM | #27 | ||
Cheapskate
4447
Rep 4,993
We'll probably see some new failsafe methods added to tunes to protect the engine in this sort of scenario. I know BM3 just added several more tables. |
03-10-2020, 12:46 PM | #28 | ||
Rep 232
YT: Conrad B
IG: conradb_93 |
03-12-2020, 06:06 PM | #29 |
403
Rep 257
03-12-2020, 09:02 PM | #30 |
Rep 585
Any change of tuning strategy planned?
When the intake blew up it looked like the same chain of events was occurring. I think there needs to be a hard boost limit as these turbos, combined with enough fuel via the Dorch Stage 2 etc, can provide more than enough flow to end stock components. It'd be good to have the same safety that exists for the HPFP lower limit apply to boost upper limit i.e. cut boost, drop timing etc if MAP boost exceeds X PSI. For you that might be 29. I'd set the upper limit at about 25 or 26 PSI for the stock engine.
03-13-2020, 02:55 PM | #31 | |
403
Rep 257
kern4174446.50 |
03-18-2020, 04:07 AM | #32 |
Rep 95
thanks for posting logs, this is very interesting for others in the community to learn form, nice to see your keeping a sense of humor about it
agree with tuner and others here, that something happened mid log, that cased boost to get out of control, seems like right after shift it is concerning that there appears to be no limit, the boost target goes higher and higher, it would be interesting to know what the boost limits were set at, i set mine to about 2.7 bar or about 25 psi, and hope this will not happen, i only run about 22 psi however, it could be that if you set them too high at some point they stop working, it was limited to 2.5bar in older BM3 release, but now I can set to anything I like, even like 4 bar interesting that the remaining cylinders seems to handle almost 40 psi of boost for a few seconds, that is somewhat impressive, but I guess you will know more when you open her up it is very strange that it did not go into limp mode, when I cracked a piston ring land due to detonation on my B48 (same pistons as you), the engine was totally fine, I think they are designed to crack around the circumference and therefore the metal is captured and does not get into the engine what happened to me a few years ago after big detonation, meth cut when drifting, was very rough idle, stalling and misfire, causing limp mode, however it would only go into limp mode after misfiring when idling with misfire code, other then that the engine had no idea it was critically damaged, and even power didn't seem that far off under higher load, it would collect oil in charge pipe due to positive crack pressure pushing it our of the turbo I guess, and suck oil into the intake causing massive misfires on all cylinders and bog out, the engine was rebuilt with new pistons and is totally fine for 2 years now |
Nugget649.50 |
03-18-2020, 04:23 AM | #33 |
403
Rep 257
OzBMR574.50 B50AteYourRide70.00 ronanz1819.50 eluded3032.00 kern4174446.50 les anderson145.50 F30MGM196.00 Aberle74.00 imperfectluck425.00 |
03-18-2020, 04:15 PM | #35 |
403
Rep 257
It actually wasn't nearly as bad as we expected. Couple hiccups along the way but nothing major.
03-18-2020, 05:57 PM | #36 |
Rep 412
Nice job. What is your plan now? Still runing with the Pure 800 I guess but what is your target in term of hp this time? 600wp?
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
03-20-2020, 04:17 AM | #37 |
403
Rep 257
Currently back on stock turbo (sent my Pure 800 back to Pure to be inspected and rebuilt if need be after the engine failure to be safe), but my goal is right around 600-640whp. Honestly whatever 24-25psi gives me. As of right now i'm competing for a full built motor sponsorship by Ghassan Automotive.
03-21-2020, 04:08 AM | #38 |
Rep 296
I have that setup too - can send you some; sounds kickass honestly, but still managable for daily . IMHO no need to go for anything more than this
03-21-2020, 04:14 AM | #39 | |
Rep 296
Btw - I did my B58 conversion last week; talked with Peter at Pure in Belgium. He mentioned a lot of things, but the way I understood it, he mentioned multiple examples of things going wrong when you push around and over 600whp (Dynojet) on B58s. At that point, you need forged pistons and hmmm I think he mentioned bearings? Not sure , I'm still new to this. Also - at that point, he mentioned you will start to have to look at gearbox. There is no real good data yet on how much it can take, but it would be safe to assume that its going to need some work. |
03-21-2020, 08:30 AM | #40 | |
Rep 203
https://f30.bimmerpost.com/forums/sh....php?t=1555975 Any empirical data on the max toque that manual and automatic gearboxes can handle would be great!
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
03-22-2020, 03:37 AM | #41 | |
403
Rep 257
luke1990132.50 |
03-23-2020, 11:31 AM | #42 | |
Rep 98
03-24-2020, 03:03 AM | #43 | |
403
Rep 257
03-25-2020, 02:25 PM | #44 |
Rep 179
I just went through the same thing, had to replace the engine in my 2016 340i due to cylinder wall scoring. Swapped in a motor from a 2018 (has all the revisions that have been made since 2016) with 1700mi. Runs like brand new! Now I'm just waiting for my VTT GC to arrive so I can get that in and get it on a dyno to be properly tuned 👍
